Whirpool Ultimate II Not spinning
My Whirlpool ultimate II won't spin. Everything else works fine.
1.) I Replaced the lid switch. 2.) I've replaced the drive coupler with a beefed up one (metal reinforced and all), but no luck. there's no change in status.
I've pulled the aggitator to make sure that everything is good up top (which it is), and I've now dropped the motor and transmission. I noticed that when I twist the coupler prongs on the transmission, the shaft does not move. Is this normal? I
've also noticed a great deal of black dust at the base of the shaft... along with orange fluid like on the floor beneath the washer. Some of the metal around the gearbox had oil on it as well.Is my gear box shot?? is that why it wasn't spinning?
    President:
  • 3,113 Answers
Internal transmission trouble.
Posted on Jul 02, 2009
Our ultimate care ii is not working properly. it
the lid switch is broken,open and close the lid if you don't hear a click that's a sure sign the lid switch is broke,try sticking a pen or something in where the switch is you might get it to spin and drain but you gotta change out the lid switch
Feb 17, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirpool Ultimate Care II - Top loading washer The water will not drain prior to the spin cylce - Please help
The lid switch is the most probablle cause for this problem.Check the lid switch lift the lid and close it if you cant hear a click replace the lid switch.
Dec 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool washer ultimate care II sometimes does not spin.
HI It sounds like the spin basket drive is going bad. If it was the lid switch, you would get no sound. Let me know if I can assist you further.
Thanks
Vic
May 16, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine does go thru spin cycle or drain water.
If the washer does not spin, take off the rubber bumbers inculding the little washers attached, inside the lid. It lowers the lid, which takes care of the problem. I had the same problem. Not anymore! Trust me, if nothing is wrong with any other part of the washer, this will work.
Apr 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine stops working
I search in the internet on regards to the problems with the Whirpool Ultimate Care II and found out that many others had the same problem as I did. Some solved this issue replacing the switch, so i decided to do the same.
I opened the machine and saw that the switch was not working properly, it was not doing any contact, so whenever I open or closed the lid, nothing was happening. I did a house fixing, with some duck tape i was able to make the system work, and now the machine is washing everything again.
Nov 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool ultimate care II will not spin
You said,washer is full of water and will not spin. You hear the lid switch clicking. When you start it on spin cycle and hear a hum, the tub moves a couple of inches and then stops...shortly after it shuts off.
Some reasons this may happen
Washer won’t drain or spin
n
1. Is the drain hose clogged, or the end of the drain hose
more than 72 inches (183 cm) above the floor?
2. Is the lid open? ............Also the lid switch can be faulty!!
The lid must be closed during operation.
3. Is there excessive sudsing?
Always measure detergent. Follow manufacturer’s directions.
4 If you have very soft water, you might need to use less
detergent.
Sounds to me like the lid switch can be faulty!!Then it acts like the lid is open.
Huuum
Oct 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirpool Ultimate care II
your lid switch is broken you need to replace it look on the lid of the unit you will see a plastic pin that pushes down on thwe switch when it closes there are 2 screws holding the switch in place but you will have to remove the cabniet to change the switch
Jan 21, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Ultimate II is refusing to go into agtation/wash cycle
It sounds like a bad timer unit, and possibly a lid switch.
As far as the water overfilling, that may be an unrelated problem, such as the water level switch... but most likely the timer.
I have the same model, and it wouldn't drain.. and it would try to spin when full of water... an interesting sight to see!
Jan 07, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II washing maching but will not spin.
lid switch is bad chance are you can by pass this by removing the timer header and crossing the outer wire on the lid switch that it mounted closest to the lid not the power cord this will tell you if you need a switch
Dec 03, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
114 people viewed this question
Top Washing Machines Experts
