Question about Honda Maxus Prosumer MX5223 Pressure Washer
Describe your Honda Maxus Prosumer 2750 PSI Pressure Washer w/ GX & CAT Pump - MX5223 Problem keeps dying
  • 27 Answers
If it has a bowl on the bottom of the carb you float might be stuck, and check if the air cleaner is dirty
Posted on Jul 02, 2009
Fuses every time I switch it on
The load is too big for the circuit you are trying to run it on.
Feb 09, 2014 | Honda Maxus Prosumer MX5223 Pressure...
What is the maximum length of hose I can run with this unit?
Your only limitation is some loss of pressure at the tip as you add sections of hose (most likely not too noticeable with 100'). Less expensive to add water supply hose if possible making sure that the unit gets enough water to keep the hose from collapsing. Good luck with your projects.
Jun 09, 2011 | Honda Maxus Prosumer MX5223 Pressure...
My pressure washer inlet tube does not syphon chemicals. The hose is fine and the strainer is new. Do I have to do anything to the pump body to make it work? It is a 2750psi Honda
you have downstream injection and this means only with low pressure will **** chemical you need a soap nozzle or check your injector make sure is in the right direccion
Aug 24, 2010 | Honda Maxus Prosumer MX5223 Pressure...
Tipe of oil and quantity for 6.0hp 2750 psi (xr2750)
any sae10w-30 will do, 5.3litre of if you prefer 5.6us quarts.
manual is available on this site:
http://www.cpocampbellhausfeld.com/maxus_tools/pressure_washers/mx5223_spec.html
if you find my advice helpful, please do not hesitate to comment and vote4 for me, thanx!
Jul 31, 2010 | Honda Maxus Prosumer MX5223 Pressure...
Pump does not seem to be working, motor runs good, no pressure
Typical causes: hose bib not fully on, kink in supply hose and, #1 - clogged nozzle, particularly after several months of not being used.
Apr 26, 2010 | Honda Maxus Prosumer MX5223 Pressure...
I want to remove the 4gpm pump on my pressure washer.
HI, It sounds like it is just stuck on the keyway as these can be very tight. You need to force the pump of evenly on either side and should come of if patient.
Feb 05, 2010 | Honda Maxus Prosumer MX5223 Pressure...
No water pressure. feels like it is developing pressure in the pump but wont deliver more than a small stream and then enging cuts out like it is bogging down
Sounds like it could be just a main jet bloked in your lance. Please remove the jet and see if you have a good water flow when pressing the trigger.
Feb 02, 2010 | Honda Maxus Prosumer MX5223 Pressure...
Honda Maxus Prosumer MX5223 Pressure Washer Logo
219 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Marvin
Marvin
Are you a Honda Garden Expert? Answer questions, earn points and help others
