Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Icemaker will not dispense tho ice is in drawer,
Ice makes, falls into holder, but does not dispense, motor cannot be heard when dispense lever is pressed, water still dispenses...
  • GE Master
  • 4,655 Answers
There 2 possibilities the auger motor is bad or loose wiring connection or the control switch is bad in the dispenser control. I can assist you if you like. Will wait to hear from you, Sea Breeze
SITE=> http://servicepartstec.blogspot.com/
or http://appliancepartsandtechnicalservices.blogspot.com/
Posted on Jul 02, 2009
  • John Tripp
    John Tripp Jul 03, 2009
    You are welcome to email me or call me to get further assistance on the solution. I want to get you fixed. Sea Breeze
    appliancepartsse@yahoo.com 864-812-1887 leave name and number and I will return your call.
  • John Tripp
    John Tripp Aug 12, 2009
    OK
    Capitalistfi By now you should have the manual and we will start by unplugging your model and having a look at the door switch WR23X10161 Door Switch
Icemaker is making ice but will not dispense. continues to accumulate then over time ice in the bottom of the dispenser will freeze
I can think of two possible problems. The ice has frozen together and will not allow the ice screw to push the ice out the dispenser. Or the motor for the ice screw is broken.
1. Shut off icemaker with lever at icemaker
2. Remove ice container (either throw away ice or save in another container).
3. Put back empty ice container.
4. Leave ice maker off for about an hour.
5. After an hour , check if motor is working by trying to dispense ice. You should not expect any ice but you should hear the motor /auger moving.
A) If you do not hear any thing , you need to get your motor replaced.
B) If you hear the motor , mostlikely you had an ice dam which prevented the ice dispense from working..You can turn you icemaker on.
Oct 15, 2015 | Whirlpool Refrigerators
I have a problem with my Kenmore side by side refrigerator model # 106.56926600. The icemaker when pressing the dispenser lever from the outside of the door.I hear the ice coming from the ice maker to the...
Your question is worded in a way that I might not be interpreting it correctly. I am guessing that it is making ice but not dispensing,or going into your glass when you push the lever, right?
So when you push the ice dispenser lever do you hear a "click" like you do when you push the water lever? Push them slowly and listen.
If no "click" is heard then it is most likely the bracket that holds the dispenser switches. It is made of plastic and very prone to breaking over time especially if children are using it. Part# is WP2180226 and be aware that this is under live voltage so if you are not mechanical then do not attempt yourself and please call a pro to fix.
If you hear a "click" then can you hear the motor turning inside? If yes then it could be something as simple as a block of ice stuck in the bucket preventing the ice from coming out. The owners manual recommends to dump the ice to avoid this roughly every two weeks but most people never do.
Jan 27, 2018 | Kenmore Refrigerators
I have a Knmore side by side fridge, model 106.55606400. The ice dispenser have stopped dispensing ice. The icemaker working fine,the dispenser motor makes a sound when lever depressed for ice.Where do I...
One is the icemaker will leak on the auger motor and freeze it up as you describe. If this is the problem the ice will be very solid (hard ice). If this is the case check to see if the tube that feeds the icemaker water is clogged with ice and if so remove the ice and replace the water valve. If not the icemaker may be overflowing, which is still most likely due to a bad water valve.
The other thing that will cause this is an air leak. If it is an air leak the ice will be frosty more like snow than hard ice. But even so it will still cause the auger not to work. If this is the case check the little flap that opens and closes to let ice through the door to see if it is closing properly. Then check the door gasket to see if it is sealing properly.
Turning the temp. down shouldn't help nor hurt your problem.
Jun 08, 2011 | Kenmore Refrigerators
My ice maker makes ice but will not dispense it
When you push the lever to dispense ice, can you hear the motor running? If not, that motor might be dead and not turning the auger, which would be your problem.
If you can hear the motor and auger turning, the chute or the opening in the ice maker might be clogged up with ice. Clean the entrance to the ice maker and the chute in the freezer door and that should fix your problem.
Dec 13, 2010 | GE Monogram ZDI15C Automatic Icemaker
Ice maker makes ice but can't dispense ice
Please try this. Remove your Removable Ice Bucket Assembly which is where the Auger (corkscrew) is located. You should be able to see the Auger Motor Drive Fork which is located permanently inside the freezer compartment... opposite the end of the Removable Ice Bucket Assembly that you just took out. Close the freezer door and attempt to dispense ice... if you can hear the Auger Motor running as you attempt to dispense ice... then the Auger Motor is OK. Dump out all the ice that is in your Removable Ice Bucket Assembly and wash it out in your kitchen sink with warm water. Reach into your freezer and put your hand on the Auger Motor Drive Fork ... you should be able to rotate it CW or CCW...it is a little hard to turn but it will turn. Position the Auger Motor Fork to a 12:00 and 6:00 o'clock position. Now take your Removable Ice Bucket Assembly and position its Receiver Auger Fork to a 9:00 and 3:00 o'clock ....Re install the Removable Ice Bucket Assembly into the Auger Drive Fork. Close the freezer door and again attempt operate the ice dispenser... you should hear the Auger Motor again run as you press the ice dispenser. Note....at this same time the Ice Chute Door in the Freezer Door should spring open so that ice can fall out. Of course you have no ice in the Auger at this time...but it all this works then future production of ice will fall out. Note...Usually the Auger Motor never fails. but the whole thing can get jammed with ice and not dispense. Also, the the solenoid that operates the Ice Chute Door fails quite frequently. Last but not least... if nothing is happening... it is a control board type problem. Hopes this helps! Handy Henry
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
Jul 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Will not dispense ice
i have changed filter and it still is not making or dispensing ice what could be the problem
Mar 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
Icemaker works fine, only dispenses water
make sure that the ice shoot is not clogged up with ice or the in the ice basket where the ice goes through. Sometimes the ice can be stuck together and jam and nothing will come out.
Nov 25, 2008 | GE GSS25JEMWW Side by Side
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
271 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
