Question about Kenmore Refrigerators
Kenmore freezer won't make ice
I had an ice maker that didn't work and was told that it was most likely the motor so I took it out and found that the mold and heater assembly looked pretty rough as well, so I replaced both the mold and heater assembly and the motor assembly. When I got it all put back together and installed, I turned it back on and nothing happens. No fill or cycle at all. Is there a reset switch or something to get the water flowing again? Or do I need to manually fill it up first to get the cycle started?
  • kylep756 Jul 02, 2009
    The part number for the fridge is 106.53634300. I can't find anything for the ice maker as a separate unit. It is the one with the ice bin on the door.
  • Kenmore Master
  • 4,655 Answers
If you did not replace the thermostat then it is possibly your problem The thermostat tells the ice maker to do every function.Sears uses a model number that is different than anyone. For example 213.546987 should be listed near floor and behind fresh food section door above the kick plate.Get me that number and I will be able to look at the parts for your ice maker. Sea Breeze
Posted on Jul 02, 2009
Kenmore Refrig Model # 75922400 top Freezer. Freezer is freezing really good but frig is around 46 - 48 degrees at coldest setting. We discovered ice on vents in freezer and thawed them out with hair...
Sounds like a defrost failure.
Look on the back wall of the freezer from the inside.
If it is covered in ice your defrost system has failed.
Also check the fan motor in the freezer.
If it is not running it must be replaced.
Feb 24, 2011 | Kenmore 18.9 cu. ft. Top Mount...
Hello, I have a Kenmore refrigerator model 795.73264300 and I've been told by a service tech that I need a freezer fan motor replaced along with the ice maker. Total cost is about $400. I've been on...
Go here:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Model-79573264300/0582/0166000?pathTaken=
It's the Sears Parts site for that model refridgerator.
They list the fan for $8.10 and you can replace the whole ice maker for about $120
Looks like you take the shelves out and then the bulb, then the top panel in the back of the freezer to acces the fan
Good luck
Dec 24, 2010 | Kenmore Refrigerators
Ice maker issues - what to do next?
I have not found Kenmore to do the best with the icemakers; however, you want to make sure that the lever on the side was replaced properly. They have a slot that they need to go into. The other thing that is important is to see if the motor is running on the ice maker. It could be at fault, but if that is the case those units usually are better off replaced as a whole, which runs around $200. You will probably get them cheaper through an appliance dealor rather than going through Sears and there probably is one in your yellow page section of your phone book...hope this helps.
Oct 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
3 year old kenmore top freezer, won t defrost ''no ice'' buildup behind the freezer panel I removed. no clicks on the defrost test, same result for method #2. The ice maker works ok when freezer is at...
your freezer had a heater and a bi metal behind its pannel. if they won't work properly than you would face problem like this.......contact your service authority. it cannot be solved by your own
May 14, 2009 | Kenmore Refrigerators
Error message on fridge "er ff"
Error code Er FF indicates that the evaporator fan has failed, or at least is not sending a signal to the electronic controls. Open the door and see if the evaporator fan is running inside the freezer compartment. If that fan stops, then no cold air will be sent to the refrigerator compartment and it will warm up. Possible causes include bad motor, bad connection, bad electronics.
Jul 20, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite 106.54619300 Ice maker just stopped working
sounds like the moter is burnt out and you need to replace ice maker try ebay
Apr 04, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Coldspot Ice maker is not working on our side by side refrigerator
I have a kenmore coldspot side by side model # 106.53662300.
The ice maker red light is blinking and it has made very little ice in the last 24 hours. What do you think the problem is?
Jan 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Side by Side Refrigerator Ice Maker Not Working
A couple things to check here. First see if there is ice in the tray. If so chances are the ice maker will need to be replaced however these are very reliable ice makers. If no ice in the tray pull up on the ejector blade (don't worry you won't break it) turn clockwise to start the ice maker thru a cycle. The ejector blade is the long white bar with fingers on it that run the length of the tray. Once it completes a cycle it should fill with water. If no water then either the fill tube is frozen over and will need to be defrosted or the water valve is bad.
Sep 30, 2007 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Refrigerators Logo
91 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
