Home | Sony | PlayStation Portable (PSP) Console | Ip adress keeps tim...
Sony PlayStation Portable  Console
Problem for Sony PlayStation Portable (PSP) Console
Ip adress keeps timing out
By ckapple495 on Jul 02, 2009
ip adress keeps timing out
Sponsored Links
Solution #1
posted on Jul 04, 2009
Somewhat Helpful)
jamless
Rank: Master
Rating: 77%, 14 votes
what is happening is that you are too far away from where ever you are conecting to and when it disconects it times itself and then when it can't re-connect in this time it tells you the Ip adress has timed out! So the best thing to do is get closer to there hub or whatever you are conecting to and it shouldn't say it again.
Was this helpful?
Yes
No
Solution #2
Not Rated)
theplaank
Rank: Apprentice
Rating: 0%, 0 votes
bro you will need to change your wep code even if you know the correct one i think it is becuse it allows other devices or somthing to conecte through to change your wep code do the following
1 open internet broser
2 type in the bar (http://192.168.0.1) tuyp tthis in for D-link routers. for Netgear routers type(http://192.168.1.1) as for Belkin routers type (http://192.168.2.1) if you have a diffrent router you are going to have to shearch it on google.
3 ok now when you put in the routers address in the address bar and press enter this parssword/user name thing will pop up you will net to enter (admin) this is the defalt for most routers if you have a difrent router look in the instruction manal or somthing. if you have changed it and you can nto remeber it ring your brodband support.
4 ok now your in your routers seetings change your wep code then reenter the same thing on your psp.
ok some times this will not work and the (ip address thing has timed out) thing will be starting to really **** you off ok this is what you do.
5 go to the start botton in the bottem right coner and click on this then you will need to click on run let it pop up and in the bar type (cmd) this will bring the comarnd promt up if you have vista just go all programs then to asseories then the comarnd promt.
6 once you have ented in (cmd) click on enter and the command promt will pop up in there just type (ipconfig/all) then it will come up with a bunch of informatin on your router.
7 go on your psp and go to ip settings click on manal and enter in the settings that the command promt are telling you.
note: make sure you dont use yuor proxy setings this secrew up thes all way of doing it.
then you are all done and this should work!!!!!!!
Was this helpful?
Yes
No
Popular Solutions for Sony PlayStation Portable
Questions and Unsolved Problems for Sony PlayStation Portable
Do you recommend Sony PlayStation Portable (PSP) Console?
Answer
Answer
the charger does not work - I think the problem is with the female connection on the PSP device -... (More)
Answer
ill be playing a game or listening to music or even just on the home page and then my psp fat... (More)
Answer
Sony PSP Network Connection Problem, not connecting. Wireless Connection is 2Wire box from... (More)
Answer
I cannot get Gran Turismo to play on PSP. Keeps getting stuck at the data sharing screen.
Answer
edihduekhhue8dcjgujdguguebiude87feiut7fgeufyeihewdiyidwhit7usbjwhd7t7eke kniw dhwiuech8e... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony PlayStation Portable ...:
Top Video Game Console Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Video Game Console Experts
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
