Question about Maytag Dishwashers
Washer stops inmiddleof cycle does not drain and does not dry
  • 10,515 Answers
Is there any Error code as well?
As we are not there, we could make make some intelligent guess. I believe it's WASH PUMP MOTOR.You can also troubleshoot :-
Check the drain hose for clogs. Remove it from the drain or disposal and clean well. Does it now work?
Check and let me know.
Hope i helped you.
DO RATE THE SOLUTION.
Thanks for using "Fixya".
Posted on Jul 02, 2009
Stops at drain cycle, drain pump good and drain system clear,
If yor washer has a drip dry switch make sure it is in the off position.
Apr 08, 2015 | LG WM2140CW Washer
Malber WD1000 wont condense the water that is fed through during the drying cycle
Since it drains properly during the wash cycle, we know the drain pump and its impeller (propeller) work, and the coin trap (you called it a filter) and hoses are not clogged. By the way, turning the rightmost knob to "4" will start the pump-out cycle, so you don't have to open that trap-door at the bottom. To condense, the machine needs COLD water (spritzing on an internal screen) during drying. Make sure your cold water hose is connected to the outside (outboard) connection on the back of the machine. As a long shot: If the gray drain hose is pushed too far down into your home's drain pipe (more than 8") there could be a "back-siphon" where dirty water siphons back into the washer. It's a long shot, but it does happen.
Lastly, the controller board (mounted at top of right side) could be bad, and not sending on-off commands to the pump during drying. During drying, the drain pump should cycle on and off constantly, every few minutes. Do you hear it running? If you remove back (about 12 Torx screws), at your lower left you will see the pump. There are only 2 wires (120 VAC) and they can be connected either way. Stick a meter on the terminals and see if power is cycling on and off. If not, the controller board is bad.
You can order one from Malber (in NYC) by calling Nancy at 516-323-5299. Tell her Mike, in Wash. D.C., says hi.
Mar 06, 2015 | Malber WD1000 Front Load Washer/Dryer
WILL NOT SPIN/DRAIN CYCLE
Lid / out of balance switch faulty
Drip dry switch / button on
Sud save switch / button on
Apr 03, 2014 | Fisher and Paykel GWL11 Top Load Washer
Kenmore Washer Series 80. The cycle stops before
check to see if you have it set on drip dry
Feb 06, 2010 | Kenmore Washing Machines
M9503 washer dryer not draining before dry cycle.
Check these out:
  • If your washer spins but does not pump the water out, the drain line is probably clogged. In many washers a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that is attached to the pump or even into the pump itself. It it's in the pump, you need to remove the hoses from the pump and pull the item out.
  • To remove the item from the outer tub port, open the washer's main access panel and remove the large diameter rubber hose that connects the pump to the bottom of the outer tub. Using a needle-nose pliers, try to grab and remove the stuck item through the port.
  • Check your washer for a frozen pulley. Remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely, it's frozen, replace it.
  • If the water that pumps out of the machine goes back after the spin cycle, your washer is siphoning the water from a laundry tub that has a slow drain back into the washer. The usual remedy for this is to improve the draining of the laundry tub.
  • Also check for these problems:
  1. If the drain hose reaches more than 4 inches into the laundry tub, cut the excess.
  2. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 22, 2009 | Hoover AAA140 Front Load Washer
Machine won't spin clothes dry. I've tried the
remove the lower front panel and look to see where the electric pump hooks up to a hose and than the hose to the tub probly have a small article blocking the drain
Aug 09, 2009 | Kenmore HE2 Plus Front Load Washer
Washer keeps filling w/ water, only stops when changed to spin
Your drain line is too low.
OR the drain line is restricting air where it enters the drain stand pipe.
Remove the drain line and hold it up high.
Turn the washer on to fill. It should fill then stop.
This example should explain what you must do to correct the drain line problem.
Mar 12, 2009 | Whirlpool Washing Machines
Maytag neptune stops in mid cycle
It sounds like your drain pump is going. Neptunes are suppose to neqarly dry the clothes with how fast it spins. A poor drain pump/motor, could cause this to be less effective. There could also be something in the drain lines. I would check that before you pay money on a pump though.
Feb 28, 2009 | Maytag MAH20PD Front Load Washer
Dishwashers Logo
24 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
