Excellent wireless connection but will not connect to the internet. This happened suddenly and since then it was useless trying.
  • 1,684 Answers
It sounds like you have a corrupted DNS file. Here is a like to a file on my web site that should fix you up.
www.ccl-la.com/winsockxpfix.zip
Download this file and unzip it. Run the file on your pc that will not connect. It will reset the host file, clear your cache, and renew your IP address. After it runs it will prompt you for a system reset. After your machine restarts you should be back online.
Buddy
Corporate Computer
WWW.CCL-LA.COM
Posted on Jul 02, 2009
Internet Explorer 8
Are you using a router? Do you use cable internet? Try connecting directly the cable directly into your netbook. If you have internet access then the issue may be with your router.
Aug 24, 2012 | Samsung Computers & Internet
Connected wireless to router, excellent signal, but unable to connect to internet.
connected to wireless router with excellent signal may not means you are connected to internet. make sure your modem provided by internet service provider has signal! connect your computer to modem directly bypassing router. If you are online that means your internet is functional. Then connect modem to your Linksys router and use your wireless to log on to internet.
Your router wireless signal active and excellent means you are connected to router not necessarily the internet. The modem supplied by your internet service provider with active internet should be connected to you router on WAN port!
good luck!!
Oct 07, 2011 | Linksys Wireless-G WRT54G Router
I can connect to my modem, but cannot connect to the internet. Showing I have an excellent signal, but pages on internet will not load.
I have the same problem all of a sudden as well. No problem connected to the router: Connection Manager showed IP address and Connected status but could not load any web pages.
Dec 13, 2010 | D-Link DWA-125 Wireless 150 USB Adapter...
I have an HP Laptop LAN connection will not connect to internet
The wireless modem you are connecting to is protected with a WEP key. You have to get the WEP key or find another wifi hotspot that is not protected.
You can also get a better antenna for your laptop to see if you can pull in another site.
Jul 30, 2009 | Dell Inspiron 1501 Notebook
Wireless connection excellent / won't connect to internet
TRY TO CHECK YOUR CONFIGURATION... OR RE CONFIGURE AGAIN WITH THE CARDS.. MAKE IT SURE THE SETTING IS CORRECT. USERNAME AND PASSWORD YOU ENTERED.
May 26, 2009 | Trendware TEW-432BRP Wireless Router...
Slowed internet connection using wireless router...
Normal!
Wired connections are faster than equivalently wireless connections (from/to the same node) and so your
experienced is quite normal.
Additional nodes divide the original bandwidth and denigrate the performance, which is why one tries to
maximize the original bandwidth (speed in MHz) of the connection to the gateway.
You can maximize your experience by having critical systems wired to the router, and this also provides
greater security than any encryption (which is another brake on your speed) necessary for a wifi
connection.
Make sure you have the fastest possible wifi card in your portable devices to maximize your speed.
Apr 10, 2009 | Linksys Wireless-G WRT54G Router
I have a modem with a wireless card that AOL Broadband provided. It is a Comtrend CT-534 and works great when connected to my desktop. But when I try to use the wireless card to connect to my laptop I get...
If you are getting a connected and excellent signal for your wireless connection then you need to double check the IP address. If you are not connecting to your Internet Service Providers Web server then this would block you from being able to connect to the web. While you are connected to your wireless card click on start>run>type in "cmd". This will bring you to the DOS prompt. Type in c:\ to get to the root directory. Then type in "ipconfig /release, then type in ipconif /renew. This will reconnect your network to your ISP's web server. If this does not work then the problem is at the ISPs end and there is nothing you can do to correct it immediately. You need to call your Internet Service Provider and explain your problem to them. What is happening is that your router DHCP protocol is not providing you with a proper IP address and they can only fix it on their end if the ipconfig does not fix it.
Don't forget to rate this solution with 4 stars.
Jan 14, 2009 | Computers & Internet
Wireless connection
When you get signal strength excellent than at that time goto command prompt by typing cmd in run window and than type the following command at prompt c:\ipconfig / all and this command will show you the status of your all wireless and NIC card ip address. So pls check that wheather u are getting the ip address in the wireless connection or not. and if you are not getting it than
1> first of all connect the wireless router physically by lan cable and than open it in browser by typing ip address of it and than enable the dhcp in it with proper ip address range of you local lan. and than save and restart the router. This might resolve your problem and feel free if any other query.
Jan 10, 2009 | Linksys Wireless-G WRT54G Router
Connectivity
give the different name in different linksys i mean that 1st you given linksys then you second one linksys2 then u get it.
May 27, 2008 | Linksys Wireless-G WAP54G 802.11g/b...
Open Questions:
How to Remove a Virus from Windows PC or Laptop - Toshiba Dataalign As the number of cybercrimes and harmful online attacks are increasing these days, it is difficult to keep ourselves safe while surfing the websites of various sites online. If you are looking for a safe online risk reduction scenario, then trust the tech support of TechFree for Toshiba products. Toshiba laptops and other devices get best maintenance and recovery by the services of Toshiba support. Toshiba support provides best risk safety from online threats and also recovery for broken computers and other peripheral devices. Online threats in the form of viruses, Trojans and malwares that are prevalent everywhere pose serious safety threats to the customer's personal information. Various other regular issues like slow computers, snail speed processing, recurrent screen freezing, frequent and without reason computer shutting down and restarting etc. also prove to be a reason of headache for the customers. In case you want all your tech issues to get resolved while you can be busy doing your usual life stuffs then get in touch with the fabulously supporting Toshiba supprot team. You can get the benefit of 24/7 tech support service at your home or office by calling on their toll free helpline number Call Toshiba +1888784-9316 Technicians of Toshiba support got certified for involvement of advanced technology and still making it available for customers at affordable prices. Also, many profitable deals and offers are provided to the customers. Your search for that perfect tech support with features like reliability and consistency is over with Online Toshiba support Email service technique makes delivery of support easier and comfortable for the customer. Also, professional tech services become more trust-worthy with the 30 days money back guarantee it comes with. Toshiba technicians make efforts of delivering the best customer support along with proper knowledge sharing which helps the customers to get proper understanding about all issues and their resolutions. For tech related support contact tech service team of TechFree on their toll free helpline number Toshiba Customer +1888784-9316 anytime. Toshiba support providing professional and certified tech experts will use the most appropriate troubleshooting to resolve tech issues in least turnaround time.
Aug 22, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
163 people viewed this question
Alun Cox
David Payne
David Payne
