Question about RIM BlackBerry Bold 9000 Smartphone
Caller ID issues
I have several callers who do not have their numbers blocked/hidden, but their call always comes up Unknown Caller, not even the phone number.
    Problem Solver:
  • 5 Answers
It must be a *67 or from a house phone otherwise do not pick it up its etheir a retail product someone is trying to sell you something or a computer call i had this happen to me
Posted on Jul 02, 2009
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
On Samsung jet s8000 Incoming calls display unknown caller message, but call log shows ID
Check your Sim in another phone to confirm , if there is no CLIP then the service provider has barred you and must get in touch. Also is possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Apr 26, 2011 | Samsung Jet S8000 Cell Phone
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
V3a caller id unknown caller id need help figuring out how to change this as they do show up when calling
take backup of ALL the data of ur cell phone and then do a MASTER RESET.
it shud solve the problem.
i hav done it twice.
May 27, 2009 | Motorola Mobility RAZR V3
Caller ID does not display
CID needs 3 things, a subscription from your phone line provider, a phone to display it, and someone sending it.
If your generic phone is of the single line set variety and it has CID, then check with your provider. If it's a system phone, it may not have the proper equipment installed or not even be available in the phone system. Usually, even if the call is blocked by the sender, you will get a date and time and "unknown caller" or "out of area"
indication when a call comes in.
Carl
May 17, 2009 | Uniden Cordless Phone
I m getting a call from a unknown number ..he is bothering me and my family ..how can i get the name of that user...please help!!!
The person that left the "Solution #1" is incorrect. You can go to a website called Trapcall.com and set your phone up so that you can find out the number of the unknown caller. Unfortunately there is a small fee associated with this feature and it also disables your voicemail. I think it is worth it to have a solution for a troublesome caller.
Apr 13, 2009 | Cell Phones
Display always reads unknown caller when someone calls
Do you have a prepaid card or do you receive a bill monthly?
I can be the problem! you see in Latvia we must pay for the caller ID is viewable.
That can be the problem! contact your operator
Apr 06, 2009 | LG KS10 Cellular Phone
Some calls are coming through as "unknown number" on my LG U990, despite the callers having ID sent selected on their phone.
Some network providers are having trouble with caller id. You need to be sure that friends or callers are not putting code for unknown caller. Automatically You receiving as unknown calls.
Check Your phone on setting caller id click on show.
Jul 23, 2008 | Cell Phones
Caller ID - all calls come up as "unknown call"
call your mobile provider and have them assist you with this issue.
Jul 21, 2008 | Motorola Mobility RAZR V3
Caller ID Stopped Working - Think the phone needs to be reset?
Not sure why this worked, but I went to the Menu and the Set Area Code selection. The area code setting was blank, so I entered my area code and saved it. Caller ID started to work again. As a test, I went back to the Set Area Code selection and deleted the area code and saved it. It is currently still working. Seems really odd, but it worked for me.
Jan 08, 2008 | RCA 25414RE3 Corded Phone
RIM BlackBerry Bold 9000 Smartphone Logo
220 people viewed this question
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
