Question about Mtd #TB4SC 25CC 4-Cycle Gas Blower
Quit running with half tank of gas left over
Not sure if it had oil in it---does the factory ship them to Lowes with oil in them?
  • 279 Answers
If it is a 4-cycle, it does not come with oil in it. If it is a 2-cycle, you must mix oil into the gas according to the owners manual...Good luck
Posted on Aug 05, 2009
I have a 1999 dodge neon that quits running with a quarter to a half a tank of gas still left in the tank
No tank issue, Might be pressure.. plugged, or filter for fuel
you getting any Engine lights?
Oct 02, 2013 | Cars & Trucks
Starves for fuel, with half a tank of fuel and turning a corner
are you sure the gauge is accurate? next time you get fuel fill it up and check how many gallons it takes from half to full, cutting out on left turns happens when the gas in the tank moves away from the fuel pump screen, that only happens if you are near reserve.
Sep 30, 2012 | 2001 Chrysler Town & Country
Husqvarna 455 Rancher loses power, have tried the following: fresh premium gas with ams oil 2 cycle oil, new plug, cleaned air filter, runs for a little while but starts stalling out after using about a...
check your fuel filter/gas line in tank you could have a crack in your line that in the fuel till it gets below half tank then sucks air through crack, It's a possibility, other than that, check your exhaust port, but sounds like a fuel problem check your fuel tank vent also to make sure it is venting. Good Luck
May 03, 2011 | Husqvarna Garden
I have only used my saw a handful of times and it has always done this since i bought it new at lowes. It wont lube the chain with oil and gets vry hot at the clutch it will go through a tank of gas to a...
I have the exact same saw. I bought it new 6 months ago also from lowes. It has the exact Same problems you are describing. It does not appear to be oiling the chain enough, the Chain is visibly dry,very hot , and dulls quickly. It uses a half tank of oil to a tank of gas. I am Also in search of an answer.
Oct 20, 2010 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Husqvarna 20" 359 wont start. Has spark. the gas and oil were mixed and left in a plastic vented can in the hot sun. came back a day later and half the mixture evaported. Could the gas have evaporated and...
You are correct. Too high a fuel to oil ratio will not asallow the engine to run. Try using a fresh mixture of the correct ratio. It may take a lot of pulls on the starter until the old fuel is purged from the carby.
Aug 23, 2010 | Husqvarna Chain Saw 20" Bar
I have a Briggs and Stratton 7000 watt propane generator. When running this morning after two hours, it quit. It starts back up for about three seconds or so then quits again. I put a new tank on...
does this engine have a low oil shutdown unit on it
if so check the oil level an top it up it could be interupting ignition
be sure your tanks are full and connections are good and tight
brush soapy water around connections to see if any have a leak
if not oil level shutdown , then sounds like a fuel problem
suggest have a gas serviceman take a look
these units can be tricky to solve
Aug 11, 2010 | Briggs & Stratton 15,000 Watt Home Standby...
What grade oil doI use to change the oil?
Your comressor comes from the factory filled with Jenny Synthetic Blue Compressor Pump Oil. This is a 30 weight oil.
The picture below is Ingersoll Rands version of this oil.
I use it and have no complaints about it. It's also a lot easier to get.
That said any 30 weight oil will work. Although I would recommend synthetic because that is what the motor was broke in with.
Hope this helps.
Nov 17, 2009 | Jenny Products Inc AM780-HC2 1.5 Gallon...
Pony 'runs out of gas' with a half tank
also,the tank must have a vent so a vaccum doesn't build up.the fuel cap should be vented.if not replace the cap.
Apr 29, 2009 | Troy-Bilt Pony Garden Tiller
Gas Trimmer will not stay started
Many times with a gas mix, after sitting for a while, the mix separates and gums up the carb. Taking the carb off and soaking it overnight in a parts or carb cleaner and running carb cleaner through the tank and gas lines will cure this.
Jul 02, 2008 | Ryobi 15" Electric Factory Reconditioned...
Mtd #TB4SC 25CC 4-Cycle Gas Blower Logo
101 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
