Question about KitchenAid Ovens
I have a kitchenaid superba model kebs107dbl7. the control panel is not operating. I have checked the breaker and it is not tripped. I checked the lock system and it is not locked. What else should i check
catriver
  • 878 Answers
SOURCE: Oven stopped working, door stuck in lock position
Tuck, sounds like your Thermal cut out opened on the back of the oven. You will have to get at this in the back of the oven. Part number 4451442. Look it up on the net so you know what your going after. This is a common deal on built ins. Going to need some help in pulling the oven out so far, removing the back panel and changing the TCO...Catriver Post back.
Posted on Oct 21, 2006
barkencoa
  • 3463 Answers
SOURCE: oven does not heat
I would suggest that you check the oven element, it sounds as though it is faulty to me.
Posted on Dec 14, 2008
SOURCE: kitchenaid superba oven
Hit the options button and check that the "Sabbath mode" setting is off. I note that October 20th was a Tuesday but the internal clock year could be incorrect.
Posted on Jan 18, 2009
jumptrout51
  • 3361 Answers
SOURCE: Kitchen Aid Superba Double Oven
Remove the oven from the wall. Remove the rear panel.
The upper and lower ovens have a non-resettable thermal fuse that has blown.
Use a VOM to verify which fuse. After repair use Easy Off, not self clean.
Posted on May 24, 2009
  • 25 Answers
SOURCE: Whirlpool wall oven stopped working after power outage
Ouch...sounds like the control module is blown. Thats the electronic timer. I've known this happen on several occasions. Bad luck!
Posted on Jun 25, 2009
Kitchenaid Superba Gas oven and cooktop. I frequently get a F2: E1 code, which goes away when I reset the fuse. Also, the 1, 4, and 7 touch pads don't work but all others do.
You have a bad touchpad. The ribbon cable is a failure point on all of these whirlpool built ovens. Enter the model number in at this link and see if they make a replacement keypad for your oven: Introducing the Ledgestone Technologies Touchpad
Aug 25, 2016 | KitchenAid Architect II Superba EQ Series...
No heat in oven
Check outlet voltage, a 240v circuit breaker can trip halfway and not be visibly tripped when looking at the breaker panel... 120v will operate the oven controls, but will not heat the elements...
Apr 23, 2016 | Ovens
Free fuse box diagrams
Parts #: W10317343
Substitution: WPW10317343 $145.98 at sears
Parts #: W10354052
Substitution: WPW10354052 $125.92 at sears
Part #: W10317347 front LED board $230 at sears
Many ovens have a bi-metal thermal fuse-also called a thermal limit switch-that protects the oven from overheating. The oven thermal fuse trips when the temperature in the oven gets too hot. After the thermal fuse trips, the oven won't heat. If the thermal fuse trips after the self-cleaning cycle, try resetting the fuse by turning off electricity to the oven, removing the exterior back panel, and pushing the reset button. If the fuse tripped during normal operation, replace it. If the problem persists, the electronic oven control board might require replacement. Reset the thermal fuse after replacing the control board.
Jul 15, 2014 | KitchenAid Ovens
Kitchenaid superba double oven, stopped working everything dead, breakers not tripped. does not respond to any control.
Open the lower oven door and remove the 2 screws on the left and right trim pieces. Be careful not to drop the trim pieces and bend them. Locate and remove the screws on each side of the control panel and push up on the panel gently to get it off the hangers. Behind the control panel is an over heat fuse that has popped. It plugs into a harness on the back side of the panel. This trips/breaks it's connection from either the oven over heating the cleaning cycle or just from age.? Once fuse is replaced you're good to go. Hope this helps.
Aug 23, 2012 | Ovens
The display panel is blank, and none of the buttons work. It had been working earlier in the day, but is no longer functioning. Is there a breaker button?
Hi, Check to see if there are any lights working, such as the ones that come on when you open the oven doors. If there is absolutely no power going to the unit, check the household circuit breaker panel that services the oven.
An oven works at 240 volts so the circuit breaker for it will be a double breaker, similar to the ones
electric water heaters or air conditioning units. It may have tripped. If it is tripped, then
the lever connecting the two sides of the breaker will not line up with other breaker switches in the
breaker panel. If that is the case, shut down the breaker completely and then after about 10 seconds,
turn it back on. If it will not stay on, there is an electrical problem in the circuit going to the oven or the oven itself. Hope this helps. Let me know if your need more help.
Best,
Mark
Dec 30, 2010 | KitchenAid Architect ® II KEBS208S...
We put this unit on self clean and now it wont turn on nor open.
I had the same problem with a Superba wall oven. In my case, the bracket mount for the door lock warped due to the heat of the self clean cycle. We were able to open the door by inserting a coat hanger into the slight opening at the top of the door and sliding the lock lever to the left. It was a pretty easy self-repair - 1) turn off breaker 2) slide oven out 2-3" 3) remove oven front trim pieces 4) remove screws that mount control panel 5) this should give you access to the door lock mechanism.
good luck
Feb 01, 2010 | KitchenAid Ovens
Kitchenaid Superba microwave oven combo close door error
turn off the main power outlet it will work.
Feb 09, 2009 | Ovens
Oven does not heat
Dec 14, 2008 | Ovens
Ovens Logo
123 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
