Question about Home Security
How I can change the backup bateries
How I can change the backup battery in my security panel
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 188 Answers
Find the correct replacement at Batteries Plus, Radio Shack,etc. Disconnect the red and black wires on old battery an install in correct place on new battery. Red is + Black is -
Posted on Jul 23, 2009
The power wents off and the batery got completly discharged , then i turn it on and run the self test and replace icon staid illminate but in the next self test didn't, i hace to replace the battery?
First tell how old is your UPS ?
if its older by two to three years may be the Battery eeds a replacement .Try charging the battery externally with a good battery chargers but before charging externally please take out the battery outside.
Then if the battery shows very low voltage even after charging for some 8 hours then you have one alternative that is replace with new battery.and promptly keep it under charge with out fail.
Aug 16, 2014 | Tripp Lite G1000U Intelligent LCD 1000VA...
Numeric ups red light indicates?
1. low batery (not proper charging due to bad or not proper acid level)
2 short circuit
3.inner ICs needs to change
Apr 26, 2014 | Computers & Internet
I ave a powerware 9120 and get a Charger failure alarm
check your batery, may it was leaked, change it with new battery
Jan 17, 2011 | Powerware 9120 UPS System
Batery backup 1hr in 8 months
do not use your battery backup to the last point where it totally shuts down .
That way your battery drains and next time it dose'nt charge fully
Dec 06, 2010 | Lenovo G550 PC Notebook
Hi i have a May 2004 Toyota Prado GXL 4L petrol auto. I had the batery changed at Batery World as i knew it was on its last, they put a backup pack on to retain the sterio code and settings and then...
I would take it back to Battery World and let them fix it.
In our days Cars very sensetive to power loss to power train menagment components , may have to do somthing with throttle control.
Apr 28, 2010 | 2006 Toyota Sienna
MC1000 scannerBackup battery very low
You must disasemble de unit. There is a Ni-Mh 3.6v 15mAh batery inside at the bottom of the unit.
Apr 26, 2010 | Symbol MC1000 Barcode Scanner
Mge pulsar ex10 stop after 5 min with 60W charge,after I changed the pack of 3 bateries with one new.if I switch off and on works again 5 min. all 3 bateries are good,Vcharge=13,6v Vin use=12,3v thanks
Some economics UPS have a functin called "Green Function". A timer disconnect the load after 5 min to prevent damages on internal circuit.
You can confirm this:
- battery remain to good level charge
- UPS restart for other 5 min if you press On button
See manual if you can disable this features.
Sep 28, 2009 | APC Computers & Internet
How can I revive my TI89 after two years of not using it?
It could be that you need to replace the backup battery located behind a little door with a screw in the battery compartment. If this doesn't work, try resetting your calculator by leaving backup and AAA batteries out for about 8 hours and reassembling it. Hopefulyy this will work. Good luck
Jul 29, 2009 | Texas Instruments TI-89 Calculator
UPS 1800VA
You can increase the capacity of the batteries from the original equipment, but you cannot put more load onto the UPS. Your runtime may be increased, but you may have trouble fitting the car batteries into the case. Some UPS's have external connectors for external battery packs. Find one of those and add the batteries to it. Make sure that you maintain the DC voltage which the UPS requires. It may be 12 volts or 24volts. Two 12 volt batteries in Series.
Oct 16, 2006 | HP (A2997A#002#017) UPS System
Home Security Logo
194 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
