Question about Hampton Bay 52 In.Carriage House II in Polished and Satin Brass Finish Fan
Light works, fan does not. Fan motor has low hum but blades don't turn
  • 999 Answers
How old is this? The motor has failed windings and carries a pretty long warranty I believe 25 years was the norm? eric
Posted on Jul 02, 2009
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: ceiling fan
there is a run capacitor inside the motor thats probably bad but 99% of the time its just not worth fixing these things unless you really like the style and color. Good Luck
Posted on Apr 27, 2006
Richie_asg1
  • 1036 Answers
SOURCE: hunter ceiling fan
Motors work with magnets. These may be permanent, or more commonly elecromagnets. These are the rotor, and the field magnets. Another type of motor just uses a field magnet and iduces flux in the rotor.
Either way, it sounds like one of the main coil windings has either burnt out or mechanically broken.
If you want to remove it and test the coils with a meter (check resistance of each) this should show the fault.
If a coils burn't out. it's scrap .
Posted on Jun 11, 2008
  • 7 Answers
SOURCE: Blades will not turn
The motor probally damaged while you are moving the fan to the new house.
Posted on Jul 06, 2009
  • 16485 Answers
SOURCE: Aloha Breeze pedestal fan blades won't turn, but motor is humming
remove protected cover and with wd-40 or oil spray lightly behind the blade at the base oil up the bearing turn blade by hand till free put back and test the bearings get sticky from the dust
Posted on Sep 12, 2009
Fan just quit working one day. Nothing happens when I turn the light switches on and off.
Is it powered thru a light switch? Sometimes those do just quit. You can remove the old switch & replace it. Go to Lowe's/Home Depot, the switch itself is fairly inexpensive (probably less than $5). Remember to turn off the breaker to that room/switch before you do anything. The installation itself is simple - just wire + to + and ground it. Did you notice any kind of noise/smell before it stopped working? If the motor is burnt out - just replace the whole fan (unless you feel like tinkering with breaking it down & finding a replacement motor). Sometimes the lite switch on the fan itself will go out - parts for that can be found at about any larger hardware store, but sometimes that's not an easy repair (depends on what type of lite kit is on the fan). However, if that were the problem -it would not cause the blades not to turn, it would only keep the lights from coming on. Try replacing the light switch that turns the fan on/off first (the one on the wall, not on the fan itself) - hopefully that'll solve it for you. Good Luck.
Jul 13, 2011 | Hunter Fan 21623 Concert Breeze Ceiling...
Fan won't run at all.
If you plug it in and turn it on, does it "humm".
If so, it is getting power. It could be the blades are stuck on something: do they turn by hand?
The motor could be dirty also, is the blade hard to turn?
It can be repaired by Vornado, or you can dis-assemble the motor and clean it.
Dec 24, 2010 | Vornado Circulating Fan
Motor can be heard going but the blade wont spin!!
There is usually a pin in the shaft of the motor, that corrosponds with a slot in the fan blades, it sounds to me like either (a) the pin somehow came out, or (b) the slot in the blades is rounded. Hope this helps
Jul 15, 2009 | Patton 20" CVT Performance Air Circulator,...
Jul 06, 2009 | Casa Vieja Probe Brushed Nickel Ceiling...
Hampton bay fan noise
The fan does not need to be oiled. The bearings are what manufacturers described as "permanently-sealed", which means that they're designed such that they don't require oiling. The manufacturers recommend against oiling, and if you really wanted to do it, you'd have to be an expert, because there is some very complex disassembly to be done, which requires specialized tools.
HOWEVER...
The problem is not related to oil. A lack of oil does not produce a hum. If a fan's bearings are low on oil, the sound generated is a scraping or brushing sound. A hum, on the other hand, is an electrical sound. All fan motors hum to some degree -- the cheap made-in-China ones, like in your Hampton Bay fan, hum more than others. There are some steps you can take to reduce the hum:
* If you are using the fan with a solid-state control (i.e. a dimmer), that will cause the fan to hum. These controls are dangerous when used with fans, and a fire can result. You should have a qualified person remove the switch immediately and replace it with either a regular on/off switch OR a discrete-speed (i.e. 3-speed or 4-speed, rather than variable-dimmer) switch. Specially-designed ceiling fan switches such as this are available at your local Home Depot or Lowes. You could also use a remote-control system.
* If you have a remote control or other speed control system, make sure that the pull-chain speed control on the fan is set to the "high" position (highest speed possible) and left there.
* Make sure that all the screws are tight -- this includes screws which hold up the fan's mounting bracket, hold the blades onto the fan, and hold any applicable glass onto the light kit.
* Even if you don't have a speed control, the motor will still produce an electrical hum -- and the blades, which are physically attached to the motor, serve as mechanical amplifiers -- they take the tiny electrical hum and amplify it just like the big brass funnel speaker on an antique gramophone (record player) takes the tiny vibrations of the needle on the record and amplifies them to a comfortably audible level. High-end fans have a rubber flywheel attached to the motor between the blade holders and the motor unit -- and since rubber doesn't transmit vibrations well, this effectively deadens the sound. Your fan doesn't have one of these, but you can effectively replicate the noise-dampening effect by putting rubber washers between where the blade holders touch the bottom of the motor AND between where the screws which hold the blade holders onto the motor, meet the blade holders themselves. This will completely remove the path along which the sound vibrations can flow to the blades, and thus your hum will stop.
I hope this helps you! If you have any other questions, or need clarification, please ask!
Jun 14, 2008 | Hampton Bay 24002 Ceiling Fan
Hunter ceiling fan
Jun 11, 2008 | Hunter Low Profile III 20807 Ceiling Fan
Fan doesn't work, blades don't turn
Jump out the switch first that will show which is not working
Dec 21, 2017 | Vornado Standard&Full Size Air Circulator...
Celing fan making noise, how to oil
HOWEVER...
Apr 30, 2008 | Hampton Bay 24002 Ceiling Fan
Ceiling fan
There's a rubber circle that is the damper between the blades and the motor shaft that rotates. The circle has spokes connecting the outer ring, which the blades screw into, to the inner ring which attaches to the shaft and holds it. If the spokes break you get the symptoms you describe, motor hums but no rotation, but blades can turn manually if you hand turn them them. If this is the case you need to remove and replace the blade mounting ring/damper. (About 25 bucks online)
Apr 27, 2006 | Hunter Sontera 52" Ceiling Fan with...
Hampton Bay 52 In.Carriage House II in Polished and Satin Brass Finish Fan Logo
658 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
