Question about Hotpoint HSM25GFRSA
My lsc26905 ice dispenser works but ice get stuck where it needs to drop, instead it stays in the 'hole' in the door and won't drop out. Thank you
Hsm25gfrf makes ice but ice dispenser does not dispense water comes out in spurts and refri makes a load clock like ticking, witch is coming from back computer grid panel ?
Posted on Mar 13, 2010
  • 10,865 Answers
Clean that area. Use a hair blow dryer to remove any ice. dry it well and spray it with PAM. This spray is edible so it will not cause a problem and it will lube the chute.
Posted on Jul 02, 2009
Fixing in door ice dispenser
What is the model number of the unit?
Nov 23, 2012 | Kenmore Side by Side Refrigerator
LG LSC26905 makes ice, but will not dispense through door. Ice backs up on inside of freezer door when attempting to dispense ice (crushed and whole cubes). Water dispenses OK. Any help? Thanks.
Sounds like the flap or door directly above where the cup would be is not opening. Press lever and look up in there, if that is the case there is a problem inside the door.
Sep 17, 2011 | LG LSC26905 Side by Side Refrigerator
Ice dispenser stuck on
Either the paddle for the ice/water dispenser is stuck or you have a bad microswitch behind the dispenser.
To stop the ice/water from dispensing open the freezer door and press or hold the child lock button down. Once the unit is in child lock mode you can shut the door without energizing the dispenser.
Another option is to remove the upper freezer door hinge cover and disconnect the wire connector up there. This will remove voltage from the dispenser as well. Then either replace the paddle or switch. Sometimes the paddles/switches will get stuck because of splash up from ice dropping in sugary drinks.
May 05, 2017 | Amana ASD2328HE Side by Side Refrigerator
Ice maker not working on Kenmore Model # 106.54563300 Water comes through water dispenser fine Water came pouring out through ice dispenser door so I flipped bar up to turn it off Removed front box held in...
First the arm has to be in the down position. It sounds like you said theres water in the ice maker. If thats the case then it should have frozed. The ice cannot drop unless the ice maker heater comes on. Then the ice maker scoops the ice and drops into the resoviour thingy. If you have ice in the ice maker tray but no ice in the bucket then the ice maker is defective.
Mar 25, 2010 | Kenmore Freezers
Makes ice fine but doesnt dispense
Sounds like the dispenser auger is frozen up or stuck. The lights dimming happens because the voltage drop from the stuck auger's motor when you try to use it. Remove the ice machine and clean it. Do not try to take it apart!
Sometimes, the ice machine will fill too much with water and get stuck. Often, it's because the cabinet isn't level.
Jul 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ge, tfx26kpda ww, ice maker only dispences crushed ice
At least yours is making ice. Mine wount even make ice. While toubleshooting my prob, I notice a metal rod on the bottom of the ice tray. This rod opens and shuts a plastic "trap door" in the tray. The position of that door determines whether the ice is crushed or whole. If the trap door is open the ice falls through the dispenser freely. If the door this closed the ice is force thorugh metal teeth where it is crushed then dispensed. Open the freezer door and take the ice tray out. You should see a hole at the back of the freezer that the metal rod goes through. In that hole there is a plastic square that moves up and down. If the set your dispenser to crushed ice, leave the door open, push in the door switch at the bottom, and press the dispenser. The plastic square does nothing while the motor is turning. That allows the door to stay closed and forces the ice through the metal teeth. If you set the dispenser to whole ice and do the same thing the plastic square is suppose to lift up forcing the door open and letting the whole ice drop freely. The plastic square probably does nothing even if you set it to whole ice. That mean the trap door never opens focing the ice to always get crushed.
Unfortunately, I have no solution because mine works and I had no need to investigate further. I hopes this helps you figure out the problem though
Good Luck.
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser
you may have a promblem with your despensor acuator being stuck remove your ice bucket and look in the back of the fridge where the steel rod goes in its like a square hole if you see a plastic bar about half way across it see if you can pull it down while the bucket is out and with the door open hold down the switch the one that dont turn off the light an push the dispessor switch while watching that hole go from crushed to cube and let me know what you see
Jan 18, 2008 | Frigidaire FRS26H5AS Side by Side...
Ice dispenser
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced or something is wrong with the mechanism. The problem you describe is almost always air leakage around that flap.
Post back with the complete model number from the fridge if you need more help.
Nov 14, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Hotpoint HSM25GFRSA Logo
107 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
