Question about RCA TH1602 MP3 Player
RCA pearl 1602-A won't register when plugged into USB port.
I have an RCA pearl TH1602-A. When I plug it into my USB port, nothing happens. It used to connect to the computer just fine, but now nothing happens. Please help!
  • 2,335 Answers
When my computer wouldn't recognize my Pearl, these are the steps I followed after downloading the firmware upgrade from http://voxrightnow.custhelp.com/app/answers/detail/a_id/2243/related/1
remove the battery,
start the program,
hold the play button while plugging into usb,
release the play button when the term "initializing" replaces "searching",
click the start button to replace the firmware.
You might want to try leaving the "format data" box unchecked the first time. If that doesn't work and allow you to backup your music, bite the bullet and format the data area.
After I did this, my pearl started normally, and my computer recognized it again. It also fixed my aac-error problem.
Posted on Sep 18, 2009
I can't do that because my pearl won't connect ot the computer
Posted on Apr 27, 2010
RCA pearl th1602-a with new battery will not power on. Old battery will power on, but freeze at pearl logo. Player dosn't power on when plugged into USB of computer
Try a firmware recover. Download the firmware update from the RCA website and install the app. Start the updater and connect the player holding the PLAY button until it gets detected.
This is a similar player with the recovery procedure explained:
Oct 28, 2009 | RCA TH1602 MP3 Player
Tip
How to Fix Your RCA Pearl TH1602 MP3 Player from Freezing at Startup
Does your RCA Pearl TH1062 MP3 player freeze on startup at the Pearl logo?
Whenever your player acts up, the best solution is to reflash/upgrade the firmware.
Download the firmware upgrade from http://voxrightnow.custhelp.com/app/answers/detail/a_id/2243/related/1, and follow all the troubleshooting instructions that popup when you start the program:
  1. start the program,
  2. remove the battery,
  3. hold the play button while plugging the RCA player into your computer's usb port,
  4. release the play button when the term "initalizing" replaces "searching",
  5. check the box that says "format data" (you can try it first without this checked, it may work and will save your music),
  6. click the start button to replace the firmware.
This solution will fix your player.
I hope that helps.
on Jan 17, 2010 | RCA TH1602 MP3 Player
RCA pearl th1602-a with new battery will not power on. Old battery will power on, but freeze at pearl logo. Player powers on when plugged into USB of computer. It is already at the latest firmware.
When was the last time you flashed the firmware? Even if it already has the latest firmware, it sounds like it is still corrupted and need to be reflashed. It appears you already know where to find the latest firmware update based on your comments, but just in case you can download it here:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/2557
Oct 22, 2009 | RCA TH1602 MP3 Player
Rca pearl th1602-a I turn it on all I get is the pearl emblem and it wont turn off. I have to pull the battery to stop.
My solution to a Pearl TH1602-A stuck on the pearl screen:
Download the firmware upgrade from RCA's website, run it.
RCA PEARL FIRMWARE DOWNLOAD window should open.
Remove battery from Pearl, keep out.
Press PLAY and hold while plugging into USB port,
when "initializing" progress bar moves, let go off play button.
On my windows, it installed some software and asked me to reboot. After the reboot I re-ran the Pearl firmware file and about 30 seconds later the start button was now available.
Click it. However, You will loose your music on the internal storage.
Oct 07, 2009 | Audio Players & Recorders
My mp3 rca th1602
You can d/l the drivers for you Pearl here http://voxrightnow.custhelp.com/app/answers/detail/a_id/2243/related/1. Follow all the troubleshooting instructions that popup when you start the program:
start the program,
remove the battery,
release the play button when the the term "initializing" replaces "searching",
You might want to leave the "format data" box unchecked to see it that works. After I did this, my pearl started normally, and my computer recognized it again.
Jul 06, 2009 | RCA TH1602 MP3 Player
Computer not recongize the rca th1602 mp3 player
The first time I tried to restore the firmware in my Pearl it would not recognize it. I had to follow all the troubleshooting instructions that popup when you run the software. Basically, try taking the battery out and waiting 10 seconds or so. Run the software and read all the instructions at the bottom of the popup window. then hold the play button, plug your player in, and keep holding that button until the software recognizes it. It works.
May 05, 2009 | RCA TH1602 MP3 Player
My pearl th1602 is froze
Remove battery, press and hold "Play" button when inserting into USB port. Run the firmware update and should be able to re-initialize the device, start the update with the "Format" option checked. Worked for me.
Feb 24, 2009 | RCA Pearl TH1102 MP3 Player
Rca pearl 1602 will not power up new battery
Try removing the battery, insert Pearl WHILE SIMULTANEOUSLY PRESSING and HOLDING the "PLAY" button for about 5 seconds. Windows Device Manager should see the device under "Human Interface Devices"as a "USB Human Interface Device". Run the latest firmware update, it will see the HID device and initialize it as a "Disk Drive", "_Generic MSC Recovery USB Device". Once the firmware update is complete the Pearl should work again. The trick was to remove the battery and hold down the "Play" button while inserting to force recovery mode.
Jan 25, 2009 | RCA TH1602 MP3 Player
RCA Pearl TH1602 Frozen?
I had the same problem, usually plugging it into the usb port on the pc and verifying the files on the player, then disconnecting the player will solve the problem. Other times i have to reformat the player, if you do that, you will have to put all your music back on. It's a pain, this has happened to me 4 times, I've only had this thing less than 6 months! It was inexpensive, I guess you get what you pay for, but I like having a AAA battery instead of having to remember to plug it in to the pc to recharge every 15 hrs.
Oct 17, 2008 | Teac MP-111 MP3 Player
RCA Pearl 1602 main issue
Try removing the battery, insert Pearl WHILE SIMULTANEOUSLY PRESSING the "PLAY" button. Windows Device Manager should see the device under "Human Interface Devices"as a "USB Human Interface Device". Run the latest firmware update, it will see the HID device and initialize it as a "Disk Drive", "_Generic MSC Recovery USB Device". Once the firmware update is complete the Pearl should work again. The trick was to remove the battery and hold down the "Play" button to force recovery mode.
Sep 22, 2008 | RCA TH1602 MP3 Player
RCA TH1602  MP3 Player Logo
350 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
