Question about Exercise & Fitness
Circuit pops after 10 minutes.
I have the exact same problem --after about 10 minutes, every day, the circuit breaker pops and it takes about an equal amount of time before it can be reset. The weather is nice, so I just hit the trail, but when the cold, nasty weather approaches, I'm gonna need the treadmill. What is the deal?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 95 Answers
The walk belt may be worn or it may just need to be lubricated.Feel the underside of the belt,if it feels fuzzy it is worn,if it seems ok you can purchase treadmill belt wax at stores that sell treadmills or do an on line search for it there are many websites who sell it.
Posted on Aug 01, 2009
Keeps blowing circuit breaker
It could be the circuit breaker, those do sometimes go bad, but it could certainly be something plugged into that circuit pulling more current than it should. Try disconnecting everything on that circuit. Does the breaker still pop? No? Plug one thing in. Pop? If not, keep going until you find the one that's a problem, and check the total amount of current all the devices you have plugged in use.
Most standard plug circuits are only rated at 15 amps. For example, a toaster may pull 12, a hair dryer 10. You can't run both at the same time on one circuit.
Jul 10, 2015 | Electrical Supplies
My trolling motor burn out circuit breaker if it runs for about 30 minutes
Have you measured the current? Is it in spec? Is the motor stiff or seizing and taking excessive current, is the wiring to the circuit breaker adequate?
Jul 28, 2014 | Electrical Supplies
My duo therm 13.5 btu rv air conditioner started making a popping sound and dimming the lights like it's trying to cycle to shut off. Well then it started triping the circuit breaker so I changed out the 2...
The best guess is that you have a bad thermostat. When the compressor shuts off it has to stay off for a long enough period of time for the low pressure high pressure to equalize. If it turns the compressor off and back on immediately it can't start against the heavy load created by these unequal pressures. If it will start every time after sitting for 10 minutes the thermostat is making it short cycle.
May 26, 2014 | Dometic Rooftop RV Air Conditioner
Tripping circuit breaker
That unit shows that it takes 15 or 20 AMPS to run. What is the breaker amperage on the circuit where it is plugged in? Is the breaker a GFCI? You can tell by looking for the two buttons on the circuit breaker or the outlet.
Jul 18, 2017 | KitchenAid KCMS1555RSS Stainless Steel...
Refrigerator trips circuit breaker
try standing it upside down for a day it will work
May 28, 2010 | Amana ATB2135HR Top Freezer Refrigerator
Exact same thing happened to me
the 20 amp circuit should more than handle a 6.5 amp load, the 6.5 is the rating of the operating AC not of the circuit that is required to be attached to it. If the "pop" noise is the breaker tripping the circuit may be miswired, the unit mayhave a short to ground, as the circuit breaker is designed to trip on an over amp situation or a situation where 20 amps is exceeded. Di you verify that the circuit voltage id correct, eg: 220 volt or 110 volts. and that it matches the unit nameplate.
Jul 20, 2009 | Goldstar KG6000R Window Air Conditioner
Hitachi RAS09UH randomly pops 15A circuit breaker
Two things that you could check: 1) If you have access to an ampmeter, determine if the unit is drawing over over 14 or 15 amps, 2) replace the suspect circuit breaker in case it is beginning to go bad. Breakers only trip for overcurrent conditions or failure of the breaker itself. If it is pulling close to 15 amps, then it could heat up over time and trip.
Jul 09, 2009 | Hitachi RAS-09UH Air Conditioner
Dishwasher pops the circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Jul 01, 2009 | Whirlpool GU1100XTLB / GU1100XTLQ /...
RE: Roper Electric Dryer, front load
You have a ground fault or short . Disconnect dryer and remove small panel that holds the cord. Check if any wires are frayed, loose or touching any other metal objects.
Jun 29, 2009 | Dryers
Furnace keeps tripping circuit break
Furnace. To confirm use an Ampprobe or other brand ampmeter and see how much current is being drawn. If it is more that 80% of the breaker rating, it si for sure the Furnace.
Jan 10, 2009 | Haier Energy Star ESA3183 Air Conditioner
Exercise & Fitness Logo
212 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
