Question about Refrigerators
How to set temperature on a general electric
How to set temperature on a general electric refrigerator
    New Friend:
    Problem Solver:
  • 19 Answers
Copied from ehow.com
Instructions
    • 1 Open the fresh food compartment and locate the two temperature control dials. Each dial is labeled for the compartment that it controls.
    • 2 Rotate the dial to increase the temperature setting by one to lower the temperature of the compartment. Rotate the dial to decrease the temperature setting by one to raise the temperature of the compartment.
    • 3 Wait 12 hours to allow the temperature in the compartment to stabilize before increasing or decreasing the temperature further.
Read more : http://www.ehow.com/how_8772966_adjust-temperature-controls-ge-refrigerator.html
Posted on Aug 28, 2014
2 Suggested Answers
SOURCE:
espressonist
  • 1711 Answers
SOURCE: My General Electric GSH22JFX Side
The optimum setting for your fridge is between 38 and 42 degrees F; the freezer, between 0 and 10 degrees.
However in order identify if the problem of you ice maker is the temprerature of the freezer setting or other like ice maker sensor, control board we sugest to lower the tempreruture of the freezer first by 3 degrees live it for 24 hour and check the ice bean if it is not big diference go down another 2 degrees and check again. If you still have low production you need to check the ice maker sensor and also the control board.
Before proceeding with above test you need to remove all ice cubes and clean your ice maker very good so to confirm that their in nothing blocking the ice making procedures.
Thanks for using FixYa
Posted on Sep 09, 2010
How can i get the temperature to stay on it keeps shutting off it wont stay cold since it was left open 2 days ago
[PDF]General Electric Pfcs1nfzss Quick Specs - Cloudfront.net
https://d1vofmza27mmhi.cloudfront.net/.../general-electric-pfcs1nfzss-q...
For answers to your Monogram,® GE Profile™ or. GE® appliance questions, visit our website at geappliances.com or call GE Answer Center® ... Counter-depth configuration - Counter-depth configuration makes it possible to have the look of ... Adjustable spillproof glass shelves - Raised edges keep small spills from ...
GE Refrigerator Not Running - Appliance Repair Guide
www.appliance-repair-it.com/GErefrigeratorrepair.html
In this GE refrigerator repair guide, I will walk you through the steps in ... They also added an electric damper that regulates the airflow between the fresh ... If you have aGE refrigerator that is not running the most common problem is ... Once the cover isoff, you should be able to see the main board. ... Temperature ControlMissing: pfcs1nfzss
GE Bottom Freezer Refridgerator fix. Evaporator Coil drain ...
? 2:25
https://www.youtube.com/watch?v=IiPRhr6nk54
Jan 01, 2016 | General Electric PFCS1NFZSS GE Profile...
We have a profile General Electric model PTHS22LHS. The temperature control panel turned off. The refrigerator does not cool. Once the control panel stopped working the temperature just dropped.
Check the main board on the back of the refrigerator. Remove the cover and check for a burnt spot on the back of the board. UNPLUG THE UNIT FIRST
Dec 28, 2014 | Refrigerators
turn knob inside the fridge to mid way .
Aug 28, 2014 | Refrigerators
Where is the temperature control panel of my GSS25JETA WW
It is likely there is no actual control panel, but rather a simple dial somewhere located towards the back of the inside the refrigerator compartment that has lettering that states, "warmer/cooler" with arrows that show which direction to turn to change the temperature setting.
Jul 04, 2014 | General Electric GSS25JET Side by Side...
What part number is for an
A crankcase heater is an electrical component in a compressor in an air-conditioning system, heat pump system, or chiller system. The crankcase heater is normally on all the time, even when the unit is not running, though temperature sensors and set points may turn it off when not needed. A crankcase heater's sole purpose is to prevent refrigerant migration and mixing with crankcase oil when the unit is off, and to prevent condensation of refrigerant in the crankcase of a compressor. The crankcase heater keeps refrigerant at a temperature higher than the coldest part of the system. A crankcase heater generally has the same electrical symbol as a resistor because it converts electricity directly into heat via electrical resistance. The resistance in the heater coil determines the heat it produces when voltage is applied
Apr 24, 2014 | American Standard Heating & Cooling
What should freezer setting be at
I suggest you to put it on freezer,make optimal temperature and chill :)
Mar 26, 2014 | General Electric GSH25JSXSS Stainless...
Temperature
Hello R, thank you for your question! Generally speaking it is recommended that the temperature knob is set in the middle for both the refrigerator and freezer compartment for top mount refrigerators. The temperature can be adjusted by moving the knob in small increments, allowing the temperature to stabilize. If you desire a colder temperature, then turn the knob towards COLDER, or for warmer temperature, turn the knob towards COLD. Turning the refrigerator control will change temperatures in both compartments. For example, if the refrigerator control is turned to a colder setting, the freezer control may have to be adjusted to a warmer setting. Turning the freezer control will only change the freezer temperature. Hope this proves to be helpful!
Jul 22, 2013 | Refrigerators
WHERE TO LOCATE part number WR55X1002
This part number appears to be missing a digit at the end. Please add a comment with the full part number or the description of the part for additional assistance.
Several shops have the GE temperature sensor (WR55X10025). One vendor is here: http://www.appliancepartspros.com/Appliance-Parts/ge-temperature-sensor-item-number-ap3185407.aspx . The control board (WR55X10020) is also available from several sites, including http://www.searspartsdirect.com/partsdirect/part-number/WR55X10020/0046/363 . The control panel in black (WR55X10021) is not in stock but available as a special order from http://www.partstore.com/Part/General%20Electric/General%20Electric/WR55X10021.aspx .
I hope some of these links may help you. I found Sears Parts Direct listed some similar part numbers as "Order by Technician Only".
The control panel assembly (WR55X10022) is available here: http://www.a-1appliance.com/product/GHPWR55X10022 . The refrigerator control board (wr55x10024) has a new part number: http://www.partstore.com/Part/General+Electric/General+Electric/WR55X10942/New.aspx . The temperature control (WR55x10023)
May 19, 2012 | Refrigerators
My freezer dosen't freeze enough. The temperature is situated in -2 c.
Please top up the refrigerant and set the thermostat a bit lower temperature.
Oct 26, 2010 | General 14.8 cu. ft. Electric Chest...
My ice dispencer keeps icing up inbetween the botom of the ice holder and insde the chute delivery door.
The door of your refrigerator can not be closed completely so there is an air flow from outside to inside and also from inside to outside. This refrigerator uses more electric for this. The problem can only be solved by finding the hole and closing it.
This problem generally occurs because of the legs of the refrigerator.
Set the legs equally.
So you should find the problem and correct it.
Also this generally happens after cleaning.
I hope it helps.
Jun 06, 2010 | Kenmore Refrigerators
Refrigerators Logo
298 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
