TRANE 1984 Central Air Conditioning & heating system. Need manual, pictures or discribe where & how to clean the inside cooling vents which is part of blower & heater unit. 1984 Outside compressor A/C Model BTD730A100A0 Heater indoor unit with blower is Model BLU055E936B1, can't see model for cooling part of it above Heater.
You need to take the cover off and you should see some aluminum fins like whats on the outside unit the blower will either blow across them or pull air accross them. Clean them with a wire brush and soapy water if you dont have coil cleaner which can be purchased at hardware stores
The Outdoor unit will be easy 1st diconeect power at panel, or disconnect box near unit. Remove top of unit, be careful not to damage fan blades. Spray coils (fins) with a light degreaser let is soak for 5 mins. wash out coils from inside the unit out. Spray straight on so you push the dirt out the other side.
Re assemble and start up.
Indoor coil will be accessed by removing front cover and you may have another cover to expose the inside of the coil fins. That is where you need to clean. Spray degreaser on coils and rinse off. If its gunked up then use a wire brush 1st. Carefull not to bend the fins over.
Check the drain pan at bottom of the coil to be sure it's not full of stuff. Blow out if needed.
utside unit just shut off breaker and hse out coil, not fan motor if needed get a degreaser spray at auto store and folw direction indoor unit you really nee to cut sheetmetal on sides and spray chemicals and then wash ff usually with a garden sprayer which then cleans out drain sametime
inside unit runs for several minutes then cuts out resulting in red,yellow and green lights...
(More)
inside unit runs for several minutes then cuts out resulting in red,yellow and green lights flashing. The outside unit takes long to come on.
when this happens i open up the unit outside & there is only one test light flassing. i have to...
(More)
WHEN THIS HAPPENS I OPEN UP THE UNIT OUTSIDE & THERE IS ONLY ONE TEST LIGHT FLASSING. I HAVE TO SHORT OUT THE TEST PINS & THEN IT WILL WORK FOR JUST A LITTLE WHILE THEN I HAVE TO REPEAT THE ABOVE STEPS.
i have a old ruud package unit that needs to be changed out do you have a replacement unit that is...
(More)
I HAVE A OLD RUUD PACKAGE UNIT THAT NEEDS TO BE CHANGED OUT DO YOU HAVE A REPLACEMENT UNIT THAT IS COMPAREABLE TO THE OLD ONE TO MAKE IT A QUICK SWAP? MODEL#URGG-10E60JKR
