Question about Westinghouse 22" Widescreen LCD Flat Panel Monitor
Get rid of volume bar in middle of screen
Whitwestinghouse monitor my volume bar keeps popping up stays on for 15 20 sec then disapears then coms back on sporadictly
I had this same problem a while ago. It was because the top "touch" button on the side was being triggered at a rapid rate. I took mine back to the retailer because it was within the Westinghouse 1 yr warranty. After getting a replacement display (same Westinghouse 22 in), I have had to take it apart because of a bad video processing board. In doing so I have seen that the side buttons are very easy to get to and fiddle with. If you are out of your warranty period, perhaps try taking off the case of the display and fiddling with the button board and connections
Posted on Jan 09, 2010
    New Friend:
In short: try inserting a slip of thick paper (corner of a business card) into the seam between the front and back case at the location of the switch to force the back case away from the switch. Works for me.
I also have a Westinghouse L2210NW monitor with a volume pop-up problem. It was so annoying that I mothballed the monitor for a year. Last year I set it up on a new machine with a Win 7 OS and it worked fine for about a year. This week, for no apparent reason, the pop-up resumed and would not go away. Here are my speculations and brainstorming on the problem followed by a potential solution.
*) Some have suggested that the keyboard or mouse may be the problem. This doesn't seem likely for me. I'm using a different mouse than when I had the problem before. I am using the same keyboard on the new computer but I'm running a dual display. Why does the keyboard not affect the other monitor which is the primary display?
*) Some have suggested changing the sound properties by clicking on the speaker icon in the taskbar. This may be a way to suppress the icon, but I don't think the problem is software.
*) It's probably a faulty switch. As most people with this problem have found out, touching the switch along the right panel will stop the icon display. Besides being a nuisance, however, the switch is out of sight right next to the monitor power button so it's very easy to be off by a 1/4 inch and turn off the monitor, which requires a delay to refresh. p-m-forbes suggested opening the case and fiddling with the switch might fix the problem. This is probably true but there's an easier way without cracking the case. A comment I found on another forum for a different monitor (eMonitor?) suggested that putting a spacer between the base of the computer and the switch fixed the problem. This doesn't describe the Westinghouse switch very well but it points in the right direction. If the popup occurs because the switch is too sensitive, perhaps the outer monitor case is pressing against the internal switch. On my Westinghouse monitor there is a seam on the side between the front frame and the back case. The switch is mounted in the back case, which overlaps the front frame. Insert a slip of thick paper (e.g. the corner of a business card works for me), into the seam between the front and back case at the location of the switch to force the back case away from the switch. It has been only an hour now, but no pop-ups. Previously, I was getting pop-ups about every two minutes on average.
Posted on Aug 01, 2014
Upgrade to Windows 7
Posted on Nov 18, 2009
My Emachine monitor had a gray box w/volume control that keeps popping up in the middle of my screen. I have tried numerous things to make it disapear and it seems when I think it's gone for good it pops...
As a monitor tech, I have to say. You two dopes are completley useless. My son, LB who suffers from severe downsyndrome among other ailments. Quickly figured out that if he stuffed the eraser he was eating between the base and the menu button, the problem would go away.
Congrats on being outsmarted by my disabled son who eats pennies and erasers.
You should be proud. Next time, don't be so, You know....havanagilaish.
Aug 30, 2010 | E-Machines eMachines Monitor E15T4
A volume box keeps popping up on my E-Machines monitor (E181H). If I press one of the buttoms on the bottom of the monitor, the pop up goes away, but it keeps popping up periodically. The box shows a...
Wondering if you resolved it and how I was having the same issue have taken my screen apart and it is not the button pressing seems to be a deeper routed issue. I have tried driver re-install, change of start up and various other items none are resolving it. I think it maybe a issue directly related to the manufactoring of the E181H Monitor.
Apr 05, 2010 | Computers & Internet
Brightness/contrast window pops up and scrolls through fast
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
May 28, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor keeps displaying model and serial information
@ baller98_199; did you ever get a solution to this? I'm having the same problem with the same monitor!
Mar 13, 2009 | Sony SDM-HS75 17" LCD Monitor
The Volume Screen on my monitor keeps popping up
Try putting pressure on the monitor near the buttons. There might be a short or some type of stress pressing the buttons.
Mar 04, 2009 | HP w1907 LCD Monitor
Volume pop up in the middle of my screen
no photos of said window presented? i cant see them?
must be OSD? the monitor brain on screen display (menu)?
even with the DVI cable pulled?
only a monitor stated, w1907, no PC
some monitors have button lock
read the manual ?oops HP deleted it...
it tells you to push the menu key on the monitor for 10 seconds
and it unlocks. (4 buttons right side left button is MENU)
doom?
that power deal sounds super bad, like the power supply is bad.
if the monitor fails by its self not plugged it to a PC
then the monitors is bad.
try a reset on it? ( power off for 1hr, or off then plug in with power button held? or power on with menu held (wild guesses but common practice)
ok found your manual page 4-8 shows menu page advanced
list line in list factory reset.
but if the keys are dead, and power lamp failing
the power supply is no good or worse. worse is always possible.
and expensive
ever see the support page, read the guides
https://support.hp.com/us-en/product/HP-w1907-19-inch-Widescreen-LCD-Monitor/3709665/model/3709666
its over 10 years old now. 2007?
walmart has larger one for $50
cheaper that parts or repair this.... vastly
Jul 27, 2017 | HP w1907 LCD Monitor
Sounds like one of the front panel buttons is stuck in - possibly the volume down button. If no buttons work, this could be the reason why. Just a guess. If they all feel OK, it may still be worth pulling the back off, (Without electricuting yourself -DISCONNECT POWER!) remove the PCB board that has the buttons on it, and see if it turns on without the menu. If so, check all buttons, rare but I have seen one that looked fine but with a multimeter it showed it wasnt working. If the screen still displays the menu, Id say there is a bigger problem... HTH
Jan 19, 2009 | HP f2105 21" LCD Monitor
On-Screen Menu
You have to check keyboard and the cable which interconnect main board and keyboard it could be damaged.
Oct 25, 2007 | Samsung 931BF 17" LCD Monitor
Westinghouse 22" Widescreen LCD Flat Panel Monitor Logo
1,705 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
cxbxr_3
cxbxr_3
Level 1 Expert
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
