Question about Genie Aire PACR12 Air Conditioner
Can Model PACR12-GE be transported on its side with no problems?
Can these units be transported on their sides? Model PACR12-GE
  • 855 Answers
Most ac or refrigerators and freezers can not be moved moved in any position other than in the upright position. The few that can will tell you in the owners manuel. The ones that can after you move them you must put them in the upright position and leave set not plugged in for between 12 and 24 hours.
Posted on Jul 02, 2009
When i moved my kic chest freezer model kc0021-Aa, I heard an light explosive sound and now the freezer does not go on.
The following is the GE moving instructions. If you have started before the 24 hour rest period and the unit had been rotated from vertical have the compressor inspected.
FREEZER MOVING INSTRUCTIONS Please use the following steps when relocating an upright or chest freezer:
  1. Disconnect the power cord from the wall receptacle.
  2. Remove the food, defrost, and clean the freezer.
  3. Use blankets to protect the freezer finish from scratches.
  4. Place the freezer on its side for moving only if you have no other choice.
  5. When transporting a freezer, keep it in an upright position. If transporting it in an upright position is not possible, lay it down on the compressor side of the unit. Be careful to secure the door to prevent it from opening.
  6. If it has been transported on its side, set it right side up in its final location and allow the freezer to sit for the same amount of time that it was on its side (24 hrs max.). Do not plug the unit into the electrical receptacle without allowing this settling time. The unit can be damaged if it is plugged in prematurely.
If the unit was transported in an upright position there is no waiting time required.
Hope this helps?
Apr 07, 2017 | Freezers
What problems exist with GE model pscs5rgxafss
I have a GE Profile Side by Side Model PSCS5RGXAFSSThe lights work but it does not cool (or work) in the Fridge side or the Freezer side. The front door panel numbers illuminate but, will not control any setting. What's wrong? The unit is 4 years old.
Sep 04, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
GE model GTS22WCP can I lay it on it's side or back to transport?
it is not recommended to lay an appliance with a compressor, the reason is that the compressor oil will run to one side and the appliance will not function properly. i have heard that if laid down the make sure to stand the appliance upright for several days before plugging it in.
Aug 08, 2012 | GE GTS22WCP Top Freezer Refrigerator
Moved unit, wont get cold
did you transport it upright or laying down.... depending on who you talk to you will get a different answer... i have been in the appliance business for 18 years and have to say the more i hear they are transported laying down the more i hear troubles... either way after transported or moved they should be left sitting for approx. 24 hours to allow all the oil to settle back down,,,also could have developed a leak in the sealed system one of the refrigerant lines leaking.
Feb 14, 2011 | GE Refrigerators
I have a GE Profile Arctica side-by fridge that previously worked great, however we moved and now won't cool. Maybe important: to fit in a pickup truck the fridge was transported on its side for about...
COOLING
Dust on the condenser coils can cause overheating, observe safety precautions then clean coils. Switch off the unit before you clean them. If the problem persists, test the compressor for overheating. Overheating will cause many problems with cooling ability. Leave the unit unplugged for 3 hours and plug it in again. If it starts working, the compressor is probably overheating (Observe cautions with food going bad). A simple cause of the problem might also be that there is not enough airflow Lack of airflow is the number one cause of compressor problems and thus an owner purchasing another unit for hundreds of dollars when you can fix it for free.There should be at least several inches distance between the sides and walls/cupboards/ceiling.
Electrical
There is an in-line fuse mounted in the line supplying the power to the ice-maker. It is in the wire clipped to the side, change out this fuse asap. It is actually a 20-amp fused, associated with the grounded electrical supply.
PARTS
You may order parts very cheap from here
www.canadianappliance.ca/KBRS22KV.html
TIME TO CHANGE YOUR FILTER
While your on the back of the system, please check the filter. There is a filter in the back of the fridge in the upper right hand side. If you do not change it, it will slow down the frig and burn it out permanently.
Jan 24, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Transport
yess you can do this how ever make sure the unit stands back upright for approximatly one hour of the longer it stays on itside the longer you have to let it stand up before plugging it back in.
Jun 09, 2010 | GE GSS20IEP Side by Side Refrigerator
Frig not cooling-water line frozen
Check to see if the fan in the freezer is working. It moves cold air from the freezer side to the refrigerator side. If it is not working or if there is an obstruction in the duct work the issue could be there. Fans and motors are cheap and easy to replace.
Apr 12, 2010 | GE Profile PSW26P Stainless Steel Side by...
Genie Aire PACR12-GE - Warning light flashes 3 times-No cold air
Turn the unit off, check the bottom rear of the unit and place a shallow pan under the drain outlet and remove the rubber plug to drain the condensate out of the unit then replace the plug and turn the unit back on.
Jul 26, 2009 | Genie Aire PACR12 Air Conditioner
Fridge and freezer won't get to temp
you have problem oil get in the evap call service
Dec 29, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Genie Aire PACR12 Air Conditioner Logo
170 people viewed this question
Top Genie Aire Heating & Cooling Experts
Michael Youngman
Michael Youngman
Ronny Bennett Sr.
Ronny Bennett Sr.
ray gallant
Are you a Genie Aire Heating and Cooling Expert? Answer questions, earn points and help others
