Question about GE 25952 Cordless Phone
When I put either phone on the main base, the "charge/in use" light does not come on and when I push the "talk" button, if just gives two beeps. I have tried cleaning all the contacts. Also the page button does not work. The charge light does come on when either phone is put on the other unit. Any suggestions?
  • rose86420 Jul 02, 2009
    Changed the transformer and the phone was fixed! Thank you so much!
  • 27 Answers
Possible the tranformer for the plug for the wall is bad swap it with the other and check it that might be the issue.
Posted on Jul 02, 2009
Why is there a beeping noise when I press talk?
When you press talk, there should only be 1 beep. This is to confirm that the Talk button has been pressed. If it beeps multiple times, this means the phone is not communicating with the main base station, or the battery is low or dead.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Apr 10, 2011 | Uniden Lands Phones
Hell There, We have a "legacy" GE hands free kichen" phone model: 26730GE1-D Yes, I know it's ancient, BUT I did put a fresh, brand new battery in last week and it rings, when piucked up reads out...
Hi.
The calls are being placed on waiting, try using Flash button before using Talk.
Test the chance on a different phone line , the most likely is that the phone is defective.
If the phone is working on a different line, then it is a configuration problem, and the phone is waiting for a manual call transfer from a different phone in your network.
Try using Flash button instead of Talk, this will answer the call if there is a waiting service programmed.
Try testing with no other phone connected.
Finally try resetting the phone, use procedure below:
  • 1. Make sure the phone power is ON (but not in the “talk” mode by pressing the PWR button.
  • 2. Use the arrow buttons to scroll through the main menu until Handset setup is flashing.
  • 3. Press the SELECT button. A second menu shows on the display.
  • 4. Use the arrow buttons to scroll to Reset phone.
  • 5. Press SELECT.
  • 6. Use the arrow buttons to change NO to YES.
  • 7. Press SELECT to confirm.
If after resetting the calls are still being placed on hold, then again, the phone may be faulty.
Here a manual for your phone.
Jan 15, 2010 | Cell Phones
Uniden XS 1210 cordless phone won't connect to base unit
try connecting both phones via the base that is working and see if they recognize each other. Let me know if that works.
Jul 21, 2009 | Uniden Cordless Phone
Ringer off displayed on base. How do I turn it back on? Just called myself from my cell phone and phone actually did ring.
Thanks for giving me the opportunity to help with your problem.
The "ringer off' message on the base display is referring to the ringer on the "base" unit not the phone ringers. Your phone handset(s) will still ring even when the base ringer turned off.
To turn the ringer on the base back on press and hold push the ^ symbol on the base until it beeps two times, To turn the base ringer off, press and hold the v symbol until the unit beeps.
If my information has proven to be of help, please give me good rating. Thanks for using FixYa!
Jan 27, 2009 | Panasonic KX-TG5632 Phone
Model 25922 5.8 GHZ Cordless phone with one main phone and two extras
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ge Telephone Solutions
Handset can not link.
• If any handsets become inoperable, place it on the main base cradle for 20 seconds to re-register.
No dial tone
• Check or repeat installation steps
• Make sure the base power cord is connected to a working electrical outlet.
• Make sure the telephone line cord is connected to the base unit and the modular phone jack?
• Disconnect the base from the wall phone jack and connect another phone to the same jack. If there is no dial tone on the second phone, the problem might be your wiring or local service.
• The handset might be out of range of the base. Move closer to the base.
• Make sure the battery is properly charged (for 16 hours).
• Ensure the battery pack is installed correctly.
• Did the handset beep when you pressed the TALK/CALL BACK button? Did the in use indicator come on? The battery may need to be charged.
http://www.home-electronics.net/ge/pc/IB/25922GE2_IB.pdf
Sep 02, 2008 | GE 26998GE1 Cordless Phone
Uniden Cordless Phone Model DSS7855. frequently fails to connect to an incoming call, with 'out of range' indication. The phone is less than 1 meter from the base station.
The handset/base keeps a record of who it’s registered to. The base also keeps a record of how many handsets are registered to it.
Using the de-register function on the handset deletes the handset from the base (decrements the count) and deletes the base info from the handset. All this requires that the base and handset can communicate with each other.
To remove the base data from a handset when out of range of the base, press and hold the ‘end’ button and the ‘#’ button simultaneously until the phone beeps. It will now be de-registered from the base.
However, the base will still have this handset in it’s record.
To de-register all handsets from the base, remove power and the base handset. Press and hold the ‘flash/find hs’ button while applying power. Wait for the beep and release the button. The charge light will now flash. Sit any handset in the cradle. When the flashing stops, all handsets are inhibited from connecting.
However, the handset still appears to be connected to the base unit. Pressing talk will give an ‘Unable to connect’ message. To re-register the handsets to the base, you have to de-register the handset first with the two button method.
Of interest, pressing ‘*’ and ‘#’ on the handset while reconnecting the battery is suppose to reset the handset. Doing the same on the base unit puts you in some sort of diagnostic mode. Press speaker to exit.
Aug 21, 2008 | Lands Phones
Main base not charging
no you need a new battery. Hope this helped you
Nov 18, 2007 | GE Thompson 25901EE1 Cordless Phone
Motorola 580 handset not working
My handset does not connect to the base station. It flashes momentarily, but does not find the base. The base station has a humming noise when the phone line is disconnected and the talk button is depressed. Hum is also present when the phone line is reconnected. The problem was resolved by replacing the 9VDC power supply. The hum disappeared and the handset immediately connected to the base.
Oct 31, 2007 | Motorola Mobility MA580 (612572111116)...
Handset wont register
To register the handset:
1. make sure phone is charged
2. hold down the "mute/program button on the phone 10 seconds.
3. you should see a message on the screen that says you need to push the "pager button" on the handset.
4. Push the pager button
Apr 10, 2007 | Uniden Cordless Phone
Not Registered Problem
I had the same problem and I JUST fixed it! First, unplug the power to the main base (answering machine) for 20 seconds. Plus it back in. Put the phone that says "not registered" in the main answering machine. It will say "press the find handset for 4 seconds". Do that. It will run thru a series of stuff and will find the handset. It works! Rich (jambones.com)
Dec 25, 2006 | Vtech IP5825 Cordless Phone
GE 25952 Cordless Phone Logo
154 people viewed this question
Top GE Lands Phones Experts
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
