Hp flat screen monitor
It's probably your dc power supply.
Mine would blank just 2-3 seconds after power-on.
I pulled this monitor out of the garbage - someone threw it away. I found any old 12vdc power supply I had laying around (1 from an hp scaner 1250mA, another rated at 600mA) neither could supply the current (amps) required to run the backlights, therefore backlights shutdown, monitor goes blank--monitor stilled powered on, but black.
I tried all of the disassembly, re-solder various solder joints on the LCD Inverter board and removing the heat/magnetic shield from inside the back cover of the monitor. Nothing worked.
I bought a Segate 80gb external hard disk drive that came with a 12vdc power supply, looks like a typical laptop power supply, rated at 3A (3000mA). Plugged it to the monitor, it powered up, and it works flawlessly.
