I have a Poulan ,possibly a P3314, hard to pull starter rope, removed plug pulls fine, replaced plug turned off switch and removed plug wire and also disconnected fuel line, same problem, I made sure there was no fuel in the system since there are no reed valves that is not the problem. do you have any ideas?
SOURCE: Poulan P3314 Automatic Oiler
Go to Poulanpro.com and look at a parts explosion and they also have a toll free number that might help. let me know if not and I will research more.
SOURCE: saw does not idle
You have gum in your carbeurator.
You can try a carb. cleaner that you add to the gas. I likve one called seafoam. You add one ounce per gallon of fuel.
Also, you must have a good clean spark plug, and a clean air filter. The spark, the fuel, and the air all contribute to an easy start and a good idle. If you havn't changed the spark plug lately do so, same with the air filter.
SOURCE: poulan model p3314 recoil spring won't go in correctly
You need to pretension it. Remove the pull handle, rotate the spool about 2 revolutions against the spring, rethread the cord and reinstall the handle.
Lou
SOURCE: My Poulan P3314 primer won't take in fuel or push it out.
the vinyl primer button on your carb shoots fuel into the crankshaft space. when you pull the rewind air and fuel in the crankshaft area is sucked into the combustion chamber. when the magneto reaches almost top dead center, the high voltage fires the spark plug. if there is an air leak in the gasket that surrounds the crankshaft, the air/fuel mixture will be way off. flooding will occur and the plug will get saturated. remove the whole back of your engine and clean the mating surfaces. now use high temp permatex and run a bead all around the gasket surface. tighten all the bolts - screws. push the primer button twice and try starting the engine.
SOURCE: P3314 saw will not cough
Here are my Tip(s) on this problem:http://www.fixya.com/support/r6078121-fuel_line_relacement_trimmer_weedeater
Good Luck!
Jim
