Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
Login/logout - password request goes to status page only
I have a Belkin 54g. The problem I have is my wireless connection works but is in unsecure mode. When I access via Web interface and click security it takes me to the pasword login page, (I have rest the factory default numerous times so assume it is now blank - no password) after clicking submitt with blank password the Status page comes up. This happens every time I want to change anything or anytime a password login page comes up. In other words, I can not change anything which requires password as after clicking submitt, it goes to the Status page. All help will be greatly appreciated. Thanks.
  • 1 more comment
  • inet_mark Jul 02, 2009
    Thanks for the quic reply, the problem has been rectified by using another Laptop that I connected to the router wirelessly and you maybe right as that seems to be the only thing that I had not looked at on the problem PC - meaning clearing the cache. I shall do that and see if that lets me see the correct pages. Infact the setting on the browser was to never check for Newer versions of the web pages, changing that to check every visit has solved the problem. Thanks again for your quick reply.
  • Rolena Facundo May 11, 2010
    Hi, You said that you cannot change anything on the router setup page, right? Have you tried to clear your browser's cache or used other browser or other PC to isolate the problem? There's a possibility that you are just seeing the cache of the router's interface and that's maybe the reason why everytime you change something it just goes back on the status page.
    Scholar:
  • 62 Answers
Posted on Jul 02, 2009
How do I rename my network on a Belkin router
Please open the configuration page of your router by typing your router's IP address on a browser's address bar. Router's IP address is the default gateway when you check the IP address on the command prompt. As soon as you are on the login page, type the user name and password. Look for the wireless settings tab. SSID is the router's wireless network name. Replace the SSID of the name you want for your wireless network and apply the changes.
May 21, 2011 | Belkin (54G F5D7230UK4) Wireless Router
How to remove pass code so wireless access is open not secured
1. Connect a computer to any of the four LAN ports of the Belkin Wireless router.
2. Open your web browser and type the router IP address of the router(by default, the address is (http://192.168.2.1) in the address bar press Enter.
3. Click Login on the top of the page to login to the router. By default the Password is left blank, click Submit. If you have already changed the password then type in your password.
4. Click Security under Wireless menu.
5. Under Security Mode, select Disabled.
6. Click Apply changes to save the settings.
Feb 04, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Unsecuring my wireless router
http into it 192.168.0.1
if you set the password there is a small button somewhere at the back of the Bulken that will reset that ... You shiould be able to HTTP into the the setup menu and change any of it's configuration
Jul 26, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
It wont connet to my belkin wireless router
Hi...to find the password, or network key:
1) Login to your router.
To do this, open a web browser on a computer, as if about to view a web page: then type the router address, http://192.168.2.1 in the address bar.
2) You should see a prompt asking for a password. Just click 'submit' button if none has been set: otherwise, enter the correct router login password.
3) You should see the router user interface. In the left hand menu, under Wireless, click Security.
The 'Pre-Shared Key' or PSK you see there is the network key (password) you need.
Please come back to Fixya if this doesn't work or if you need help with any of it. Good luck
Jan 11, 2009 | Belkin (F5D7230-4) Router (587009)
Router
you may need to set up a security item...can't remember what it is, but you need to set up a password as well, to make the network secure
Jan 07, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Router problem
Connect a computer to any one of the four LAN ports of the Belkin wireless router. DO NOT use a wireless connection, use a cable.
Open your web browser and type the IP address of the router (by default, the address is http://192.168.2.1.) in the address bar and press Enter.
Under Security, Select 64 bit WEP (or 128 bit WEP).
Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength). You may also enter a pass phrase and have the router generate a key for you. Example (0102030405060708090a0b0c)
Apply the settings.
Please write down the key – You will need it later to configure your and your neighbors wireless computers with the same key.
Remember to set an admin password before you close down, other vice anyone can access you router and change the setup and admin password.
/regards
Teis
Dec 31, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Cannot connect my Mac Pro to the internet via my Belkin wireless
With the router powered on, use a small thin object to press and hold the reset button for exactly seven seconds. The router lights will flash and this will restore the router to factory default. Connect your computer to one of the routers lan ports with an etherent cable. Open your web browser and navigate to 192.168.2.1. This should show the router status page with the default settings.
This will make the router unsecured again, so be sure to go back into setup and reset your Wireless security. I suggest using WEP authentication, and using a 10 digit ph # for your key (that way its easy to remember).
Dec 31, 2008 | Gateway 802.11g Wireless DSL/Cable Router...
Unsecured network shows up as secure
The person who has the router attached to there computer must enter the IP for the router and you will be able to reset the password to enter the router. If you need Help doing this I can solve this issue with you through my computer.
Hope This Helps
All The Best,
RCF
May 28, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Router disconnection
1. Open an Internet Explorer window on your computer and type in http://192.168.2.1 in the address bar. This will take you to the Belkin router's web based configuration page. If you are not able to open the page click here.
2. You will get a login page. Leave the password blank. Click Submit .
3. On the left side of the page, click Channel and SSID below Wireless .
4. The wireless channel on the Belkin router is set to Auto by defualt. Change the wireless to a static channel like 11. Click Apply Changes .
5. Click Logout in the top right hand corner.
6.Then reconnect to your wireless network.
May 17, 2008 | Belkin (F5D7230-4) Router (587009)
Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
181 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
