Question about Canon PowerShot SD780 IS / IXUS 100 IS Digital Camera
When i try to play back my videos, there's no sound. any tips? i've checked sound settings, and there all set properly. is there a microphone off setting i'm not aware of. it's not in the manual.
  • 744 Answers
Hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Posted on Jul 02, 2009
Audio recording for toshiba nb520
Troubleshoot: Unless you already did this, go to Device Manager and check the properties of all other hardware involved.
Mar 14, 2013 | Toshiba NB520-11W
Sennheiser md 42 microphone not being picked up on camcorder help please.
This would require a special cable to work. The mic is MONOAURAL with BALANCED output and the camera is STEREO input. This means a special cable is needed and you would probably have to make it yourself as I haven't seen one on the market.Pin 2 of the XLR of the mic would go to BOTH the tip and ring of the plug into the camera. Both pins 1 and 3 of the XLR at the mic would tie to the sleeve of the plug to the camera. If you tried an XLR to 1/8 adapter, no audio would be heard other than from the buillt in mic.
Mar 08, 2013 | Sennheiser MD 42 Professional Microphone
My chrystaleye webcam wont work with skype
SKYPE VIDEO PROBLEM
To test if the Logitech QuickCam is functioning, check the USB cable; make sure it is connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture your image/video. If this works then the fault is with the Skype configuration. Sometimes the WEBcam settings drop off and the WEBcam need to be selected again. Open Skype - Tools - Options - Video Settings and select the Logitech QuickCam Also check the Audio Settings for the Microphone THEN click on Save. Avoid connecting the WEBcam to an USB hub. SKYPE MICROPHONE PROBLEM
If the person cannot hear you then, either your microphone driver not installed or not working OR the microphone is not configured in Skype.
To test your microphone then click on Start - All Programs - Accessories - Entertainment - Sound recorder. Then record your voice and then play it back. If this is OK then the microphone need to be configured in Skype.
To configure the microphone - Open Skype - Tools - Options - Audio Settings for the Microphone THEN click on Save.
Sep 03, 2012 | Acer Aspire 5500 5570-2609 Laptop
My microphone not working
Dear,
Hardware troubleshooting Depending on whether you are using an internal or an external microphone, follow the steps below to see if the problem is with the hardware.Show all ' Hide allcollapse_individual_default.pngTest the internal microphoneThe internal microphone is located near the top of the notebook LCD display or near the bottom of the LCD display near the hinge. Use the following best practices to capture sound more easily.
  1. Adjust the notebook screen to place the microphone in the best direction for receiving sound.
  2. Click Start , enter sound in the search field and select Sound Recorder from the list.
  3. Click Record and speak into the microphone. Save the file to an easily-accessible location, such as the desktop.
  4. To play back the recorded sound, open the file using Windows Media Player.
  5. When using the internal microphone, choose an environment without background noise.
  6. If the recorded sound does not play back, continue to the next section of this document.
collapse_individual_default.pngTest the external microphoneVerify that the microphone port and the microphone are working properly.
  1. Test the microphone on a known, working portable tape recorder, another computer, or a device that accepts the microphone connector.
  5. If the recorded sound does not play back, continue to the next section of this document.
  6. If the microphone successfully records the voice, test the record function on the computer. If the microphone does not work properly on another computer or on a tape recorder, try using a different microphone.
collapse_individual_default.pngSet the default microphoneIf the external microphone is set as the default recording device, uninstall and reinstall the audio driver to change the default recording device to the internal microphone. The internal microphone should be the default recording device.To change the default recording device:
  1. Click Start , enter device into the search field, and then select Device Manager from the list.
  2. Expand the Sound, video and game controllers list.
  3. Right-click the audio driver , select Uninstall from the drop-down menu, and then click OK to confirm that you want to uninstall the audio driver.
  4. After the audio driver is uninstalled, click Start , enter backup into the search field, and then select HP Backup and Recovery Manager from the list.
  5. Follow the on-screen instructions to reinstall the audio driver.
The internal microphone is now set as the default recording device. Basic troubleshooting
The following are some basic troubleshooting tools that you can use to restore your microphone's functionality, depending on your operating system and/or software preferences. However, it is recommended that you first run the HP Support Assistant as it can scan your current system configuration to automatically determine if your notebook requires updated software and device drivers.
Mar 09, 2012 | HP Compaq d530 SFF PC Desktop
No sounds on skype
If you can play songs or videos without sound problem on your computer, try this.. Login to your skype account, click "Call" on the menu and select "Audio Settings" and deselect both "Automatically adjust microphone settings" and "Automatically adjust speaker settings" and move both the sliders towards the left. Also check the default "Microphone" and "Speaker" and make sure the shown device name is your default sound device of the sound settings. Save the settings and try again. It should work fine.
If you need further help, let me know.
You can refer this pic..:
Good luck.'
Thanks for using FixYa.
Aug 29, 2010 | Compaq 40/80 DLT VS (td-cq40225) Tape...
No sound when I play back using an external micropohone however when I play back on the TV full sound. Any solution?
Microphones are input devices; they don't double as speakers. If you mean that a stand-alone set of speakers do not work, but the internal speakers of the tv do let you hear the audio track from the camera. Then I have a couple of different suggestions: 1) make sure the stand-alone speakers work with other input sources, 2) try a different cable (make sure it is connected properly).
Also how are you connecting to the different devices? The video camera has an HDMI port which will send audio and video to the TV on one cable. If you are using the RCA audio in both cases, then I suspect a problem with the external speakers.
If you mean that the audio track is clear on play-back when you use the built-in microphone during the recording and not heard if the external microphone, check the external mic for problems. Try it on another recording device. I can't rule out a jack failure without more information.
I hope this helps.
Jun 03, 2010 | JVC Everio GZ-HD7 Camcorder
Microsoft Lifecam problem
Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select
Camera Microphone or Headset.
Click OK and it should work. Laptops have built in micophones if on at the same time as the camera microphone will cause audio
to be give you static. Either shut off the internal mike or disable the camera mike and see if that helps.
Then to use it on the Web, do this.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set
it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ )
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions
on the left window.
C. Windows Live Messenger:
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window, click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings?
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own
camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
Nov 30, 2009 | Microsoft LifeCam VX-3000 Web Camera
My creative vf 0040 won't play back sound
Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone or Headset.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your Computer does not set it up to broadcast on messengers or Skype. Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
2. Then click on the Video Settings.
3. The camera if Installed Properly will come up and show a video picture.
4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able tosee and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html) set it up as follows:
1. Go to Messenger at the top left and click on it.
2. Next go down to Preferences and click on it.
3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
3. Next go to the Menu Bar on right side, click on “ “Action.”
4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
Go to this site http://dashboard.aim.com/aim and Launch AIM AOL Messenger.
1. On the VIM sign-in window click on Edit.
2. Then click on Settings Enhanced IM.
3. Next click on Enhanced IM.
4. Then click on Audio Video.
5. The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
Microphone
Speaker
Camera
Additional information to use with VIM settings,
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
Notes:
· The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
· images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the picture-in-picture (PIP) display.
Aug 23, 2009 | Creative Labs Creative Webcam
My built-in microphone doesnt work due to important sound updates
Normal 0 Check your Audio Setting.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
NOTE: You audio and video shoud work. Enjoy.
Jul 05, 2008 | Logitech QuickCam Communicate STX Personal...
Re: No sound
yup 9 proable dont suprt vista 11 verison will and beter
Jan 05, 2008 | Ulead VideoStudio 9
Canon PowerShot SD780 IS / IXUS 100 IS Digital Camera Logo
302 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
