Screen when i turn my power on it comes on normally for about 2 seconds then goes extremely dull, you can barly see anything things i have tried new cables resetting the screen and looking at the computers driver which are fine ,, i have tried this screen on another comp and it does exactly the same thing .. help would be apprieciated cheers chris
  • Anonymous Mar 22, 2014
    Using after market cable, could that be the issue? Cable is new.
Could also be the bulb... some LCD Desktop bulbs can be replaced with as little as $10.00 (us) and a little bit of soldering
Posted on Dec 19, 2007
  • 71 Answers
Sound like you have a bad power inverter inside the monitor. These can usually be replaced on laptop screens, but I have never seen the parts to do it on a desktop LCD screen ( eBay might be a good shot), but your best bet would be to send it to the manufacturer for repair.
Good Luck,
Posted on Nov 10, 2007
My Vizio GV42L is fading to a dull whitish color after 2-3 minutes. I can still see the TV program I am on but the screen just goes to a dull whitish color. No boxes or anything popping up. Basical
Either its back light inverter board, or, the LVDS cable has the fault. First try by re-seat the LVDS cable, and check. Thus you can make sure about the fault. If you wish to get more details, check this link. Selecting the view option, either to Mosaic /Timeslide, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Nov 06, 2013 | Vizio GV42L 42 in. LCD Television
1) when i switch on my hp L1906 19" LCD monitor display comes for 2 sec. or 3 second then it goes blank. then i have to switch off and again switch on but problem remain like that... 2) in my second...
this question is posted here 100 times, search much.
the CCFL tubes are burned out
as all do ,every 20,000 hours, 5 years old if run 10yrs a day.
all do,
POST 101.
Also the internal power saver must be turned off.
menu button, turn it off. on OSD
Jan 26, 2018 | HP L1906 19" LCD Monitor
My screen is extremely bright/white , difficult to
try to use the auto adjust button. if it doesn't work you have to go to the nearest service center in your place
Jul 18, 2010 | HP L1720 17 in. Flat Panel LCD Monitor
Leapster 2 screen to dull to see
The leapster 2 screen is so dull you can hardly see the writing and programs. Very dark in colour. You can see colour arounf the edge of screen but the darkness overpowers the screen.
Jun 06, 2010 | LeapFrog Leapster 2 Learning System
I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned ON the...
Try to do this: Just before the Windows start up screen (after the bios loading) press F8 and log in at safe mode settings. If at this mode you can see your screen change the resolution settings at a lower set. Save and reboot normally. Now try step by step to increase your resolution. In case of a blank screen appears at a new setting, don't do anything; after some seconds the monitor will come back to the previous settings. Save and go on.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Mar 05, 2010 | CTX S762A 17" LCD Monitor
Monitor comes on then after 2 seconds screen goes black then if i turn it off again then repeat the process does the same thing
the power supply of the light tubes is not working well
you need to replace the capacitors of the power suply
the value of the capacitors are bethween 220/40V 470/40V normal theire are 2 pieces.
you will find this in the bak of your screen after removing the cover, its near the tube connectors located.
Feb 16, 2010 | HP Pavilion F1503 15" LCD Flat Panel...
The LCD does goes dark after power on
you mean few second the monitor goes in black. then its come. if it happen, it is ok
Jan 21, 2009 | Sony VAIO® VGC-LS37E PC Desktop
Phone blinking
there a problem with your phone memory, try adding an external card, if it has one. if you do have an external memory, try to remove it, and power-up your phone. if the problem persist it needs servicing.
Dec 05, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Computers & Internet Logo
548 people viewed this question
David Payne
David Payne
