Does not advance wash cycle if i advance it by hand it seems to finish as long as I move the dial forward otherwise it sits on initail cycle
  • lucky928 Jul 02, 2009
    it is fridgidaire model glws1749as4
    Thank you for your help
    glws1749as4 it is a fridgidaire, any help would be great
    President:
  • 1,865 Answers
The timer has failed. You can order a timer from http://www.apwagner.com/ Enter your model number, and it will take you to the parts list and prices. It also provides diagram of your washer
Posted on Jul 02, 2009
    President:
  • 1,136 Answers
Hi, Sounds like the timer needs replaced. If you will get me a model #, I can look this up for you and get you a part #.
Vic
  • Victor
    Victor Jul 03, 2009
    Here is the part # you will need for the timer. P#134173100
My washer will not switch from one cycle to the next
I understand that your washer is not advancing and stuck on one cycle. If you provide a Model and serial number, it will be helpful.
Jul 22, 2016 | Washing Machines
I accidentally set cycle to Self Clean instead of Spin & Drain and pushed Start button. Trying to reset to correct cycle. Have just moved and don't have manual on hand.
Most machines will reset if you press the stop button or otherwise end the cycle. If all else fails, un-plug the machine, wait a few minutes and plug it in. Otherwise, just let the Self Clean cycle finish.
Nov 14, 2014 | Washing Machines
The dial on my machine is not moving around by itself cycles still work if I turn the dial
The dial is driven by a synchronous motor which seems to have failed. You might be able to replace the motor itself, otherwise the whole timer will have to be changed.
Mar 07, 2011 | Hoover Washing Machines
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
My Kitchenaid Superba washing machine won't advance to the next cycle. For instance, it will stay on the wash cycle until you push the dial in and manually move it forward to the next cycle.
ck ing the model # it doesn't work but a washer that the timer will not adv . its just a timer failure . replace timer as it is bad .. you will need a correct mod # of the unit to pur timer .. hope this will help **** ..
Dec 23, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Whirlpool AWM1200 washing machine wont advance at certain stages
there is a little motor in the selector switch that moves the dial around.  This little motor is defective and needs replacement.  Sometimes it's sold separately and sometimes you need the whole timer.
Apr 01, 2009 | Whirlpool AWM6120 Front Load Washer
The washer will not move forward automatically. I
it may be the timer or the heater has gone faulty in which it will not advance the timer from the stats. is it heating ? if not theres your answer, if so it may be the stat or the timer itself.
Mar 16, 2009 | Washing Machines
Service M6766 washing machine. works on whatever programme I set it on but just sits on that programme and will wash at say 40 all day and not move through the washing cycle. I have to turn the dial by...
It more than likely needs the control board taking out and looking at. The dial contains a small drive motor, which can give up, or it could be that the water level or temperature sensors ae not working correctly. these give the control a signal to advance when the drum is full enough, and when hot enough. Are you sure the outlet hose is 3/4 the way up the machine? - too low, and it will always drain before getting full enough.
Nov 05, 2008 | Washing Machines
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
