Question about Hoover F5520 SteamVac Duo Upright Wet Washer
Hoover SteamVac Duo pump is not working
I have a Hoover SteamVac Duo and the Invensys PI pump is not working, I will like to know if it can be easy fix or where can I buy a new pump, I already search the web but the only thing I found was in the UK and is for 230V 50HZ (https://www.vendingspareparts.co.uk/product.asp?urn=8361&c_urn=155). I already opened but din't found anithing broken, all the seals are ok and when the Vac is running I can see the piston going back and forward, but I don't have a clue how it works.
Thanks,
Reinaldo
  • 126 Answers
SOURCE: Hoover self-propelled windtunnel belt pops off
The correct belt is a 38528035. If the belt does not have this number printed on it, it is a generic belt and probably the wrong one. The pulley on the transmission is "convex" because this pulley design keeps the belt running in the middle. (a belt will always try to "climb up a hill") If the motor shaft and the pulley are not aligned properly, the belt will constantly throw off. This can be a result of a bad motor mount (located inside the motor compartment.) The motor shaft end has a rubber cover that absorbs vibration and keeps the motor positioned squarely. The handle could also be loose on the pivot. It is held down by two metal clamps that screw securely to the bottom, holding the handle on to the base and allowing for the handle to pivot backwards. This problem can be difficult to diagnose and I have had many in my shop for repair. It takes a seasoned and experienced repairman to find a solution to this problem, in most cases. The disadvantage I have here is that I cannot see your machines to inspect all the various things that effect the belt alignment. I hope that some of this information will help.
Posted on Jan 20, 2008
  • 3 Answers
SOURCE: hoover f5520 steamvac duo upright wet washer
Your problem is inside the vacuum hose where they have installed a small coiled hose that carries water to the smaller power head for upholstery. After taking this apart I found the inner smaller coiled hose was broken at 2 different places. A very poor design and poor quality material. The hose looked like it was rotted. This could be from old detergent left in the line or maybe the wrong detergent. A job to get it apart but if you remove the three screws that hold the side plate over the electrical you can block that hose off and the machine will work on floors only as the water to the power head is terminated.
Posted on Aug 16, 2008
SOURCE: bare floor attachment for Hoover steam vac with surge clean
According to www.vacuumpartstore.com, for model #'s F5903, 5904, 5905, 5906, 5910, 5912, 5914, and 5915, you need Hoover SteamVac Bare Floor Cleaning Attachment (old # 48417003). You can get it at www.amazon.com for $7.99.
Posted on Jan 07, 2009
  • 294 Answers
SOURCE: Hoover Steam Vac - Brushes not turned, no suction power
The Brushes not spinning is most likely is caused by seized bearings in the turbine, requiring shop service (easy fix). The suction issue can be caused by the standpipe seal missing or lower recovery tank not on properly, on some models missing front panel. I would need more exact model info to assist further.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Posted on Mar 15, 2009
  • 3 Answers
SOURCE: brushes don't work on my hoover steam vac v2
The bearing on the inside of the turbine is rusted. You will have to take the hood of the unit and unscrew the black piece that has to rub hoses going to it. Then take apart the black turbine. Inside you will find 2 white gears and a small 1/2inch bearing. Use wd40 to uncease the bearing. After this put the take pliers and make sure the metal post will turn. Spray wd40 on everything you see including Hoover for making such ****. After this put put everything back together. Now the best thing to do is get some automotive bearing grease and put a large amount on bearing and and other metal parts. Put everthing back together. Clean any hair off the brushes and you are ready. Now the bad news if your gears are worn you will have to replace the turbine. Go to an internet website and the part number will be 91001019. I know all this because I spent 6 years working for Hoover and they found it cheaper to send our jobs overseas.
Posted on Apr 30, 2009
Www.hoover.com
Having never used a steamvac I can only only offer this....pump
and nozzles dispense solution....Is the pump on and working?
Are the nozzles clear? This is all I have...hope it helps.
Regards,
Dennis
Aug 18, 2014 | Hoover F6055-900 SteamVac Maxextract LS...
My hoover steam vac will not dispense the water
I did use my cleaner for along time , started it up and no water would
pump.
Nov 07, 2010 | Hoover F5520 SteamVac Duo Upright Wet...
Hoover SteamVac isn't extracting solution from carpet. Motor runs and the brushes weren't turning at first but do now
That vacuum is fine on liquid extraction but often gets clogged by debris when it hits a solid. It would be better to do the clean with the steamvac then follow it with a wet/dry shop vac to be sure you got all the water. I say this because the vac built into that hoover is way too easy to clog.
Mar 13, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
I have a Hoover SteamVac F5914-900 that I purchased approx 6 mos ago. It just started having the following problem. When I turn the cleaner on there is a sudden burst of solution/foam that emits out to...
Mine has been doing that occasionally, and I have ordered the pump assembly, #H43582003 which several have suggested is where the problem is. This leak, along with loss of solution going to the hand tool, seems to indicate that the pump is not working properly, and is leaking. Something about a float getting stuck, which makes sense, cause it stops leaking when the unit is tilted back a couple inches.
Feb 09, 2010 | Hoover V1 SteamVac SpinScrub Vacuum
I bought a used hoover steamvac duo and I do not know how to use it. I need instructions please?
Go to www.hoover.com then, towards bottom left of the screen, click on "Download Manuals". This opens a search window, in which you can enter your model number and then download a copy of the manual.
If this solution has been helpful, please remember to rate me. Thanks!
Jan 22, 2010 | Hoover F5520 SteamVac Duo Upright Wet...
My hoover steamvac spot doesn't spray
the pump has to prime first ,put water in the solution tank an yurn on and keep the trigger pulled till it sprays.if that don't work take it back
Apr 28, 2009 | Hoover F5505 SteamVac Spot Vacuum
Leaking Hoover Steamvac
Either you have a crack in the tank and it is running down the indise of the handle and going out the bottom, or there is a water line off either under where the tank sits or under the top cover.
Mar 29, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover f5520 steamvac duo upright wet washer
Nov 11, 2007 | Hoover F5520 SteamVac Duo Upright Wet...
Hoover F5520 SteamVac Duo Upright Wet Washer Logo
48 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
