TRANE 1984 Home A/C Where are How to Clean Coils inside House
Have 1984 Trane Home A/C Central Heat & Air Unit. Have no manuals for this. Need to clean cooling coils inside house. Unit is with the heater fan blower unit. Can't see a model #. Outside Unit is model BTD730A100A00 date 05/1984, Inside # on heater part is BLU055E936B1.
  • 52 Answers
The best thing to do it with airhandler shut down at breaker. 1st soften dirt and crud with 409 or different brand. 2nd take a wire brush and clean in up and down motion following the fins on coil.3rd rinse with spray bottle . this is the best you can do without coil removal.
Posted on Aug 24, 2009
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
How can I make the ac quieter inside the house?
If you have hard ducts, you can use some flex duct between the supply plenum and the hard ducts as a way to quiet the noise down.
May 10, 2017 | Goodman Heating & Cooling
Trane Air Conditioner air handler drips water
are you still having issues with your twg030a140b1? the heatpump that you own should not be having this issue the question is the configuration of the coil in the AHU is it properly installed. I am a distributor for Trane equipment and am wondering if the install tech installed correctly
May 30, 2010 | DeLonghi Trane 5t Rooftop Air Conditioner...
Hello We have a Trane central air
Bad thermostat, improper wiring or bad circuit board in furnace. Turn off the disconnect outside.
Dec 30, 2009 | Heating & Cooling
My rooftop Trane A/C unit shows high humidity on the thermostat, will not cool the house during the day but cools fine at night. What could the problem be? Also, how can I lower the humidity in the house?
High humidity causes Icing of the cooling coils. Avoid constant running of the a/c. Meaning let the AC pull the house dow 2 - 3 degrees at a time.. The unit shutting off will allow the ice to melt. Make sure the drain is clear by going outside and chkg for drainage. Once the house is reasonably dehumidified the ac can be set and left on its own.
Jul 06, 2009 | DeLonghi Trane 5t Rooftop Air Conditioner...
How to Clean 1984 TRANE Cooling VENTS inside house No Manuals
The Outdoor unit will be easy 1st diconeect power at panel, or disconnect box near unit. Remove top of unit, be careful not to damage fan blades. Spray coils (fins) with a light degreaser let is soak for 5 mins. wash out coils from inside the unit out. Spray straight on so you push the dirt out the other side.
Re assemble and start up.
Indoor coil will be accessed by removing front cover and you may have another cover to expose the inside of the coil fins. That is where you need to clean. Spray degreaser on coils and rinse off. If its gunked up then use a wire brush 1st. Carefull not to bend the fins over.
Check the drain pan at bottom of the coil to be sure it's not full of stuff. Blow out if needed.
You should be clean and ready for the season
Jul 02, 2009 | Ruud Central System Air Conditioner
Central Air, its a Trane, cools, however not very well. I think it needs a charge
First I would check your filters inside the furnace or air handler. Then if you have access I would check the a-coil. Sounds to me like you have a problem in the area of where the system transfers heat from the inside to the outside. Another thing that would'nt hurt would be to clean your condensing unit outside.
Jun 22, 2008 | Heating & Cooling
Heating & Cooling Logo
295 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
