Frigidaire GLRS264ZA Side by Side Refrigerator Logo
A
Anonymous Posted on Aug 27, 2014
How do I troubleshoot the water feature on the freezer?
  • Frigidaire
    Frigidaire Sep 02, 2014
    Thank you for your inquiry, Friend. I am happy to assist you! In order to provide you the correct instructions on how to troubleshoot the water feature on your Frigidaire refrigerator, I would need your model number please. The serial tag, which lists your model number, is normally located inside the cabinet, on the right side wall. Also, what is the feature that you are having trouble with you? Is the dispenser not properly dispensing water or ice? Thank you and I look forward to further assisting you. - Z
Ice maker, water and light stopped working.
If the light you are talking about is the freezer light, along with the ice maker and and water dispenser, I would guess you have a bad freezer door switch. That switch works the light but is also an interlock switch that keeps the dispenser features from working when the door is opened. Either the switch is bad or a wiring problem going to the switch.
Water leaking from inside of freezer bottom
Check the defrost of the freezer which you are using right now.For More information please visit Clothes Dryer Element.
1helpful
Freezer filled up with water from ice maker
That is caused by a defective water control valve on the ice maker side of your water control valve. The only way to repair is replace water valve. Please rate this solution, Thank You, Sea Breeze
Ice maker dont work
There are several things that can prevent and icemaker from working.
1- Temp in freezer. If the temp in the freezer is higher than 6 degrees the ice makers thermistat will not call for water.
2- Water inlet valve. If the inlet valve is malfunctioning the silinoid may not be opening. Even if you are getting water through the door.
3- Faulty ice maker. If the internal components of the ice maker are no longer functioning it wont make ice.
To test the inlet valve. In the back of the fridge is and access panel near the bottom remove this panel and look at the inlet valve. now you should see 3 hoses. One is usually copper and runs directly from the house water supply. There will be two other hoses from the inlet. One leads into the fridge for the water in door feature. The other is for the icemaker. Switch the two hoses from the ice maker ( water in door and icemaker) than push the water in door feature and see if the water goes into icemaker. If it does not than replace inlet. If does and temp in freezer is below 6 degrees replace icemaker.
If you need further assistance please comment me back.
WHAT IS THE PRICE OF THIS MCCFFW CHEST FREEZER
spacer.gif 5.5 Cu. Ft. Chest Freezer bbd4a981-a436-4ad6-b98a-7249ef5d1d1a_300.jpg Click to Enlarge Lowest price:$179.00Description:
Food storage will be a snap with this roomy 5.5 cu. ft. chest freezer, featuring up-front temperature control, storage basket and defrost water drain.
Brand: Magic Chef
Category:
Appliances > Refrigerators & Freezers > Freezers > Chest
UPC: 665679002023
Model Number: MCCF5WBX
My freezer is completely covered with frost. What is wrong with the auto-defrost feature?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Just replaced freezer fan a couple days ago. Now water leaking into top shelf of fridge. Could drain be clogged ? Frigidaire model FRT8S6ESBG.
Frozen drain
Ice maker water line and wiring
harness openings not sealed.
Seal water line and wiring harness
openings.
Drain trough not properly formed.
Ensure drain trough is at 90° angle to
back of freezer and that lip is up on front
and ends.
Divider (foam block) frozen.
Replace divider. Check drain trough.
Visit my site, I offer free help and model and parts number search feature. Movies and instruction manuals for most brands. [email protected] click on link below, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Water has stopped coming out of the filtered water dispenser
I just had this same problem and finally figured it out. The water in the line was frozen because my freezer was turned to 6 (note on inside of freezer says recommended temp is 4) so I turned the freezer to 4 and the refrigerator to 3. Next day the water was flowing.
Hope this fixes yours,
Sherry in Pittsburgh
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
