Question about Nespresso C190 Titanium Espresso Machine
Krups FNA2 Nespresso machine
I have a Krups FNA2 Nespresso C190 Espresso machine, which is now a couple of months out of warranty. About 1 week ago it started switching its self off when making espresso - it wont stay switched on for more than 1 or 2 seconds before switching off. I have tried to descale it with vinegar but that hasn't helped. The shop I bought it from told me I needed to buy a new one. Its only just over 1 year old and doesn't get used much, only at the weekends, so should be able to last longer than this. Any ideas or suggestions?
Noggin
  • 944 Answers
SOURCE: Krups Nespresso FNA2 coffe/cappucino machine
First thing to try is a descale. Run the machine normally using it (as if making a cup of both types) a couple of times with a 50/50 mix of white vinegar and water. Leave the machine off but uncleaned overnight. run a couple of cycles with just water, and if there is still a slight vinegar taste then run a cycle with a teaspoon of baking soda in water, then flush with just water again. If this doesn't solve the problem, try again with 75% vinegar. If still not working, there is either a control board problem (may be solveable), or the valve/solenoid that stops/allows the water is sticking, almost certainly solveable by taking that apart and cleaning/lubricating. Definitely solveable by replacement. Let me know what you get after a descale if no luck. Hope this helps :)
Posted on Aug 20, 2007
SOURCE: water leaks from the top of the C190 Espresso Machine
in our case the problem was fixed easily: the metal piece in which the capsule sits is screwed in on the top. When it became loose our machine started to leak water from the top. So the problem was solved by retightening it!
Posted on Feb 02, 2009
  • 3 Answers
SOURCE: No espresso coming out.
The problem with the XP4050 is the two safety valves that the water goes trough on its way to the coffee head. They are plastic and some of the parts will just become brittle because of the hot water and the contamination they gather. With my XP4050 they just broke and parts of it were in the rubber tubes that go to the waste tank.They are also very cheaply constructed compared to the more robust parts of this machine. The water to the hot water/steam head does not have these valves and has a completely different routing. I am currently trying to fix the machine with just one valve and parts of the two valves that are still good. Fingers crossed....
Posted on Jul 20, 2010
micromatikal
  • 2777 Answers
SOURCE: I need the instructions for
It is fairly complicated, but luckily I found the manual for the device that goes into detail on exactly how to descale it. You want to go to page 8 of the manual. I will provide the manual at the end of my answer here...
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
http://www1.nespresso.com/precom/sav/pdf/HD_RO_en.pdf
Thanks
Tim
Posted on Oct 13, 2010
SOURCE: Recently my Krups 4050 espresso machine starting b...
I have the very same problem and cannot find any solution for that. Any suggestion from you out there?
Thanks,
Peter
Posted on Apr 02, 2011
My nespresso c190 makes coffee watery
Have you decalcified the machine? They need descaling about once every year - 18 months, and one MUST use the Nespresso Descaling Pack, which is designed for all Nespresso machines. I can't understand why the capsule holder is tight, unless you have used so-called "Nespresso Compatible" capsules, which can cause this. The machines are designed for use only with genuine Nespresso capsules.
Feb 28, 2015 | Nespresso C190 Espresso Machine
How do I descale my Nespresso C190 coffee machine?
You can buy a descaling kit from your Coffee pod supplier, but I simply use a mix of half water and half white vinegar - run this through your machine and it will descale perfectly.
Sep 29, 2014 | Nespresso C190 Espresso Machine
Krups FNA2 doesn't draw water!
If it sounds like a pumping noise but louder then it may mean that the pump is bone dry and needs to be primed. You need to find an imaginative way to force water into the socket that the tank engages with. A clear hose of the correct size with water already in it and then press the button and blow into the other end of the pipe. Once the valves are immersed in water it should start to function.
Dec 18, 2013 | Krups Coffee Makers & Espresso Machines
I need to know if the Concept FNA2 41 Nespresso machine is double insulated or not. I am Portable Appliance testing in Queen's University Belfast, and none of the metal parts of the aforementioned is...
here , double insulated machine only have an active and a neutral pin in the power cable
you can test by testing for continuity between the active and the metal and neutral and the metal
if it has a 3 pin plug consider as not double insulated
Sep 11, 2017 | Nespresso C190 Espresso Machine
Krups nespresso not heating water
That is a faulty thermostat or a defective control board.
Contact Krups and have the machine replaced.
Contact - Krups International
Feb 17, 2009 | Coffee Makers & Espresso Machines
Machine won't work
This machine does not have that muck electronic, the button switch has probably a short, and must be replaced.
As said the machine is Krups, and therefore should be covered with one year warranty. Call the number listed on the user manual, or find contact from websites below:
Coffee & Espresso Machines - Small Domestic Appliances - Krups
Home - Krups UK
Jan 03, 2009 | Nespresso Aeroccino Automatic Milk Frother
Water leaks from the top of the C190 Espresso Machine
Oct 28, 2007 | Nespresso C190 Espresso Machine
Aug 20, 2007 | Nespresso C190 Espresso Machine
Nespresso C190 Titanium Espresso Machine Logo
424 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
