Our washer (Eco Intuitive) switched on by itself one day and could only turn off at the wall. We replaced the motherboard, then got fault code 105 so replaced the pump, but still got fault code 105. Have now replaced pump motor control board and still getting same fault code. The display screen module seems to be working fine so we have not replaced that. What else could it be?
Fault codes sheet is located under the dryer control cover.
Fault Code 105 Communications Error Time Out - I&A
Communications failure between the sensor module and display module. (loose wire). 1).Visually check the contacts on the RAST (edge) connector at each end on the harness between the sensor and the display module. 2). Replace sensor module and/or display module and/or harness.
SOURCE: IW712- fisher paykel intuitive eco.
I BELIEVE THAT IS A ROTOR SENSOR ERROR
REPLACE THE ROTOR SENSOR
yep I have the same problem and I can't use my machine
