Question about Kenmore Washing Machines
Washer won't rinse/spin/drain
My washer fills and agitates but won't rinse/spin or drain. The knob/dial
turns by itself all the way to the end of the wash cycle. When I open the lid and my clothes are swimming in water. If I turn the knob manually for each cycle each cycle will work. I have checked the lid switch and it seems to be working fine. My laundray takes forever and is piling up. Any suggestions. Thanks
  • 2,071 Answers
The lid switch ensures that the lid is closed before enabling the machine to spin or agitate. This feature was added after serious injuries resulted from people reaching into an operating washing machine. For this reason, the lid switch should never be bypassed.Aside from electrical problems, the switch may suffer from a mechanical problem. The lid may have a striker which depresses the switch when the lid is closed. Make sure the striker is functioning and aligned with the hole over the switch. Inspect the switch and make sure the metal strip is not bent out of position (if present). If your switch uses a mercury switch, make sure the mercury envelops the internal contacts when it is in the closed lid position. Your design may differ, so inspect it for proper operation before proceeding to the electrical testing.
There are two primary types of lid switches. One type on which you can directly test the terminals on the switch and another style where you have to test it at the wiring harness. In either case the method for testing the switch is the same. If a wiring harness is used, separate the two pieces of the harness and test the side of the harness that connects to the switch.
Test the switch for continuity using a multitester. Set the multitester to the ohms setting X1. Place a probe on each terminal. The multitester should display a reading of infinity. Depress the button on the lid switch and the reading should change from a reading of infinity to roughly zero. If it does not pass both of these tests, the switch should be replaced.
Some lid switches also have a fuse, you can visually inspect the fuse or test it for continuity with a multitester. If the fuse is bad, replace it with one of the same rating.
Good luck:
Regards:
VOTIT
Posted on Jul 02, 2009
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Maytag Washer won't agitate after filling
Believe you are on right track would try door lock switch first easier to replace and most likely cause.
Aug 04, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 26, 2011 | Maytag Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Washer only works by manually advancing the dial.
yes this sounds like a timer it sounds like it is getting stuck in the cycle. replace the timer and this will clear up the problem
Dec 29, 2008 | Maytag SAV3710AWW Washer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
112 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
