Question about Sony Televison & Video
How to run laptop through tv
I'm trying to hook my lap-top to run through my sony trinitron. I have my s-video cable connected to both and the headphone jack cable running into the audio-in. Looking at a blank screen reading 'video 1', no sound. What am I missing?
    President:
  • 563 Answers
G'Day mate!
In order to send the picture from any computer to a TV screen, you must have a VGA input on the TV. You can't output your computer signal using s-video, HDMI, or component cables because they aren't designed for computer use. If you have a VGA connection on your TV, then you can use a standard VGA cable. If your TV doesn't have one, unfortunately you're out of luck.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. I hope I've earned a positive rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 02, 2009
How do i hook lap top up
Most Laptops have a VGA output port. You would just hook this to the VGA input of the TV for video (picture).
You would then need to hook an audio cable from the laptops headphone jack to the TV's VGA's Audio Input jack.
Newer laptops have a HDMI output so that is easier and can hook directly to the TV's HDMI input for both video and audio.
Nov 13, 2013 | Zenith R57W46 57" Rear Projection...
How can I hook my dell latitude e6400 lap top up to old sony Trinitron with one vga cable connected to laptop has rca and s-video also on same cable only one side thoe
If I understand your configuration correctly, you have a VGA cable that plugs into your laptop and you want the other end to connect to your TV? They make a VGA to S-video converter box that you can buy to make the connection http://www.bestbuy.com/site/agptek-vga-rca-s-video-to-vga-converter-box-adapter-switch-for-pc-lcd-monitor/1308798590.p?id=mp1308798590&skuId=1308798590
Sep 23, 2013 | Dell Latitude E6400 Notebook
Hello, have a Sony Trinitron KV-36FV27 and I want to know if it has hdmi so I can connect it to the lap top
I believe it does. It will say HDMI 720p and the connector port is very distinct. You can't miss it..
Dec 30, 2012 | Sony FD Trinitron WEGA KV-36FV27 36" TV
What's your problem?can not hook up lap top to tv
Connecting your laptop to your TV will require a HDMI cable. Attach the cable to the HDMI ports on the latop and TV, then change the source input from your TV to HDMI and your TV will now display your laptop.
Jan 30, 2012 | Televison & Video
How do I connect roku 2xs to sony trinitron tv
If your Tv does not have the HDMI port you can use the RCA cables. If your Tv does not have the RCA video/audio ports you will need an adapter from Radio Shack for hooking up a video camera to a cable Tv. This adapter will allow you to hook the Roku to the adapter with the RCA cables, then the adapter hooks to the Tv with a cable just like a cable box. This adapter is also a pass through for other devices like a cable box and or another DVD player. Hope this helps FixYa up.
Aug 07, 2011 | Sony FD Trinitron WEGA KV-24FS120 24" TV
How do I Connect a Dell Latitude E6500 to a Sanyo Television
Check your ports on the lap top see if you have s video or hdmi or dvi or VGA the best is hdmi if you have that get a cable for either one of you connections also match connections from the lap top to what you have for your TV more than likely if they are both fairly new you should have hdmi connections for both get a cable that is long enough. I get my cables at amazon.com their prices are the bomb.
Connect them together both ends to lap top and to tv then make sure that you have a line in jack stereo jack with RCA ends hook that to the back of your tv and your lap top in stereo jack even better to your surround sound system. Set your TV to AVI 1 or 2 or DVI or whichever is your connection start a movie on the lap top and turn your sound on and see if you have a picture on your screen you should have the same thing as what is showing on your monitor on your lap top. Adjust settings and have fun!
Jan 08, 2011 | Dell Latitude E6500 Laptop
My sony trinitron wega says no signal when I connect the coaxial cable.
Your Sony has several varieties of possible connections.
They include,
  • HDMI (High-Definition Multimedia Interface)
  • Component video
  • S VIDEO
  • Composite video
  • RF/Coaxial
Make sure that the appropriate choice with in the menu "SETUP" option matches the connection at the rear.
If this is done correctly and you still have now picture it may be an issue with the cable or the connector on the end. Check the tip to make sure that there is between 1/8 to 1/4 inch of the internal wire past the end of the connector.
If this looks ok try a different hook up such as the "S-VIDEO" cable and seperate left and right audio "RCA" cable.
If you have no image after trying one of the other connection types then the issue may be with the TV itself which would require servicing.
Hope this helps
Oct 07, 2009 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Top left side screen shows video 5
Get the original Sony remote. Select TV or the Video input you want to use. Then press the Display button to make the text dissapear.
Jerry G.
Nov 13, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Transferring from a Sony DCR-HC19E to an Advent Laptop with Vista (no Firewire port)
I hope you have Sony Picture Package Sofware CD in hand came with Camera. Pls install it and go to Sony Official website and download driver updates for Vista. Connect your handycam with your lap top and enjoy.
Aug 13, 2008 | Sony DCR-HC19E Mini DV Digital Camcorder
Hooking up my hp laptop to a sony trinitron tv
Let me explain on how to connect the TV to HP notebook.
There are two ways to connect the TV to the notebook. One is with the S-Video cable and another one is HDMI cable. (If you computer had HDMI port)
Connecting notebook and TV with S-video cable:
You need to get the Svideo cable and connect it to the notebook Svideo port to TV Svideo port and press Fn+ F4 to get the notebook display on the TV.
For the first time pressing the Fn+F4 keys, you will get the display on the TV and there will be no display on the Notebook.
If you press the Fn+F4 for second time, you will get display back to the notebook and Tv screen becomes blank.
By pressing the same keys again will show the display on both the screen.
Samething connecting with the HDMI cable, if your computer had HDMI port.
If you won't get the display on the external screen even after following the correct process, then once you need to reinstall the display driver.
If the issue persists, then you have to check with another cable.
Note: No need to install any software on the notebook to connect the TV to the notebook.
Aug 01, 2008 | HP Pavilion dv6000z Notebook
Televison & Video Logo
313 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
