Question about Maytag SkyBox MBV1976A Beverage Dispenser
Compressor problem, installing the Supco 3-in-1 Relay
My compressor quit, and unfortunately the serviceman who worked on it was not quite "up to speed." He installed the Supco RC0810, which worked for only a few hours. I have bought the RC0410 as recommended on this site, but can't be sure of the connections, as the old relay and wiring is gone. Can somebody who has done it tell me which of the 3 wires from the 3-in-1 (red, white, black) go to which terminals on the compressor (top, lower right, lower left)?
The 3-in-1 also has wires for a run capacitor, yet none is apparent on my Skybox. Does it use a run capacitor?
Any advice would be greatly appreciated.
  • ms-ss Jul 02, 2009
    Thanks, Vic, for your quick and concise answer. It appears the RC0810 is installed correctly. The one I bought is the RC0410--similar except for a different hp rating.
    Problem is, most every time the compressor starts but runs for about 3 seconds then sounds like it stalls.
    Once in awhile the compressor will keep running and cool the box, but gets extremely hot within an hour. I have measured the red wire current at 6 amps, which is obviously too high. Don't know where to turn now except to try the other 3-in-1.
    I know this is tough, but do you think I should give up yet?
    Mike
    Vic,
    We bought it new 4 1/2 years ago. The warranty is only 1 year, so we are surely out of luck. Plus we had it repaired by a non-Maytag tech. After reading all the bad comments on FixYa, I get the idea Maytag won't repair it for any price. And they say no parts are available. I have seen a couple posts about a "compressor transplant," but I wouldn't be able to handle that. The compressor looks a whole lot like those in the $90 dorm refrigerators.
    President:
  • 1,136 Answers
Hi, If the 3 posts are top center and bottom right left, the black wire goes top the top center post. The red wire will go to the bottom right and the white goes to bottom left.
If the posts are bottom center and top right left, the black goes on bottom center and the red goes top left. The white goes top right.
If you do not see a capacitor, disregaurd the wires in the 3-1
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 02, 2009
  • Victor
    Victor Jul 02, 2009
    Mike, It sounds like the compresor might be going bad. I have seen this a lot and even hesitate and give my customers the choice on replacing the 3-1 because Ihave seen to many compreesor go bad soon after. It's not the 3-1's fault. It's just the compressor usually causes the re;ays to go bad because they are working to hard.
    How old is the refrigerator? Under 5 years it might have a warranty.
    Vic
  • Victor
    Victor Jul 03, 2009
    Yes, the compressor is a major job. Some makes have 5 year warrenty on compressor but, the service call and laobor wil not be covered and they are pricy as well.
    Good luck Mike
Im replacing START RELAY ON AN OLD 1950,S FRIGIDAIRE REFRIDGE ,CANT FIND A YT-4 SO IM USING THE SUPCO rc0410 ,CONFUSED ON THE WIRING FOR T-STAT-LIGHT -DOOR SWITCH -HELP!
Posted on Mar 22, 2012
  • Steve Kissell Apr 01, 2013
    I too am having this same delemia,how do the thermostat wire play in without the full power demand going thru the thermostat?And where does the neutral wire from the power supply patch in, to the white wire going in to the compressor?
Not cooling quit working
call a serviceman possibly needs recharged
Mar 12, 2015 | Amana AFI2538AES Stainless Steel (256 cu...
The a/c on my 2010 Mercury Milan quits blowing after about 2 hours of driving. Any ideas?
Sounds to me like the A/C clutch is no good and out of adjustment.You should goto your nerrest junkyard and get a used assembly take the clutch off then you learn how it comes off and install it on yours the save the pump for later use if needed. The clutch should only have a .010 air gap after install between th inner elctro magnet and the clutch plate it's self.
Aug 04, 2012 | 2010 Mercury Milan
I have a kenmore chest freezer model 19502/19702. I had it unpluged for 5 months. When I plugede it back in the power light flickers. Tryed other outlet. Other then that it seems to be working
We purchased this same Kenmore chest freezer model 19502/19702 in 2010. In less than 2 years the compressor quit. If you do a search on this model you will see dozens of complaints. Don't waste your time or money on this freezer.
Apr 16, 2012 | Kenmore Freezers
My Hair 12 bottle wine cooler quit cooling. what is the main cause?
Possible bad thermostat. Bypass the thermostat wire to run the compressor. If the compressor start, replace the thermostat. On the other hand if the compressor is running, and there is no cooling; there is a leak and all the refrigerant probably escaped. If it is the case, you need to call serviceman and have him evaluate the wine cooler for possible repairs. P.S. The serviceman may charge a fee for evaluating or estimating the cost of repairs.
Dec 29, 2010 | Haier BC112G Wine Cooler
Freezer getting warmer
The click sound is the overload on the compressor kicking out the compressor because of high amperage draw........(check with a amp clamp if you have one) Also if you do not have a stationary condensor coil hanging on the back there should be a fan running if the coils are on the bottom and clear for air flow.
There are some things you can do depending on the age of the unit.......
If it is a newer unit still under manufacturer warranty it may be best to call a authorized servicer to fix unit..
If it is past warranty you could try a supco 3n1 hardstart either 410 or 810.
Fairly simple to install with a diagram(have it unplugged) It is a universal part for the relay overload and maybe a capacitor on your unit.......If the compressor is bad and not one of the electrical parts on the compressor it will not repair it and you will be out the cost of the part. If it does fix it your done...... If you wire it wrong you are also done......
Good luck.......
also wait a few days to buy groceries (as sometimes a compressor will fail with a correctly installed supco hardstart) that unit is working ok again
Apr 06, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Compressor stops running and keeps cycling every few minutes. It buzzes as if the compressor is gone. the compressor is hot. If the thermostat is turned to off for 6 to 8 hours and then turned back on the...
you can replace the relay with a 3 in 1 made by supco. i generally just use a supco 0410.
www.supco.com
it is a start relay, overload, and start capacitor all in one. works great for residential systems.
Nov 06, 2009 | Frigidaire FRS3R5EMB Side by Side...
Compessor will not come on. I hit the compressor with my hand and it came on until the fridge was cold again and it shut off. Now it will not come on again.
You need to replace the overload/relay , plugged onto the side of the compressor , with 2 or 3 wires going to it . When you hit the compressor , the jolt , reset the overload .
Nov 01, 2009 | Refrigerators
Help on RC0810 Refrigerator Relay Overload Start Capacitor
Really cool fix - this is used when the refrigerator has trouble starting but is not a factor of not cooling properly. See link below. How to Install Universal Relay 3 1 Starter on your Compressor
Feb 28, 2018 | GE Hotpoint 18.2 Cu. Ft. Top-Freezer...
Stops working after a week then will work again
It sounds like the compressor is starting to get a little worn out and needs some assistance starting. This is achieved by adding a start capacitor via a Supco RC0810 3n1 start device.
Oct 14, 2007 | Freezers
Refrigerator/freezer is warm, fan is running.
The problem is the compressor isnt starting. The relay is probably ok. It should have 5yr warranty on the compressor. However if you purchase a Supco RC0810 start assist relay available at all appliance parts stores, it will start the compressor, however this is only a temp fix. But it should last till sears can put a new compressor in.
Sep 29, 2007 | Refrigerators
Maytag SkyBox MBV1976A Beverage Dispenser Logo
4,989 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
