Question about Sharp Remote Control
I can not remove closed captioning on all my channels. i use time warner cable remote control. i dont know how captioning came about. pls help. thanks
As best I can tell, the TWC remote requires about 12 steps to turn CC on & off - very annoying and I can't understand why it's not simpler. Hit the blue menu button near the top; scroll down or up to Settings, hit enter, scroll down or up to Captioning, hit enter, scroll to how you want CC (off, on, or just when Mute), hit enter, then hit Exit to clear the screen. A pain, no?
Posted on Dec 29, 2009
How do I turn the closed caption off? I have a remote
      Immediately-within one second-push the MENU button on your remote. You should see a User Settings menu screen displayed. Use the arrows keys on the remote to highlight the Closed Caption option and press OK or SELECT on your remote to toggle Enable/Disable. Power on the Set-Top Box to return to watching TV.
      How do I turn Closed Captioning on or off? ' Time Warner ...
      www.timewarnercable.com/.../closedcapt/how-do-i-turn... Time Warner Cable
    Feedback
    How do I turn on/off closed captioning? - Comcast Help and Support ...
    forums.xfinity.com/t5/.../How-do-I-turn...off-closed-captioning/.../1325...
    Jun 25, 2012 - Turn STB off and leave TV on; Press Menu on STB or remote control; Using the ... If this does not activate Closed Captioning, try the following:.
Jan 24, 2016 | Televison & Video
Cannot remove the closed captioning
You must have its original remote control to close the closed caption.
May 07, 2012 | Sony RM-Y915 Remote Control
How do i add channels on my tv
The closed caption just suddenly appeared on my screen with no buttons pressed. It won't turn off. I no longer have the original remote for this Durabrand 13" DU1301 TV . I was using the Time Warner Cable remote and have a basic cable box attached to the TV. Everything was fine until suddenly with no buttons pushed the closed caption came on. Is there anything sort of buying a new tv to fix this
Sep 11, 2011 | Durabrand DU1301 TV
Dont know how to get the words to stop comming up when they talk captins on
If you have a cable box or satellite tv receiver connected to this television, and you are using the cable company/satellite tv company remote control the captions are not coming from your television. They are not controlled by your television or your television's remote. There is usually a hidden menu where captions can be enabled and disabled. You reach it by turning off your cable box and then immediately pressing the menu button. If your cable box/satellite tv receiver does not work this way the company can troubleshoot/walk you through removing the captions. If they cannot request to speak to a supervisor.
If this does not apply to you because you don't have a cable box or satellite tv receiver then there is usually a closed caption button on your remote control even if it is under a hidden fla or there is a closed caption option in the television's setup menu that can also be accessed with the television's remote control.
Mar 29, 2011 | Toshiba 32AV502R LCD TV
How do i remove the caption from screen on a konka tv?
On Time Warner Cable box change the Closed Caption to T3. This will remove the closed caption box when you change channels.
Sep 18, 2009 | Televison & Video
Unable to remove the closed caption through the remote control (Haier) 42 inch flat screen tv. Went through the function and selected 'No' to Closed Caption, but it does not remove it. Thanks, Sandy
I dont know what model you have i see two on there website. i read manual for one of the 42 inch lcd tvs and i do see where you confirmed you said off to closed caption mode am i correct? Ok try this turn the closed caption on and exit menu. now shut off tv and turn it back on. now go into menu and turn closed caption mode to off now and exit menu and see if that helps. ok i hope this helps ....oh i forgot to mention make sure that you didnt enable the closed captioning on your cable box remote. Just might want to check with that. It might not be your tv at all it could be the cable boxes closed captioning service. I hope some of this helps if not see if there is a factory reset in the menu.
Feb 20, 2009 | Haier Televison & Video
Closed caption for durabrand
if you have the menu button on the tv itsself then you can go from there to remove th closed caption
May 10, 2008 | Durabrand DWT1905 TV
Turn off closed caption on input(component) on Sharp Aquos 42"
Had this happen on a Comcast box (Motorola DCT 6416 III)
Here's how to fix it:
Turn the cable box off, leave fully connected. Press Menu on the remote
The cable box internal menu will display (Not the Comcast one the Motorola one-- i.e. Display ratios-16:9 etc It's in black and white)
Use the arrows to cursor to the Closed Captioning and toggle to "Disabled" Press Manu again to exit and Voila!
Power the box on an have at it
Apr 10, 2008 | JVC HD-61Z575 61" Rear Projection...
Removal instructions for close caption
If you are hooked up to a cable receiver, the closed caption must be disabled in the cable receiver. With most cable receivers the closed caption must either be on or off and there is not cc button on the remote.
Feb 14, 2008 | LG 42LC2D 42 in. LCD HDTV
Closed Captioned
Assuming whatever your TV receiving from has close caption. (Not all TV channel has close caption) Solution 1) Get a new universal remote that support your model and has close caption button. Once you program in the code for your TV model and it works then all button should also programmed including th close caption button. Solution 2) Search online for the owner manual and read see how to turn it on using buttons on TV (if possible). Solution 3) Get new TV with close caption. (If you have an old old TV with bad and huge pixels then this solution is the best. Your eyes will thank you.)
Aug 25, 2006 | Panasonic CT-32G11 32" TV
Televison & Video Logo
765 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
