Question about Pinnacle Dazzle DVC 90 (210100371) Video Capture
VCR Recording Hi, I dont seem to be able to record from a VCR, everything seems geared towards a camcorder. Could you please advise me how to do this in very layman terms PLEASE Thank you.
  • 1 more comment
  • steve59 Nov 11, 2007
    Sorry this is using a Dazzle Digital video creator 90. thanks.
  • steve59 Nov 24, 2007
    I have not got a clue what the comments made by BRILLO234 are supposed to mean, I have waited a week for a response after initialy paying my money, only to get THIS. Come on, give me something I can make some sense of.
  • cesca123 Apr 14, 2008
    hi i'm having the same problem it worked ok on xp but now with vista no joy i downloaded all the drivers sugested help
I go into dazzle premimun and there are no capture options.
Posted on Nov 24, 2007
I dont have picture for recording
Welcome to Fixyah,
If yo can't see any picture please check your video cable connection.
>checked if the video cable is properly connected from dazzle to your camcorder.
>if you connect you camcorder,vhs,VCR using S-video then go ahead and click on option on step number 1 click on video input and then click on S-Video click also VHS input and then click okay.
>If RCA the same thing click on option then video input and then select Composite.
>Turn your camcorder,VHS,VCR on and then hit played button.
>checked your preview screen if the video image is now showing, If showing then start recording.
Mar 11, 2010 | Pinnacle Dazzle DVD Recorder
Picture rolls on playback
Try cleaning the heads, but it seems like the heads may be faulty, you might need to replace the vcr, they don't cost much these days, the repair might cost more than a new vcr these days.
heres a cheap headcleaner, look for one at local shops, wallmart bestbuy and so on
Sep 24, 2008 | Panasonic PV-V4021 S-VHS VCR
How to switch from sp to lp mode when playing back?
Did you try setting the rec mode to SP in the playback menu?
a54f98a.jpg This is from the D250 manual.
Dec 18, 2007 | JVC GR-D250 Mini DV Digital Camcorder
No sound when recording
Please get your microphone tested, also, you can try testing the recording using external microphone.
It seems that the problem is with microphone contacts or internal loose connections.
Seem to be a minor one, hope it will be resolved with above methods.
May 01, 2009 | Panasonic AG-DVX100B DV Digital Camcorder
Everything seems fine, but will not record.
buy a cleaning cassette and play three times and then try to record .
Feb 02, 2008 | JVC GR-D33US Mini DV Digital Camcorder
Problem with recording
this problem is caused by defective power and record start/stop switches. they are still available from Panasonic.
Jan 21, 2008 | Panasonic AG-DVX100A Mini DV Digital...
Recording Snow
If you hook your VCR up to the RCA jacks on the front of the DVD recorder, push 002 on the remote to use the front input jacks. (001 if you hook your VCR up to the rear input jacks)
Push record on the DVD recorder, and push Play on the VCR.
(Pg. 35 in the manual)
When you push play on the VCR, you should be able to see the movie being played on your TV. If you cannot, make sure your RCA cables are good and hooked up correctly.
That's all you have to do, so if it's not recording I would try to take the unit back for an exchange.
Dec 03, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Camcorder Widescreen Recording Issue
THERE IS REALLY NOTHING YOU CAN DO as your settings conflict with each unit connected
Nov 13, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Recording From An External Device
The following Models can be used as a recorder to record from a VCR, TV or another Camcorder. 2004 - SC-D107 2003 - SC-D5000, SC-D27 2002 - SC-D180 Recording In Player Mode 1. Connect the camcorder to the VCR or TV with the AUDIO/VIDEO cable (provided) (to the A/V Outputs on External Device) 2. Set the power switch of the camcorder to PLAYER mode. 3. Turn on the VCR or TV. 4. Insert the blank tape with protection tab closed into the camcorder. If you want to record from a connected VCR, insert a recorded VHS tape into the VCR. 5. Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. 6. Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. "AV IN" and picture appears on the LCD monitor. OUT : Releases the INPUT mode. 7. Press the START/STOP button to set the camcorder to REC PAUSE mode. "PAUSE" appears on the LCD monitor. 8. Select the TV program or playback the VHS tape. 9. Press START/STOP button to start recording. If you want to pause recording for a while, press the START/STOP button again. 10. To stop recording, press the (STOP) button. Notes: * Recording from an analog VCR to the camcorder is only possible when the VCR is playing back at normal speed. * If you want to see the camcorder picture with a TV, set AV IN/OUT in the menu to OUT.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
How do I make a copy from a camcorder to a VCR ?
Connect audio and video outputs of the playing camcorder or the audio and video input of the recording VCR. Set the recording VCR to AUX or Line Input setting. On most JVC VCR’s we use channel 0 for AUX. (F1 or L1 will appear on the front panel). If you have another manufacturers VCR, please refer to that owners manual for the proper setting.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Pinnacle Dazzle DVC 90 (210100371) Video Capture Logo
147 people viewed this question
Top Pinnacle Televison & Video Experts
Daniel Dollive
Daniel Dollive
Are you a Pinnacle Televison and Video Expert? Answer questions, earn points and help others
