Question about Sony SRS-D21 Computer Speakers
Where can I get a new audio cable for the speakers?
  • 37 Answers
A easy solution is to contact the manufacturer or your device manual for support numbers and instructions
Posted on Jul 02, 2009
I have Ativa Mobil IT mini speakers and one of the cables slipped out of the pin that plugs into my iPod.
you can have the cable repaired by someone with electronic tech skills. Far less money than buying new speakers.
Apr 21, 2014 | Audio Players & Recorders
I connected a speaker bar directly to my new LG TV. The speakers came with two audio cables ( red & white) and one video cable (yellow). I connected the red & white cables to both devices - red...
You can only get the television to recognize the external audio when connecting to its audio OUTPUT. If it does not say OUTPUT on the television where you've connected the red and white cables between it and the spear bar it is not going to work. You'll have to connect all your devices to the speaker bar with red and white cables and to the television with a yellow or green, blue, and red cable for video.
Aug 29, 2011 | Audio Players & Recorders
We connected our z 5300 speaker to a new computer. and get no. sound. Is there a driver that needs to be installed. the last computer no longer works.
Did you open your speaker ICON and check to see that you don't have the audio muted? I have seen a lot of customers complain that their NEW speakers don't work but they have their audio set to mute.
Mar 06, 2011 | Logitech Z-5300 Computer Speakers
I just got a new samsung tv and the audio out is different from my old one. i used to be able to connect my cinemates red and white cables to the red and white jacks for the audio out. however, my new tv...
That's probably a digital out. I'm really surprised it doesn't left/right standard output in addition. Are you using a separate AV receiver? If so, and it's a new model, it should have a digital audio input, and then you could send your signal out to your speaker system.
The digital audio connection uses a unique type of connector and a special cable.
If your TV has a red/white pair out from another source, you should be able to select on a menu which audio output to utilize.
Nov 08, 2010 | Bose Cinemate Digital Home Theater System...
I purchased a new computer and after hooking everything up, everything works except I have no audio. I believe the speakers are internal to this monitor.
Double check that you have the speaker cable plugged into the proper jack (audio out - green) on the computer. Make sure that the audio hasn't been muted and that it is set for the correct output type (if you have a multi-channel audio option).
Try a standalone set of speakers to check if the audio driver for the on-board audio or sound card is working.
I hope this helps.
(I've found that the integrated speakers will fail before the monitor does. Since the integrated speakers are low-end and similar speakers are fairly cheap, get new speakers of a quality you like. Repairing the speakers isn't worth it.)
May 19, 2010 | AOC LM729 17" LCD Monitor
No inlet on my computer for my X223W LCD Monitors audio cord.
Is the monitor supplied with inbuilt speakers..? Most monitors no longer have inbuilt speakers and this is why there is no place to connect the audio cable. You will have to purchase a set of external speakers and connect these to the audio output of your system.
Dec 27, 2009 | Acer 22" X223w LCD Monitor
Cable called ?
if your looking for a 3.5mm male to male audio cable you can get them at any electronics store or at walmart heres the link to it here or for the extension audio cable the 3.5mm male to female here they are usually $10 each in the store at walmart
Aug 04, 2009 | Logitech V10 Computer Speakers
Need Audio Cable Extension
You would be looking for a Lead that has a 3.5 Ml Male Connector Jack to plug in to PC, and a 3.5 Ml Female Connection on the end in which you will plug your PC Speakers in, that will also have a 3.5 Ml Jack on the end.
Dec 09, 2008 | HP JBL Platinum Computer Speakers
Please help me
If after connect your usb speaker cable the system it is asking for software (drivers) you have to install them to get your audio working properly. Check it out the box of your new speakers for a installation CD.
You can also verify:
Check if your audio es working properly (start >> control panel >> sound and audio devices)
Check if your sound card is properly installed (My pc >> Properties >> Hardware >> Device Manager >> Audio)
Oct 05, 2008 | Audio Players & Recorders
Sony SRS-D21 Computer Speakers Logo
143 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
