Question about Brother MFC-8840D All-In-One Laser Printer
Replacing front LCD panel
The Fax and Scan switches on the front panel PCB have broken - the buttons are OK but they cannot be depressed so I guess the switches underneath are dead.
I have identified that the replacement part as the LCD panel LG4383001, which looks easy to replace (two screws and some connectors), but I cannot work out how to remove the front control panel cover to do the work - anyone have any knowledge of this or a location where I can download a service manual.
Oh - and just before you freak out - I am a qualified electronics engineer!!
  • Linker3000 Nov 12, 2007
    Many thanks for the reply - and it looked as if it would be so simple!
    I did have a good look around the printer and had come to the conclusion that the top glass probably needed to come off - kinda reminds me of the early-days Olivetti/AT&T PCs - they were beautiful to look at, but not designed to come apart again for maintenance.
    A Brother-recommended repair agent will do the job for £95 so I will probably leave it to them based on your feedback!
    I may be keen, but I am now old enough to know when it's best to leave jobs to someone who's done it before - or an engineer who will suddenly realise they have been assigned the biggest PITA job of the week!
  • Brother Master
  • 1,113 Answers
Looks easy to replace boy did you pick the wrong model, I've done this job, what a pain of a design, you just want to get to those four screws that hold that operations panel in, heres what needs to be done first, remove left rear corner covers(2) and disconnect wires cables that go to Doc feeder and scanner(27millon), unscrew and remove doc feeder, now you can take out scanner top with glass, from base to reveal screws for operations panel. flow chart below .. and dont order that part it is the LCD display only - you want number depends on country but i think the states is .LE8846001 , PANEL UNIT, MFC8840D FOR ASA/OCE not LG4383001 LCD
And dont swear when doing job remember your a qualified engineer!! have fun,
DX FEED ASSY(duplex)
(MFC-8840D/8840DN, DCP-8045D/
(3.5 (1) and (2) are contained.
p.s. the switch itself is a lot of the time ok it is the plastic arm part that breaks..
Posted on Nov 09, 2007
  • Soulvisitor
    Soulvisitor Nov 13, 2007
    Good idea, not that you couldn't do it but I will admit that the first time I did it,I put one 3pin plug from doc feeder into the wrong 3pin socket, yup so clever is the design (and so well I was focused) that there is two same size sockets and the cables reach well to both too, but do it and you've done in a board, but you will only ever do it once!
What is sequence of events when power plug is applied? it's a MFC-6890CDW Printer. Should a motor start? Should power on/off button light?
Hi. Did this just start or were you doing something prior to the failure. Sequence is usually very quiet. Unit will do a self diagnostic, then printer carriage should move from rest to a complete right/left travel. Stop then it will do a ink check you may hear a high pitch noise, it's charging cartridges. If your plugged into power strip, plug into single outlet. Check plug for burns also if your on Wi-Fi turn out off, repower up. Do same if you are on cable re start. Your not getting a code so it's something physical in printer.
Feb 06, 2015 | Brother MFC-6890CDW Printer
I just picked up a sylvana lc320ss9b it has a cracked screen i was wondering what to do
Sorry the tv it is worthless as a whole tv set.Very exspensive if tries to fixed.By replacing the tv LCD screen panel it is not possible,because the tv LCD screen panel will cost the same as a new tv.Because u only can buy the tv LCD screen panel by the tv corporation themselves only,they'll sell it to u but they charge u like a new tv for the LCD screen panel.Tv set now only can be used as salvage tv only for it PCB boards only now,for other tvs to used as salvage tv electronic PCB boards only for repair for other tvs as for PCB boards as parts that it.
Jul 30, 2011 | Sylvania LC320SS9 32 in. LCD TV
How to fax?
This section describes dialing and sending faxes directly using the Numeric buttons.
  • A PBX (Private Branch Exchange) is an on-site telephone switchboard. If your machine is connected through a PBX or other telephone switching systems, you have to dial the outside line access number first, and then the number of the party you are calling.
Sending a Fax with the Numeric Buttons .
Click here for other useful sending methods.
1. Preparing for sending a fax.(1) Make sure that the power is turned on.
(2) Load a document on the Platen Glass or in the ADF.
  • When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
(3) Press the FAX button.
The fax standby screen will appear.
(4) Adjust the density (scan contrast) or image quality (fax resolution) as necessary.
See "Adjusting the Sending Quality"
2. Sending the fax.
  • When the document was loaded on the Platen Glass:
(1) Use the Numeric buttons to dial the recipient's number.
(2) Press the Color button for color sending, or the Black button for black & white sending.
  • Color sending requires that the recipient's fax machine supports color faxing.
(3) Press the OK button.
The machine starts sending the fax.
note: When loading two or more documents
  • Load the next page, and press the same button as you pressed in (2) of step 2. Repeat the same procedure to scan all pages of the document, and press the OK button.
  • When you have sent the first page with the Black button, the following pages will be sent in black and white.
When the document was loaded in the ADF:
The machine scans the document automatically and starts sending the fax.
  • To cancel sending a fax, press the Stop button, and follow the instructions on the LCD.
  • If documents remain in the ADF after pressing the Stop button during scanning, "Close the feeder cover [OK]Eject the document" will appear on the LCD. Press the OK button so that the remaining document is automatically fed out.
Automatic redialing
  • When sending a fax and the recipient's line is busy, the machine will redial the number after a specified interval. Auto redial is enabled by default. Auto redial can be enabled or disabled by selecting ON or OFF. Select ON to specify the number of redialing in Redial times and redialing interval in Redial interval.
Redialing the Number Dialed with the Numeric Buttons
1.Prepare for sending a fax.
(4) Adjust the image density (scan contrast) or quality (fax resolution) as necessary.
2. Select the telephone number recently dialed.
(1) Press the Redial/Pause button.
Most recently dialed fax number using the Numeric buttons will appear.
(2) Use the g0016984.png (-) or g0008875.png (+) button to select the number to redial.
The selected number will appear in the fax standby screen.
3. Send the fax.
Jun 03, 2011 | Canon PIXMA MX340 Wireless Office...
My Sony KDL 4040W4100 Keeps turning off and then turns back on again durning a show... what is the problem?
These trouble is commonly caused by a rusty or dirty switch. It is easily to determine what switch, try to check the power switch or replace a new one. When replacing a switch open the back cover of your tv, try to locate the power switch by looking for the power button, It is connected in a small pcb together with the volume and channel button it is separated to the main pcb connected with a wire.
May 28, 2011 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
My HP fax 6500 is sending fax but is not receiving fax
There could be several reasons for it. the basic one is..
Press SETUP Button on front panel
Scroll to Fax setting or Advanced Fax settings - Press OK
Check for Error Correction Mode or ECM - Press OK
Turn the ECM Off - Press OK
Try to receive fax.
Oct 29, 2010 | HP Officejet 6500 Wireless All-in-One...
Tv fell on floor and now does not switch on
Take the aparts.Check all PCB boards.Might have PCB boards broken.Might even have LCD screen pannel broken,not worth repairing if LCD screen picture pannel is broken.
Mar 17, 2010 | Televison & Video
It wont turn on the button seems to be stuck in a unpushable position
You need to open it up and remove the switch PCB assembly from the front panel, then you will see the plastic power push button that is attached to the front panel by a couple plastic stems that were melted on to hold the button in place (cheapy way of making the monitor), you can try using the siliocne adhesive to hold the button in place since the silicone is flexible (that is what I use for fixing broken button/hinges)
Mar 05, 2010 | Dell E173FP 17" LCD Monitor
Start button broken
front panel will need to be taken off ..pcb assy removed ...refit new button ...replace pcb ..panel on
Jan 04, 2010 | Washing Machines
I have a broken open/close button. Can the button be replaced, or do I need to replace the whole PCB?
you need to replace a switch, which is behind the plastic button and mounted on the PCB
Nov 01, 2009 | Teac CD-P1440 CD Player
Fax, Copy, Scan Buttons do not change
Sounds like switch inside operations panel has broken, there is no reset that will fix it, will need new operations panel.
the reset code on this machine is menu # 2 8 6 4 then maintence shows enter 99, the first bit must be done super quick.
Nov 28, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8840D All-In-One Laser Printer Logo
100 people viewed this question
James Cagle
James Cagle
Jim Keysor
