Bosch 24 in. SHU43 Built-in Dishwasher
Problem for Bosch 24 in. SHU43 Built-in Dishwasher
One year old Bosch dishwasher stop wrking.will not
By mersayd on Jul 02, 2009
One year old Bosch dishwasher stop working.will not start. At first when you slammed the door it started up and ran for a week and now it is not running. There is no light when you press the on button.
Solution #1
posted on Jul 19, 2009
Somewhat Helpful)
ACiDG
Rank: Wiz
Rating: 84%, 38 votes
Start with the basics: Check the status of the breaker and the electrical connections under the toe kick panel. If the unitis getting power, You may want to call the dishwasher helpline to see if it is a recalled model. A free replacement of the control panel circuit board is available for many of these, but if the power switch is the culprit, you will need to buy a replacement button.
I have written a guide to help with drainage issues. The helpline number is near the top. It is here. Thanks!
Was this helpful?
Yes
No
Popular Solutions for Bosch 24 in. SHU43 Built-in
Questions and Unsolved Problems for Bosch 24 in. SHU43 Built-in
Do you recommend Bosch 24 in. SHU43 Built-in Dishwasher?
Answer
Answer
Door makes a loud grating sound when door is opened and closed.
Answer
it does not let in water to the machine ,the sound is normal when its plugged on,the lights are on... (More)
Answer
bosch shu43c06uc-17. Our dishwasher turns off mid cycle, and now leaks from the bottom.
Answer
shu 4302uc/u06 it will run for 5 hrs. you open the door and hit it that sometimes helps
Answer
After dishes/glassware run through a complete cycle (normal wash) the glassware is cloudy (has a... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bosch 24 in. SHU43 Built-in...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
