Water in machine not advancing to spin? What is wrong and what can I as an end user fix?
  • 65 Answers
My washing machine did this and I found that the lid switch had gone out. I bypassed it and keep out of it when it is spinning. You could do this yourself but it is a safety issue and if you have children around may not be a good idea. When you raise the lid look for a plastic piece on the lid that is inserted into the machine when you close the lid. As soon as you locate the actual switch (unplug machine from the power source) remove he two wires from the switch and tie them together. However, machine will run through all cycles even with the lid open. My Whirlpool washer has been running for 21 years. I bypassed the lid switch about 5 years ago.
Posted on Jul 02, 2009
Hi my washing machine works perfectly fine but the water don't pump out srew out bottom filter is clean and I clean it on a regular basis. Defy 1300 laundromaid. Thanks please help
You probably have a rock or some object stuck in the pump blades. Take out the pump and turn the blades get out the obstruction
Nov 26, 2014 | Washing Machines
How to move around brandt wm 550
see this causes and fix it. God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Sep 22, 2012 | Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
Aug 01, 2012 | Washing Machines
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
Washer won't wash
Hi!
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | GE Washing Machines
Frigidaire washing machine gets stuck on cycles
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Frigidaire Washing Machines
GE Top Load Washer WLSR2000G3WW~smells like burning and wont drain
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Nov 06, 2008 | GE WBSR3140DW Top Load Washer
Front loead washer will not spin/rinse,
First, make sure that you do not overload the machine.
Sep 17, 2008 | Frigidaire ATF6000ES Front Load Washer
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Clothes washing machine
    Fist off the unit is operating ok it was designed to only spin after the water is let out. by you opening the lid and closing it you have paused the machine (opening the lid) and started it back up This function is also built in the timer to pause the machine then go into spin.. The timer sounds like it has a dead spot in it. is this the only place in the cycle it does this ???? or does it stick and not advance say in the Agitate portion of the cycle?? there is a small timer motor on the timer that advances it it could be going out l. If you check that out with no luck the part # for the timer is 3954449 is is about $102.00 at www.sears.com it is $109.00 at www.apdepot.com the little drive motor on the timer is not a replaceable part the whole timer will have to be replaced
    Hope this Fixes Ya
    Feb 16, 2008 | Kenmore Elite HE4 Electric Dryer
    Washing Machines Logo
    149 people viewed this question
    Top Washing Machines Experts
