Question about Magic Chef MCBR440 Compact Refrigerator
I have a compact fridge, Modle# MCBR415S (Magic Chef) I need some parts for it. I need clips for the freezer shelf. I need one glass shelf for the refriderator. I also need a wire pop holder for the door.
  • 249 Answers
SOURCE: refrigerator will not cool
there is a fault in compressor motor the clicking is the overload cutting off,If its a relay on the motor its worth repairing,If its the whole motor it would be too costly,I know
its not what you want to hear,but thats the size of it.the relay is in a black plastic box on the motor itself,I hope its that
Posted on Dec 16, 2007
  • 1314 Answers
SOURCE: Fridge does not get cold enough
first the freezer does all the cooling there are air vents in top of the refrigerator that the evaporator fan draws air through then blows it down to cool the fridge in the fridge section you should see an air vent if you don't have a defrost problem then you have an air flow problem first do you hear the fan running if you see heavy frost on the back wall of the freezer wall where the fan is then you have a defrost problem and that's a different repair but if you don't then remove the four screws and pull the panel carefully as the fan is there see if there is heavy frost on the evaporator a large aluminum honey comb so much that air cannot come through it under that part will be an a tray with around hole in it make sure that's is not frozen and the drain hole is open then check that the square hole that goes down to the fridge is clear and check the two square styrofoam intake blocks are clea you an pull them out gently and see if its iced up under there after you check that reply to me on any fault
Posted on Dec 31, 2007
bobotfel
  • 236 Answers
SOURCE: Recharge Refrigerant 134A into Fridge
Some technicians tried that, they just replace the compressor oil. But I did try that yet.
Posted on Jan 02, 2008
mikedurland
  • 481 Answers
SOURCE: Our Magic Chef fridge model
yes the freezer door not closing properly will effect the refrigerator. also check in the freezer back wall and bottom for any frost buildup. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 16, 2008
SOURCE: magic chef gas/electric rv fridge
Mod. R47 gas RV fridge 1973. It lights and gets cold (sometimes below freezing in the bottom of frige) then it starts to warm up above 55, but the flame is still burning high. I try to turn it down with the fridge thremostate and it stays the same. Is it the thermostate? If so where can I order one?
Jerry toolster@cableone.net
Posted on Jan 09, 2009
Magic Chef MCBR415S when I plug it up the breaker flips in the breaker box. What is wrong
is voltage select switch on back near power cord entry set for proper voltage ? 120 for usa and 240 for Europe and Canada also check light bulbs inside they could have gotten broken to cause a shortage
Aug 09, 2016 | Magic Chef Microwave Ovens
4.0 magic chef freezing on the back wall
you have a defrost component not working , timer , thermost , or defrost thermo
Nov 29, 2013 | Magic Chef Refrigerators
Magic Chef fridge too cold - defrosted it unplugged it - set the control to 1 and it still is freezing things
On the MCBR170 refrigerator the plastic clip the holds the the temperature probe to the bottom of the freezer compartment will break off and allow the probe to hang freely in the back of the fridge. This could be the problem with the refrigerator. I had this problem and used zip ties to hold the probe in the proper position. (see attached pics). magic-chef-fridge-cold-defrosted-3xqyivebcuprbty0n3yvm4ul-2-0.jpg magic-chef-fridge-cold-defrosted-3xqyivebcuprbty0n3yvm4ul-2-2.jpg
Aug 25, 2011 | Magic Chef MCBR170 Compact Refrigerator
I have Magic Chef refrigerator model MCBR415S frezzer is working but the refrigerator only cools to 52 degress what can be the problem
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 02, 2011 | Magic Chef Refrigerators
Water collecting on shelf above veggie drawer in Magic Chef refrigerator
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 15, 2010 | Magic Chef CTF2125 Top Freezer...
Is there a replacement part for the freezer compartment in a Magic Chef MCBR360S? Mine is damaged and leaked coolant and fridge no longer cools.
The evaporator can be replaced and a damaged line can be repaired. It's not cheap as a qualified tech will have to recharge the system besides the repair. With the proper model number you can look up parts here. http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a Model number help here. http://www.appliancepartspros.com/modelnumber_locator.aspx
Aug 22, 2009 | Magic Chef MCBR440 Compact Refrigerator
Magic chef bar fridge
Have the same problem with my 3 year old bar fridge. I could hear a clicking sound like it was trying to come on. Unplugged it and bought a new one. I figure the cost to repair a $100 bar fridge may not be worth it. They will charge you to come out and then charge you for the parts. For a little over $100 I bought a new one.
On the new fridge, the freezer gets colder than the fridge part..but luckily for me, it is still under warranty (Manufacturer's). I'll call for a look see-who knows maybe that guy can tell me what's wrong with the other one, too. ;-)
Feb 06, 2008 | Magic Chef MCBR440 Compact Refrigerator
Magic Chef MCBR440 Compact Refrigerator Logo
374 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
