Question about Humminbird Piranhamax 210 Portable
Charger red light on
Charger red light is on. As soon as I plug in the charger the red indicator light goes on "short/reverse" even though I am sure I have the cables correct. The unit will get very hot if left plugged in.
  • 76 Answers
I have heard of one other doing this. Either the charger or the battery is toast. If it's under warranty, call Humminbird.
If not, have a look around for a new battery or charger. They can be had at a good electronics store for not a bad price.
Best of luck!
Mike
Posted on Sep 27, 2009
Charger not working
When the red light is on it is to indicate that the charger is getting power from the wall outlet. If there is a second light that normally comes on Green when charging pay close attention to it when you first plug the charger in. See if it blinks even once then turns off. If it does that means the charger is not seeing any battery voltage at the plug that goes into the chair. If the green light does not blink at all then it usually means the charger is defective. Also most wheelchair battery chargers will not charge the batteries if the chair is to dead to even turn on.
Apr 12, 2015 | Health & Beauty
Battery charger red charging light blinks once then goes out
Do the batteries charge? Are they charged? The green indicator normally is the status signal that the battery is charged and the red indicates that the battery needs charging or is charging. If you plug in a charged battery, some chargers will flash red momentarily then go out. This is an indication that the charger checked the battery (red light) and if the charge is good, the red light will go out. I hope this helps you.
Oct 24, 2017 | Hilti Drills
My Pavilion g6-1b79dx notebook will not charge even with a new battery and charger. The light indicating the charger is plugged in is blinking white
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
http://www.chargerbuy.com/replacement-hp-pavilion-g6-ac-adapter-19v-90w.html
Dec 09, 2012 | Plantronics Hp - Pavilion G6-1B79Dx Laptop...
My baby monitor won't charge - it's not even recognizing the charger as plugged in -- the red light doesn't go on any more??
shut it down and restart and see if it takes the charger ..usually there is nothing that makes the camera behave that way but the charger ..either being damaged or the plug does not makes contact well ..check the wire not to be damaged and try another charger with the same specs ..exactly the same ..It is possible to be damaged if you let it in the plug for a long time ..
If it shows out that the charger is not to blame ..than it is a mater of plug need to be changed cause is damaged ..In worse case just open it and hot wire if you can not get a plug to match ..
Dec 28, 2011 | Samsung Wireless Baby Monitor Camera...
I just bought a KA08 KA09 mini mobile but can't get it to charge. After around a minute the light goes green & red saying okay but I get nothing on the screen? can you advise me?
Use a nokia charger, they fit but very loosely in the little hole next to the usb/charger slot. You lucky mate my charger exploded as soon as i plugged it in! Luckily my old phone was a nokia though.
Sep 13, 2009 | Cell Phones
How do i connect a battery charger
I suppose this is what you want to know
The battery charger has 2 leads coming off it as well as the power lead to the external power source .THE TWO LEADS WITH CLAMPS ON GO TO THE BATTERY THE RED GOES TO THE POSITIVE TERMINAL PLUS SIGN AND THE BLACK GOES TO THE NEGATIVE TERMINAL.MINUS SIGN, THE POWER LEAD PLUGS INTO THE POWER. AND THAT IS ALL THERE IS TO IT..
Sep 10, 2009 | 2002 Mitsubishi Lancer
Can't turn on and a battery sign with a red slush appears
Thee battery is fully discharged. It may take an hour on the charger before this goes away.
Mar 13, 2009 | RIM BlackBerry Pearl 8100
Medion 2310 laptop switches off as soon as charger is plugged in
1. It can be a screw loose inside the unit shorting something out.
2. The AC Port is damaged and needs to be re soldered.
3. Bad motherboard.
I've seen this be a bad motherboard more than not, however it has been the other 2 options from time to time. Most likely need to take it apart and you can see if it's the first 2 and if not than your board is bad.
Nov 10, 2008 | Computers & Internet
Humminbird Piranhamax 210 Portable Logo
195 people viewed this question
Top Humminbird Boating Experts
Mike Marcotte
Mike Marcotte
Phil Walker
Phil Walker
Steve
Steve
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
