Question about Samsung Televison & Video
Samsung lcd coaxial hook up not working. tv will show a picture when coax is run through vcr and uses rca jacks.
techman
  • 3130 Answers
SOURCE: Sony shows a split screen when DVD plays
If the new player you hooked up is causing the spit screen then you have to go into the set up menu in the DVD player and take it out of prograssive scan.. Its in the wrong fornmat for your TV set. good Luck PS please dont forget to rate this.
Posted on Oct 16, 2006
MikeNJ1964
  • 398 Answers
SOURCE: Need help with PIP
When you go into the menu to choose the PIP source the PIP comes on to confirm that a valid source has been selected. It is normal for the PIP to close when the menu is exited. To display the PIP normally you will need a remote with a PIP button. Most universal remotes today have PIP functions but if you get a Zenith original replacement then you are guaranteed to enjoy the other PIP features such as size, position, freeze and swap.
Posted on Jul 27, 2007
betz73
  • 298 Answers
SOURCE: no coaxial connector on tv
if it has an antana input the two screws on the back, you get an adapter from almost any department store for around 3 bucks.
Posted on Aug 16, 2008
  • 12 Answers
SOURCE: I have an RCA converter box hooked up to an RCA tv
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Posted on Feb 27, 2009
JULIANFIX
  • 975 Answers
SOURCE: How do I repair where the coax cable connects to my 13 in TV
go to RADIO SHACK and get a RF MODULATOR ,this will do the trick , good luck , AJ
Posted on May 22, 2009
How to hook up my atari
It hooks up to the coaxial jack on the back of the tv ( antenna jack )
you will also have to get a Manual TV/Game Switch Box with Coaxial Output or a 300 to 75 OHM matching transformer or a coaxial (f-type) to female rca adapter. You can also just splice a coax cable to the Atari. There are also a converter box that will convert a coaxial input to RCA output ( Yellow,red,white) cabels
Dec 27, 2012 | Atari 2600 Console
How to hook up a cable remote to a Samsung cable box?
    • 1 Examine the back of the your cable box and the back of your Samsung HDTV. Note which cable jacks are of an identical size and color. Those are the ones that can be used to connect the two devices. Samsung HDTVs cluster all the jacks in a single panel near the power cord.
    • 2 Look at the square rectangular boxes labeled "HDMI In." These are for high-definition multimedia interface cables--combination A/V cables that provide the highest possible image and sound clarity. Look at the back of your cable box for an identical jack labeled "HDMI Out." If you see one, connect the two jacks using an HDMI cable. If you don't, you need to use another set of cables to hook up your cable box.
    • Sponsored Links
    • 3 Check for a series of three round jacks labeled "Component In" and color coded in red, green and blue. These are component video jacks, which provide a good HD picture, but not as good as HDMI. If your cable box has an identical set of "Out" jacks, use them to connect the two components.
    • 4 Look for a pair of red and white jacks (possibly connected to a yellow one). These are audio RCA jacks. If you're using component video cables to hook up your cable box, you will need to hook these two up as well: Component video cables don't provide sound. Any cable box that uses component video cables should also have "Out" jacks for RCA audio cables.
    • 5 Find the raised circular jack with a pinhole in the center of a milky white plastic interior. This is the coaxial jack. Samsung HDTVs label them "Ant In." Every cable box should have a corresponding jack labeled "Out" or "Ant Out." If none of the other cable jacks on the cable box match, use a length of coaxial cable to connect the TV to the cable box through these two jacks. You can also use this connection to hook the TV directly to the wall cable.
    • 6 Turn on your TV and cable box, and set the TV to the input jack connected to the cable box. You can do this by pushing the Menu button on the remote, scrolling down to the "Input" option and pushing "Enter." That will let you cycle through the various input options, labeled by cable type (HDMI, component video). Press "Enter" again when you reach the right component, then exit the menu. You should now be able to watch TV as normal.
Read more: How to Hook Up a Cable Box to a Samsung HDTV ' eHow.com http://www.ehow.com/how_4867255_hook-cable-box-samsung-hdtv.html#ixzz2DwgQRtRE
Dec 03, 2012 | Televison & Video
I have an older tv with only a coaxial cable connection on the back, no others. I have a Magnavox dvd/vcr combo that does have RCA connections available and also a coaxial cable connection on the back. I...
First make sure you have the cable connected properly.. on the vcr it should be connected to the OUT coaxial connector.
Second.. the VCR usually has a VCR/TV setting..
Most TV's must be set to channel 3 or channel 4 to output the signal from the VCR when getting the signal via Coax.
So..insert a tape...hit play..tune the tv to channel 3 if you are not getting the playback signal..press the VCR/TV button on the vcr or vcr remote.
Repeat this on Channel 4
Check your cable to make sure the connections are tight.
Finally check your television menus for Input settings..make sure it is set to COAX/ANT
Make sure your VCR's output is not on some alternate output like L1 or L2 (line one or line two)
Best of luck!
Apr 22, 2011 | Televison & Video
The coax input on my tv is broken off how can I connect the cable to it other than the red white and yellow cords which don't have a good connection either I have my dvd player hooked up to hdmi is there a...
the simple answer is no.
but if you have basic cable (coax) you could connect it to a vcr, tune the channels with the vcr-
connect the vcr to the TV with composite video (yellow, red/white)
Apr 13, 2011 | Samsung Televison & Video
CT-32SL 13 antenna busted off, how can we hook up
you can use your rca connectors for your cable if your cable box have rca all you need is rca jacks if you don't have a box and all you have is the coax , then you can use a vcr or a dvd with coax input and rca output "hope i explain this right {" tv-----rca's--2---rca jack output vcr ---coax input ---hook up coax CABLE
May 14, 2010 | Panasonic CT-32SL14 32" TV
Need an RCA Adapter for a TOSHIBA D-VR610KU
If the RF Modulator will convert a coaxial signal to an RCA output signal, fine however, you still need a tuner to select the channel on the TV you want to record. This unit is primarily for dubbing or copying DVD to VCR or VCR to DVD. There is no tuner in the unit to get the cable signal. Try hooking up an additional VCR, that probably has a tuner in it and use the RCA out of the 2nd unit to the RCA in of the Toshiba. Hook the coax to the input coax jack of the 2nd then RCA out to RCA in of the Toshiba. Choose what channell you want to record on the 2nd unit. You may have to choose Auxillary mode on the toshiba the press instant record on the Toshiba. Again, this unit is a Player or Dubber. Not designed to record TV shows without an external tuner. I hope this helps. If you use a 2nd VCR just to get the TV Signal, you won't need the modulator.
Jan 21, 2009 | Toshiba DVR610 DVD Recorder/VCR
Dvd without coaxial, old tv without RCA, passthrough VCR died
http://www.ellies.co.za/v2/index.php?id=492
@ tihis link above you can see it. It takes the av SIgnal Your Sound and picture and convert it RF making it possible for your tv to tune it, its just like tunning into a station. I do sell these for R199 South African Rand excluding postage
Thank you for using FIX YA
Jan 04, 2009 | Televison & Video
Fading dvd picture
DVDs are recorded in Macrovision* format which distorts the video when playing through a VCR. This is an anti recording device to prevent duplication. You can try finding a decoder that connects between the player and VCR to override this
Aug 02, 2008 | Sony DVP-NS575P DVD Player
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
Televison & Video Logo
118 people viewed this question
Jerry Greenberg
Jerry Greenberg
