Question about Fedders AED24E7F Wall/Window Air Conditioner
My Fedders through the window AED24E7F does not turn on. I've checked the outlet and it still has power. I've flipped the reset button on the cord but that doesnt do anything. I just cannot get the thing to turn on, but it was working fine two days ago but now nothing. Any suggestions or is this thing done?
My front panel comes on but nothing else on my fedders window unit
Posted on May 30, 2010
    Problem Solver:
  • 15 Answers
If you can take out the thermostat, check to see that you have power on both connections. If not it may be a bad t-stat. If you can jump the terminals on this with at least a 12 awg wire and it starts, then thats the problem. If you do have power thru the t-stat then it may be the relay on the compressor. It will usuallly look fried if it's bad. Pull it off carefully (with unit unplugged). With an ohmeter, touch one lead to one of the three post on the compressor and one lead to the housing. Do this for all three. If you get continuity on any, the compressor is toast.
Posted on Jul 28, 2009
I HAVE A FEDDERS AIR CONDITIONER MODEL AED24E7F-C THIS UNIT TRIPS THE RESET BUTTON ONCE IN A GREAT WHILE IT RUNS FOR HOURS OR DAYS ON END AND THEN TRIPS. IT TAKE AWHILE AFTER THAT BEFORE I CAN RESET...
The reset button is part of the cord. The cord has built in arc detection. This is a complex circuit that monitors the unit and senses potentially dangerous sparks or arcing inside the internal components of the A/C (motors, switches, etc.) It sounds like the problem is getting worse - as they usually do. Sparking and arcing happen when dirt, corrosion, etc. accumulates and can result in pitted contacts. All of these conditions only make the sparks and arcs worse. Page 1 of the manual (left column) says this:
If the Arc Detection Device has tripped, the
reset button will pop up.
Follow these steps to reset the Arc Detection
Device:
1. Unplug unit from electrical outlet
2. Press the reset button
3. Plug the unit back into electrical outlet
4. Check to see if power has returned to the unit
Testing
You should test the Arc Detection Device
equipped power cord monthly, after every major
electrical storm, or if power to your Room Air
Conditioner has been interrupted.
Follow these steps to test the Arc Detection
Device:
4. Press test button. Unit should trip and reset
button will pop up.
5. Press reset button again for use
If above test fails, stop using the air
conditioner and contact customer service by
calling the following toll-free number:
1-800-332-6658 or email:
customerservice@fedders.com
I hope this helps & good luck!
Aug 30, 2011 | Heating & Cooling
The reset button that came on the cord of my Fedders model AED24E7F-C keeps tripping after a short while. Otherwise the unit blows cold and works fine. I can hit the off button when it is working fine...
Do you have anything else on the same circuit? I have heard about many of these units, not just Fedders, that will not run on a circuit that has another appliance or something that is pulling a lot of amperage. Also, check and make sure the receptacle is not worn and the plug is loose fitting. Other wise, you definitely could have a weak internal connection in the cord. Hope this helps.
Jun 28, 2011 | Fedders AED24E7F Wall/Window Air...
My fridgedaire window unit A/C and heat won't come on. I had replaced an outside light fixture a couple of weeks ago and had turned off the circuit breaker that affected this unit too. Now the unit...
Plug a light into the outlet used for the A/C, if the light does not come on when reset then the circuit breaker that provided the power to the outlet need to be reset or replaced.
May 22, 2011 | Frigidaire FAS257S2A WallWindow Air...
HOW DO I GET MY FEDDERS AIR CONDITIONER BACK TO FARENHEIGHT
Problem with Fedders (A6R12F2A) Air Conditioner
FARENHEIGHT
Nelvie: silverslipper@candw.ky
Aug 20, 2010 | Fedders AED24E7F Wall/Window Air...
Fedders a6xo5f2b-0j leaks inside even though its tilted out?
I have a fedders a6x05f2b and the compresser comes on but the fan does not. What can I do?
Jun 28, 2010 | Fedders AED24E7F Wall/Window Air...
Fedders window ac was running control lights started going on and off ac went on and off then quit power supply is fine. reset does no good
assuming that you have a reset button on the power cord and after pushing the button you dont hear a beeping sound, there's the possibility that your cord is defective. Check it with a volt metter at the end of the terminals.
Sep 23, 2009 | Fedders A6Q10F2B Q Chassis Room Air...
My Fedders plug in AC will not start. Is there a reset button? The model # is A6X05F2B
Hi, yes right on you plug, if not, make sure there's voltage in receptacle, check your plug for any damages, your fan should be blowing, it seems to me you have no power in receptacle, check house panel for trip breakers, or you will have to go further, by removing front cover, with power off, and check master switch, sometimes master switch goes bad, if you don't want to go further call mechanic.good luck.
Aug 04, 2009 | Fedders AED24E7F Wall/Window Air...
Fedders PTAC/PTHP Condenser Fan
What is your model number, maybe we can help.
Greg
Aug 07, 2008 | Fedders AED24E7F Wall/Window Air...
Fedders AED24E7F Wall/Window Air Conditioner Logo
230 people viewed this question
Top Fedders Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Mike
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
