Question about HP L1702 17" LCD Monitor
Hp L1702 Will not power on
I have a Hp L1702 thats just gone out of warrenty. I am unable to power it on. Ocassionally when you press the on buttom the green LED power light comes on for a second and then goes out again.
This is the third flat panel of this model that I know has the problem.
Can you help
  • 5 more comments
  • Anonymous Jan 10, 2008
    I have the same problem where you turn it on and it works for a few second and then the screen goes blank. It has happened to 2 monitors of the same model on two computers.
  • freeradical Jan 19, 2008
    My L1702 refuses to power on even for a nano sec. I managed to open the case and checked the fuse on the power supply circuit board. But the fuse is fine.
  • erlbarker Jul 20, 2008
    same as the statement above what can i do to stop it from going out.
  • Anonymous Jul 24, 2008
    Same problem on HP1702, fixed worked. Mine only had 2 caps, one of which was blown. Easy to get to and easy spacing on the cap leads.
  • 1961tech Aug 27, 2008
    I have resoldered a lot of the connections, in fact, any that I could but it did not improve anything as 1 posting had implied. The inductor coil connections sometimes are not propper... No improvement at all. The green light and the image appear for a fraction of a second and gone only to come back the same way repeatedly.
    Please help!
  • 1961tech Sep 02, 2008
    Thank You Shazmo! This was the cause of my problems as well but with one exception. My monitor had 2 black - 1000uf-16V caps, PCB #'s C922 and C923 for more clarity, that were raised on the ends with minute traces of brown stuff leaking out but also had another similar but not leaking which was C924. It was shorter and purple and was 470uf -16V. C925 was the same but not swelled at all and tested good. After examining all and replacing all 3 bad ones last night, everything is working perfectly! Thanks again for allowing me to recycle another item from the dumpster !! Good Luck to anyone else with a little know how on thinking green!
  • henked Nov 05, 2008
    My 1702 doesnot power up at all, after changing one of its "brown"capacitors.
This fix also worked for me.
The caps weren't blown but were pushing out slightly on the top ready to pop.
C922, C923 and C924 were replaced and the monitor works fine.
Lets hope HP used a string of bad components that caused this failure and that it is not a design issue which will cause this failure again down the road on my monitor.
Thanks for the help.
Posted on Sep 11, 2008
Easy peasy, if you open the case up and take out the circut board with the thick brown and blue wires in it, look for the square thingie with yellow tape on it.look for four round capicitors, (little black drums) look at each one. if one is raised and probably has brown stuff comming out of it then its bust . just replace the broken one. i got one that was going to be dumped in work and did some research. but thats all thats wrong.when i first got the monitor the green light came on for a second and the monitor switched off. when i found out what blown capicitors looked like i took the gamble of taking out my soldering iron. happy hunting. if any questions
Posted on Apr 02, 2008
I have a similar problem with the same monitor.  I think it is because I used to have it set up for 2 monitors.  Now every time I try to turn it on it goes to sleep right away but works fine on my other pc.
Unfortunately, I don't know the solution but I am also looking for a way to fix my problem...
Posted on Jan 01, 2008
Answer was correctfor my HP1702, Mine only had 2 caps (1000uf 16V) one of which was blown. Easy replacement and I am not a great solderer, leads were far apart and easy to get to.
Posted on Jul 24, 2008
Problem is in 1000µ 16v capacitors as said before there is four of them on the board. Best way to fix -> change them all to new ones.
I have fixed three of these monitors and all had this same problem.
Posted on Apr 18, 2008
HP L1702 17" LCD Monitor"going sleep"
test monitor with another signal cable, if not ok change your adc (analog to digital converter or main) board.
Aug 19, 2015 | HP L1702 17" LCD Monitor
How to hard reset a WM8880 laptop
Power the unit off (holding power buttom) and selecting Power off, then simultaneously hold the "back" button and on button for about 8 seconds. When the android icon appears, press back buttom, in the menu select wipe data/factory reset pressing the home buttom and then press the back buttom, in the next screen select "yes delete all user data" pressing back buttom, and in the next screen select "reboot system now" with the back buttom and wait.
Nov 29, 2014 | Computers & Internet
I unable to find hp director for scanning icon in my computer but printer icon is there. now i want to scan bur i am unable . pl help.
You might try this. Lay the paper you want to scan on the glass and press the physical buttom labeled scan. Wait for a min but on mine director will pop up on your computer screen. Its not a fix, but it'll let you scan what you need.
Feb 04, 2011 | HP PSC 1315 All-in-One Printer
I have hp laptop #hp g60_120us . around 2 years. lastnight. i hibernate it .went to do something, the laptop not working anymore when i press on. the screen showing lot of red retangle sqaure from top...
- Shut down the laptop by pressing down the power button. - Remove the power input to your laptop. - Remove the battery and put it back after about 2-3 mins
Please report your observation
May 18, 2010 | HP G60-120US Laptop
Hp dv9000 switches on to show coloured lines on screen.
My first guess is that the screen circuitry has gone bad - although fixable. Use an external monitor to verify this. If the external monitor is fine then the screen circuitry is bad, if the external screen shows the same problem then the video chip or associated circuitry has gone bad. My company fixes these all the time.
Jul 28, 2009 | HP L1702 17" LCD Monitor
HP L1702 lcd monitor power on then goes off
There are 8 caps that need to be replaced on these monitors.
2x1000uf 16v
6x470uf 10v
It is an easy repair if you know how to do it. If not, then your local TV repair man can do it fairly cheaply and quickly.
Mar 31, 2008 | HP L1702 17" LCD Monitor
The monitor brings a 10cm thick line after powering on
this type of problem is may be due to the magnetic appliances near by ur monitor such as speakers etc... try keeping the speakers away for some distance and then in the monitor there will be one menu just press that and then go to degauss and give degauss... your problem will be solved...
if problem persists then may be the tube is gone just visit the technician ... he may tell u that he must recharge the tube....
Feb 10, 2008 | HP L1702 17" LCD Monitor
HP L1702 17" LCD Monitor Logo
2,461 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
