Maytag MDB9600A Jetclean II Built-in Dishwasher
Problem for Maytag MDB9600A Jetclean II Built-in Dishwasher
Dishwasher will not drain
By uteeckstein on Jul 02, 2009
I am having the same problem. My dishwasher latch was also broken and I had it replaced. It worked for a little while and now the dishwasher won't drain.
Best Solution
posted on Jul 02, 2009
Very Helpful)
taran_2005
Rank: Guru
Rating: 88%, 968 votes
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Thanks.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Aug 12, 2009
Not Rated)
krd72702
Rank: Apprentice
Rating: 0%, 0 votes
hello,
my dishwasher fills that ' s all it does but it won't run the cycles or drain,and is there a manual on how to take it a part.please email me with how to take it apart krd72702@yahoo,com thanks Karen
Was this helpful?
Yes
No
Popular Solutions for Maytag MDB9600A Jetclean II
Questions and Unsolved Problems for Maytag MDB9600A Jetclean II
Do you recommend Maytag MDB9600A Jetclean II Built-in Dishwasher?
Answer
Answer
I am looking for a dishwaser with a short cycle time. About a half hour or so. Are there any... (More)
Answer
Need to take apart the sprayer arm to get lime deposits scraped out. How do I do it
Answer
arms do not turn even though dw goes through water filling and emptying routine.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Maytag MDB9600A Jetclean II...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
