Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
Where is the tab that the spring hook should rest on
  • 12 Answers
The place that the spring hooks to is inside the rope housing. The rope spindle hooks into the spring coil and screws together in the rope housing. Then the housing is attached to the saw ( 4 screws ).
Posted on Jul 06, 2009
Gov and throttle linkage
gov. rod hooks to the hole in the top of the butterfly. the spring hooks to the carb and the front of the engine on the metal tab.
Aug 10, 2016 | Toro Power Lawn Mower
BLADES WILL NOT TURN OFF, FOUND A LARGE SPRING ON DECK. IT SAID TO HOOK IT TO THE IDLER PULLEY AND THEN TO THE TAB ON THE FRONT OF THE DECK. THERE IS NO TAB ON FRONT OF DECK. WHERE DOES IT HOOK TO?
The tab they are directing you to may have broken off - hence the spring hanging and no place to connect the other end. You might need to have this service professionally..
Oct 19, 2015 | Bolens 13.5 HP Manual 38-in Riding Lawn...
Proper windshield wiper adjustment?
Good question. Try a site for Mustang Owners like a Club online. The spring tension can be adjustable by moving the tab that houses the spring on each arm. If you are concerned with the position, simply move the arm on the serrated shaft until the blades rest on the cowl. There should be little pressure. The sweep should fall in line with the "at rest" position. If not, a small adjustment can be made to maximize sweep.
May 18, 2015 | 1966 Ford Mustang
How do i fix my jenn-air refrigerator JSD2488DEB .The damper door and spring fell off while removing a part.I have no idea where the spring is placed?
Parts for Jenn Air JSD2488DEB Shelves Accessories Parts
This might help. However you could try putting the damper door in without the spring and moving it through its open and closing to see what is near the door the spring could hook to. Look for small holes or tabs.
Dec 31, 2014 | Jenn-Air Refrigerators
Door does not stay closed
If you gently push up on the door latch heads (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
The service manual for the R-408LS (the model you posted it under) is here.
You can order parts from the Sears Parts Direct Web site.
Oct 26, 2013 | Sharp R408LS Stainless Steel 1100 Watts...
The govenator spring fell off my push mower
make sure not to stretch it out this is critical under filter houseing is the throttle useally white plastic on a shaft going down through carb and has a hole or 2 one for governer rod and the other for the spring then a tab a inch or so away with a hole carefully hook into the metal tab and carb with out over stretching the spring
Sep 05, 2012 | Mtd 22" Yard Machine Push Mower
Can't figure out where to hook the idler spring onto the mower deck on my DYT 4000
look at the picture on the bottom of the foot rest there is a picture there
May 18, 2012 | Garden
I took my Hitachi NR83A apart to remove a jambed nail, and can not figure out how it goes back togeather. Where does the tension apparatice go inrelation to the shaft and slide handle? Thanks Vince
You do not need any special tools to assemble the pusher into the rails, however there is a trick to getting the spring in the proper position. I use a small pair of vice grips and a paper clip to hold the spring in position. The pusher slides into the rails easily. The back part of the pusher slides into the rails first. On the back part of the pusher there is a groove that accepts the spring, spring spool and pin. The pin will be in a vertical position and the spring will have the end tab with hole towards you. As you push this assembly into the rails you will loose sight of the spring end tab. You must hold the spring end tab at the bolt hole while you push in the assembly. This is done by bending the paperclip straight with very small hook on one end. Hook paperclip on spring tab hole and hold paperclip with vicegrip to position spring tab hole at bolt hole and push assembly all the way into rails untill it locks at rear or rails. This procedure can be varried with goal of holding spring tab at bolt hole. While holding tab in position insert rails into nose of gun and bolt rails. Just leave paper clip hook end there or pull out it does not matter. You are done. Good luck
Aug 05, 2010 | Hitachi NR83A2 2" To 3 1/4" Full Head...
609 yard machine tractor idler pulley spring broke
Here's a diagram, not a great copy, but it may help:
The spring hooks to the idler arm on the opposite end from where the pulley is mounted. The other end of the spring looks like it hooks to a raised tab on the deck, straight behind the left mower spindle. Hope this helps you, please rate my solution if so, thanks!
Jun 08, 2010 | Mtd Garden
Poulan starter rope
to fix starter rope first you must wind spring and place back in housing. just grab spring by middle and wind ,you will have to get it smaller than housing hole. One end should hook to a tab at housing rest of it sets inside itself. once set in housing dont let go, insert rope housing over top & screw in. rope housing should have some return spring to it when pulled. if rope is not tight on return pull simply add one winding to spool. hope it helps!
Feb 14, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
69 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
