Question about Jenn-Air JGS8750 Gas Kitchen Range
Jenn-air gas range JGS 8850 ADW has F1-8 error code but usually self corrects not seems to not be correcting what do i need to replace
    New Friend:
Most of the time the solder on the control board brake because of the heat from the oven. Just remove the board and redo all bad solder. Sp?ciale the connector one.
Sorry for my english
Les soudure sur le board de control brise par la chaleur degager par le four. Il suffit de refaire celle-ci pour regler plusieures probleme en particulier celle des connecteurs.
Posted on Apr 12, 2016
VANMAN69
  • 23 Answers
SOURCE: F1-1 error on Jenn-Air Range
if it is the stove that is in the picture the fault codes are in the door under the oven door.
Posted on Jun 02, 2007
jsrock516
  • 5911 Answers
SOURCE: jenn air jgr8850adw won't bake
This usually is an indication of a bad igniter. If this is the standard glow type igniter, it could appear as if it is working, but may not be providing enough current to open the gas valve. This is a safety feature on gas ovens. The gas valve requires a current potential of .32 to .37 amps through the igniter before it will open and allow gas to flow. This prevents gas leakage if the igniter fails to light. The reason your broiler works is probably due to the fact that the broiler gets used less and the igniter is probably in better condition. You can test this theory, if you like, by swapping the igniter for the bake and broil burners to see if the symptoms change. Or, you can simply just replace the bake igniter with a new one. Make sure you secure the power before attempting, though. You shouldn't have to turn off the gas for this. Chances are that's all it is. I hope this helps you.
Posted on Jul 14, 2007
VANMAN69, I have looked in the door under the oven door and can not find the codes. Any more suggestions? I have had a repair man come and replace my control board but I am still getting the F1-1 fault code and when using the oven I get the F3-1 fault code.
Posted on Aug 02, 2007
Oceti
  • 51 Answers
SOURCE: Jenn-Air Gas Range
F1 is a bad power relay board.
F8 is a shorted meat probe alarm (probe jack or the harness to the probe jack)
Posted on Jan 18, 2008
aborcass
  • 2651 Answers
SOURCE: Jenn-air gas electric grill range
any power to unit at all?? clear, start, clean ,button?? what happens when you push them??? clock on?what happens when you try to set to clean again??? it should activate hte door lock latch at which point cancel and it should reset itself. with any luck! what happened thankgiving how was it fixed
Posted on Mar 14, 2008
Jenn-Air Range displaying Error F1-8
Did not find an error code "F1-8"
I did find these. Seems that about everything that can go wrong with a Jenn Air is related to the clock.
https://www.repairclinic.com/RepairHelp/FaultCodes/26/Range-Stove-Oven
Sep 22, 2017 | Jenn-Air JES8850AAS Electric Kitchen Range
Front burner does not light. Turning gas on and the gas does not seem to have a lot of pressure.
If the rest of the burners work correctly, then you have a clogged burner head. You can try to clear it out and if that doesn't work you will need to replace it. Here is the kit to order.
Oct 16, 2013 | Jenn-Air PRG3010 (NP) Gas Kitchen Range
Oven getting up to temperature very slowly, sometimes not at all it seems. lower igniter comes on right away but gas doesn't turn on sometimes for up to 15 minutes or more
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Sep 29, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn Air JGR8750 - Oven heats _very_ slowly; take 45 to 60 minutes to heat to 450ºF. I can hear faint ''whump whump whump'' from the oven as it heats. Purchased in 1998.
Sep 28, 2010 | Jenn-Air JGR8750 Gas Kitchen Range
Oven inop error code f7
This is your ERC ( electronic range control) that has gone out on this unit. We are factory authorized Jenn-Air service and parts supplies and we LOVE the Jenn-Air brands. Our house is full of Jenn-Air appliances, also.
Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we can next day air the correct part to you first thing Monday so you can start cooking for the holidays!
We answer our phones from 7 AM until 9 PM CST from Monday through Saturday and look forward to helping you to get cooking again.
Thanks, Ella
Nov 22, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Jenn air gas/elctric slide in range self cleaning does not work
iF THEY ALREADY REPLACED THE EXHAUST FAN , MAY WANT TO REPLACE THE HI LIMIT THERMOSTAT AT REAR OF OVEN... THE THERMOSTAT MAY RESET AFTER 20 MININUTES OF COOL DOWN..
Apr 02, 2009 | Jenn-Air JGS8860BDP Stainless Steel Gas...
Jenn air range stove jsg8750 have a f1-7 error code
Hi there...
Error F1-7 means --
Replace touch pad or clock assembly (also called the ERC).
Good Luck!!
Jan 29, 2009 | Jenn-Air JGS8750 Gas Kitchen Range
Error code
I have a jenn air range gas cooktop electric oven model # svd48600b the convection fan will not turn off and when you attenpt to use oven an error code F-3 appears and beeping sound what part is defective?
Aug 02, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Jenn-Air Gas Range
Dec 19, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
Jun 01, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
Jenn-Air JGS8750 Gas Kitchen Range Logo
401 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
