Question about Disney 13" TV
Not turning on
Mine doesn't even last a second anymore. It constantly turns off. There's audio but no video then it turns off. When it does get a video feed it'll maybe last a few minutes. By kids are getting frustrated with it. I've had it for about 3 years, I think.
    President:
  • 563 Answers
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. The problem is the company that manufactured that particular TV is no longer in business. The parts needed to repair the set are no longer available. You will have to replace this TV.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here.
Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 02, 2009
I have been having a problem with my amp not turning off when the car turns off. The other week I had to recharge my battery because it drained it over night.
You have constant 12v going to your remote. Check your remote wire. You need to hook it to a power source that only powers up when you turn your ignition on. If your stereo doesn’t have a remote wite coming out of the harness you can hook it to power antenna.
Nov 07, 2017 | AMP Car Audio & Video
I just bought a 40"
you are trying to hook up composite to component. the component green is your y video or black and white getting b and w proves your component is working plug up red and blue make sure your dvd player has component out have to use seperate audio for component
Jul 18, 2011 | Televison & Video
The only way mine will come on is if i connect the yellow and red wire together which makes it stay on how can i fix
This is a car audio video unit
So to connect this unit electrically, they usually require 3 wires for power for it to switch on.
  • The thick black wire is a earth or negative wire, which connects to the negative side of the battery or to the body of the car.
  • Then there is a red and yellow wire.
  • The thicker of the 2 wires red or yellow is constant 12volt power, which should be connected to the positive side of the battery or to constant 12volts in the car wiring plug.
  • The other red or yellow which is the thinner of the 2 is a accessory wire, which means it has 12 volt power only when you turn the key to accessory or motor running.
  • So yes both RED and YELLOW require power for the unit to be on .
  • This is for radio station presets so it doesn't loose memory when you turn the key off, otherwise every time you turn the key you would have to store your stations again.
I hope this helps you.
If so please leave a vote or comment.
Have a great day
MobileJB
Jul 18, 2011 | Power Acoustik PTID-8300NR Car Video...
Last night when I turned my tv off it was working fine. I turn it on today and the picture is bigger then the screen itself, and my Video 2 isn't working anymore, it doesn't even acknowledge that I...
On your tv remote click on the "wide" button and change the setting. Also you could try the setting on your cable box that pertains to the size of your screen. If all that fails, go to the website of your tv maker and see if they could send you a manual or give you advice on how to make screen smaller.
Jun 09, 2011 | Televison & Video
I have a 2001 ford F250, I replaced the stock stereo with a Boss bv8965b. It works great til I turn on the exterior driving lights then the screen goes blue like the aux screen but it has the code (Car-)....
Yes, you wire the head unit wrong, there is ground, batt12v constant(usually yellow) Constant because you radio memory, Accessory wire when the key is on(that way your radio turns on and off with the keys, and last but not least you ILLUMINATION WIRE witch when you turn your headlights gives you curren 12v...
ground
Batt 12v
Accessory (on with the key on number 2 position)12v
ILLUMINATION. 12v when lights are turn on
Mar 06, 2018 | BOSS AUDIO SYSTEMS BV8965B Car Video...
When you turn the power on it just constantly turns on and off
If you find a solution email me at gotzmines21@aol.com I have the same exact problem and can't get an answer
May 13, 2010 | Onkyo TX-SV535 Receiver
With the EIGERVISION EV-4300N how to turm sound only mode off the dvd playback
U mean the main screen of the unit (while driving) or the second screen?
Main screen, to turn on when moving (illegal in some states, not reccomended).... Ground the parking brake wire from the unit.
Second screen: Turn on dual mode in the video settings.
Jul 03, 2009 | Car Audio & Video
Doesn´t work anymore
Hi. Forgive me for asking, but did you try unplugging everything, including the firewire, and plugging it in again?
If you try this and it doesn't work, try shutting your laptop down gracefully, then unplug all the Firebox connectors including the electricity. Wait about 10 seconds, then reboot your laptop. Don't open your recording software yet.
Connect the electricity and the firewire as described in the Firebox manual, and then open your recording software. If this doesn't work, something might be wrong with the Firebox.
The problem you have happens once in a while with mine--it seems to be connected with overheating or something. Anyone else have this problem?
Oct 01, 2008 | PreSonus Firebox 6x10 External Sound...
Klh r5100 turns itself off after a few seconds
It is over heating. Mine did the same thing. Make sure you have plenty of breathing room for it
Dec 05, 2007 | KLH R5100 Receiver
Bose Acoustimass power
the amp is overheating. Disconnect one speaker at a time to see if problem persists. If so, the amp needs serviced.
Nov 08, 2007 | Onkyo TX-DS575 Receiver
Disney 13" TV Logo
49 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Demonic-2011
Demonic-2011
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
