Question about Kenmore 21.9 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
We have a leaking water line at the dispenser level. how do you remove the black plastic casing on the front?
  • suzymoyd Jul 03, 2009
    Thank you thank you thank you! That's exactly what I needed to know!
    President:
  • 1,136 Answers
Hi, The casing just snaps in on most models. With a flat blade, pry the bottom edge (there might be to small gaps on the bottom edge) away from the door. The casing should release and lift off.
I hope this helps you.
Vic
Posted on Jul 02, 2009
  • Victor
    Victor Jul 03, 2009
    You are very welcome. This the reason I am here........ To help you!!
    Vic
Water dispenser does not work, any time it is used water just drains out of bottom of freezer area onto floor. Ice cubes works
Hello Melissa;
My name is Peter. I am a retired field service refrigeration technician.
I am sorry to say you have a serious problem.
The water supply line to your ice maker runs up the back of your refrigerator from the ice maker solenoid. It is a separate water supply line.
Your water dispenser water line runs from the water dispenser solenoid under your unit and up from the bottom of you freeze door.
You have a plastic tubing leak within your freezer door. Calling a service company to replace the freezer door tubing - a good service technician would not replace the tubing - the damage has already been done.
The insulating material in your freezer door is soaked. The water in the door will cause the door liner to expand and crack. There is no way to completely dry out the insulating material.
The only fix is to replace the freezer door. So, $300.00+ for the door and $150.00+ for the service tech. No, a hair dryer will not do it.
May I suggest:
1.) Remove the bottom toe plate (Kicker plate) in the front of your refrigerator.
2.) Turn the leveling screws counter clockwise so you can pull the refrigerator out to get behind it.
3.) Unplug the unit.
4.) Remove the screws from the bottom cover.
5.) There are two connectors to the solenoid valve to the water dispenser. It is the larger diameter tubing running under your refrigerator.
This will disable your water dispenser. If you see cracks on the inside of your freezer door, seal them with a high temperature silicone adhesive.
If you elect to purchase a new unit, check out Sears Outlet (Scratch & Dent) Stores.
May 08, 2015 | Refrigerators
Side by side whirlpool refrigerator leaking water puddle in front on floor no loose connections and no signs of water from any part of refrigerator
Hello;
There are several areas where you may have a leak.
Let's check it out:
You are going to have to pull the unit out so you can inspect what is going on.
Turn the leveling screws counter clock wise to raise them. Pull the unit out so you may get behind it.
25576703-vzgcvxho43azc0x10cxafhpi-5-0.jpg 1.) Observe the plastic tubing going to the water dispenser.
The plastic tubing after time get dry rot. Have someone push the water dispenser and observe the tubing for leaks. But before this put a paper towel under the bottom hinge of the freezer door.
So, if you observe water coming from the tubing that is your problem.
Or if the paper towel in the front is wet, then you have a major problem. There is a leak in the door tubing which is only repairable by replacing the door, which is several hundred dollars plus service - $600.00. You can disconnect the contacts on the larger tubing valve and not use the water dispenser.
Ok, no leaks. Then you have a drain pain leak. Un-plug the unit. Remove the lower bottom cover in the back. Just several screws. Inspect the drain pan. Is there a water line from the pan to the front of your unit.? Repair the drain pan with duct tape and a silicone adhesive.
Inspect the bottom of your freezer. If there is ice then you have a different problem.
Keep me informed. Glen Burnie, MD., Email goodwinpeg@aol.com, Phone: 414-306-1362.
Mar 15, 2015 | Whirlpool Refrigerators
Why does oil leak at the bottom of the Gibson refrigerator door
Hello Susan;
You do not have any oil in your system with the exception of a few ounces in the bottom of your compressor. This is not your problem.
You have a water leak. The water will run across the bottom coils and the floor. By the time it reaches the front of your unit it looks oily.
Pull you unit out. Make sure you raise the leveling screws in the front first.
Remove the lower back cover. There are a few screws holing it on.
1.) Inspect the drain pan. Is it leaking?
2.) Inspect the water shut off valve. Is it leaking.
3.) Inspect the plastic tubing to your water filter, ice maker and water dispenser. Plastic tubing will dry rot and crack over time due to the heat.
4.) Have someone press your water dispenser while you observe for leaks in the back.
Feb 26, 2015 | Electrolux Frigidaire Tappan Gibson...
Miele G2020 leaking 2 spots help
please follow this steps and fix it. God bless you
Dishwasher Not Leveled
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily.f3a0b0dc-c8b0-4678-bccb-f94392039827.gif
Door Seal
This is not very common in most dishwashers. To check this look for rips and distortion of the seal. If it is ripped or distorted you will need to replace.
Dispenser Seal
This is a more common place for a leak to develop. This is easy to check, remove the front panel and carefully inspect around the seal for water dripping or stainage. If any is found replace the dispenser gasket.
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace the water inlet valve.
Drain / Circulating Pump
Some dishwashers have separate drain and circulating pumps Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. Follow the tutorial on replacing the pump.
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust switch until properly aligned.
Door Hinges
They can cause problems, but this usually only happens from opening a heavy load of dishes on the door. Occassionaly a broken spring or cable occurs. You will need to remove the tow kick and maybe the front panel to inspect.
Jun 14, 2013 | Miele Dishwashers
Dishwasher leaks after I cleaned the air pump
If your dishwasher is Leaking check the following
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily. Watch the video on leveling your dishwasher
Door Seal
Dispenser Seal
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace the inlet valve water
Some dishwashers have separate drain and circulating pump. Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace.
Door Latch
The door latched can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust switch until properly aligned.
Door Hinges
They can cause problems, but this usually only happens from opening a heavy load of dishes on the door. Occassionaly a broken spring or cable occurs. You will need to remove the toe kick and maybe the front panel to inspect.
Use the VOM, God bless you76c7517c-e034-47da-bf6c-02b58ecb7551.jpg6274586f-de4d-45f0-bbab-ada21592e251.gif
Apr 05, 2013 | GE Profile PDW8400J Built-in Dishwasher
How can I get to the inside
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily. Watch the video on leveling your diswasher
Door Seal
Dispenser Seal
Water Inlet Valve
Some dishwashers have separate drain and circulating pump. Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. .
Door Latch
Door Hinges
Drain:
This is usually caused by a syphon effect or your drain line improperly installed. You can not attach your drain line from the dishwasher without having a loop in it. If you go directly under the floor with your drain hose, all water will drain out upon fill. Safest and recommended installation of drain hose is to your kitchen sink and attach the hose somewhere so it is higher then the bottom of your sinks.
be65763a-411f-4910-88d8-4712ce0a8d7e.gifda9b96d7-ebd5-4e03-8f4c-4d0c49063e70.gifGod bless you, Use the VOM very important
Apr 05, 2013 | Kenwood Dishwashers
GE Profile TPX24...water leaking from under freezer side...water dispenser works fine, but ice maker not working properly. What could be the problem...and how do I fix it?! Thanks
i had the same issue twice. 2 suggestions 1) Remove the front grill at the bottom and you will see a plastic water line. Inspect it to see if it is leaking. Turn on the water dispenser when you are looking at the line. 2) pull out the refrigerator and remove the lower panel. Follow the plastic water lines to a solenoid valve and inspect the lines when you activate the water dispenser. water may leak from where the lines go into the solenoid value. if may be a simple fix like cutting the ends off the lines and reinserting into the solenoid valve.
Jun 14, 2009 | GE Profile TPX24PBDCC Side by Side...
''GE tfx28ppcb fridge has water puddle usually on right side
I had the same problem, I found that the plastic tubing feeding the water despendor and icemaker was run right along the comperssor, over tiem the from exposure to the heat the tubing had become brittle and cracked.  the black tube shiled had to slid up to expose the cracked tube. A  new tub installed and splice to existing dispensor feed line fixed probelm.
Dec 08, 2008 | Refrigerators
Water Leaking really bad from the Dispenser area
Disconnect the plug from the outlet. Remove the top of the washer panel by removing the 2 back hex screws then sliding it back to lift it off of the washer. Take off the front control panel by removing the phillips screws holding it in place. Remove the dispenser drawer. Check the dispenser housing for clogs or lime build up at the bottom of the dispenser housing. Or the drain hose (large black hose attached to the front of the drawer housing) to the washer may be crimped or clogged.
Aug 14, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Fabric Softener does not syphon and water leak from front of dawer.
The detergent/softner dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distributed to drawer's cells (following the programmed cycle) by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next test !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Sep 10, 2007 | Tecnik TKL9290 Front Load Washer / Dryer
Refrigerators Logo
82 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
